23-01-2012 #6
Yes it's Ali plate and yes it cuts very easy using hand held circular saw used for cutting wood so long as it has a TCT tipped blade, preferably with a thin curf.
There are purpose metal cutting blades as well but can be expensive and not required if just doing the odd bit of Ali cutting.
You could use a jigsaw but the hand held makes quick work of it and cuts a nice straight line.(Better if you use a guide or piece of wood to run against)
The hand held will cut 10mm plate in one pass just lower the blade in nice and slow and push at a slow feed. Make sure you use goggles and long length sleeves because the chips burn like crazy.
You can even cut Ali with hand held router if you take shallow depth pass's. Thats how my first machines gantry sides and Z axis where cut, I made a MDF template then used TC 6mm straight top bearing guided wood bit and cut around the templates in 0.25 pass's.!! . . . Scarey shit at first and took awhile to do but it worked ok.
With this setup you'll be ok for anywoods really so long as your not expecting to cut 20mm in one pass.!! and my comment about light wood use was aimed at your first design mostly.
Regards cutting Aluminium then yes it will but you'll need to be sensible, don't expect it to take 2-3mm depth pass's or even 1-2mm. You'll be in 0.25-0.75mm Max area for acceptable results. That said this is still usable thou and if your realistic with DOC/FEED rates etc then it'll be ok.
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
help please with first attempt
By phill05 in forum Machine DiscussionReplies: 13Last Post: 01-06-2010, 05:42 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
