    Good Day all,
    thought id start a new thread through fear I wont get any responses in my build thread
    As part of my machine build, I am going to have to try some milling... I have a lathe with a miller on it. But ive never used it.
    It presently has a drill chuck (which I am led to believe is dangerous to mill with) and I should change it for a mill head
    Ive tried to find information about what taper the mill head will accept but Ive found varying facts the more I look, therefore I decided safest way would be to look at the actual taper. So I popped off the drill chuck and this is what I have to play with
    My question I guess, is as follows
    Do I buy a "MT3" collet taper chuck or "MT2" etc
    also, can anybody recommend one imparticular? I probably need to get the collet set aswell.
    In an ideal world; It would ideal if the same collet set worked on my water cooled 2.2kw spindle (I havent yet bought) for my cnc build.. But that might just be too lucky
    while im here Il ask another question if im able
    1.) this bad-boy is going to get in the way of my milling area... so how do I remove it
    I note the rustyness! this is because my garage roof at present is metal sheeting which condensates. Im pulling it off this weekend, boarding it.. then felting it, then putting metal sheets back on. not to mention re-homing the machine
    thanks in advance for your responses
    matt
    Robin Hewitt's Avatar
    Lives in Seaford, Sussex, United Kingdom. Current Activity: Viewing NEW MEMBER: Hi everyone Has been a member for 9-10 years. Has a total post count of 1,614. Received thanks 109 times, giving thanks to others 7 times. Is a beta tester for Machinists Network features. Referred 1 members to the community.
    Hi Matt
    Don't want to teach Granny how to suck eggs, but you seem to be measuring a Jacobs taper which is mounted in the milling head taper and thinking to mount a collet chuck on it.
    I'm wondering if you are confused about what you are looking at. The Jacobs taper adaptor is a round lump of iron with a taper on either end.
    It's the other taper you want to knock out, the one that goes up into the spindle by hammering from above. The Jacobs taper is irrelevant.
    Drill chucks don't make good milling heads because they depend somewhat on the downward drilling force to keep them in place. Once you lose that downward force they can vibrate off.
    best
    Robin
    Quote Originally Posted by kingcreaky View Post
    I can't see any release on the backplate so the chuck is almost certainly screwed on. To remove it select a low speed, insert the chuck key. Hit the key,close to the chuck, to turn the chuck in the normal unscrewing direction. A copper faced hammer is good, anything that gives you a dead blow.
    Many thanks for the reply. very much appreciated. Il have a go at removing the actual taper later.
    It should be held in by a draw bar screwed in to the taper. Unscrew the draw bar about an eigth of an inch.,
    Pull up on the drillling handle then whack the top of the draw bar. I use a sledgehammer. The idea is that the thread will catch the taper so don't unscrew too far.
    You may need a new draw bar for the new chuck because they come with various threads.
    It looks like the chuck has three screws on the back to remove it from the backplate, so you might be able to use those. You should keep putting oil on things like that to stop them rusting until the roof is fixed.
    The 2.2kW spindle will use ER20 collets, so if you get an ER20 chuck for the mill then the collets will be interchangeable. However this does mean you can only use up to 13mm shank cutters, which may be too small, in which case get ER25 which goes up to 16mm.
  1. BUILD LOG: CNC for dummies...Some electrics advice please...pretty please...
    By andy586 in forum DIY Router Build Logs
    Last Post: 01-06-2014, 11:13 AM
  2. RFQ: Dublin, IRL Manual milling & lathe work required
    By 250rri in forum Projects, Jobs & Requests
    Last Post: 30-01-2014, 01:07 PM
  3. RFQ: Looking for Aluminium CNC Milling Service + Lathe Work (2 Separate Jobs)
    By biketrialsdave in forum Projects, Jobs & Requests
    Last Post: 19-02-2013, 04:06 PM
  4. 4th Axis running as CNC lathe using milling machine
    By Jonathan in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2011, 10:34 AM
  5. RFQ: Cnc for dummies
    By MIAPISH in forum Projects, Jobs & Requests
    Last Post: 31-03-2010, 07:33 PM
