Thread: Transporting a large CNC
17-02-2013 #1CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
17-02-2013 #2
Anything that's rated to lift that weight, overhead crane, hiab, forklift. Depends on what you have available at BOTH ends & also access available at both ends. If your buying this from a Company they may also want a method statement/risk assesment for their H&S officer.
17-02-2013 #3
Better yet get them to load it. The unloading is more likely to be the problem, but I guess you will end up using a hiab. G.
17-02-2013 #4
If you have to ask this question I query whether you are the right person to be doing this move ?
Sorry if this sounds a bit harsh but 6 people don't throw one of these on their shoulders, there is a lot to take into account as regards how it's lifted to prevent distortion etc.John S -
17-02-2013 #5
Where is that from? Looks like some sort of repo warehouse. Did they have any more?
17-02-2013 #6
17-02-2013 #7Where is that from? Looks like some sort of repo warehouse. Did they have any more?
The problem is my end as I only have two telehandlers rated at 3ton each. So I might need use both, one each side of the lorry,lift the machine and then move the lorry forward and lower the router. Cover the machine with a hap for the meantime and then rent a bigger forlift to lift into place.
For the lift I plan to centralise the weight as best as possible, lock all axis in place, spread the forklift tines as wide as possible and cross my fingers.CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
17-02-2013 #8
Have a ring round machinery movers. many have fork trucks made for doing this, they are very big on capacity but can only lift 3 or 4 feet so they only need low masts to get into low buildings.
When i bought my big CNC from an auction I used the company who were already there doing work to save money.
they had one of these trucks and because my machine was blocked in by a 15 ton boring machine whey just drove in, picked the borer up, moved it to one side, then went back and picked my 3 tonne mill up and moved it outside.
took all of 15 minutes to do all this.John S -
17-02-2013 #9When i bought my big CNC from an auction I used the company who were already there doing work to save money.CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
02-11-2013 #10
Hi all,
In the end it was a simple case of using a forklift ethier end to load. Turns out the machine was closer to 3ton so our forklift just managed to lift it off the lorry and into place.
It took me about two days or so to get the router up and running and I am very impressed with the thermwood build, its no nonsence simple stuff, just heavy duty and well made. It uses 3.5" floppy disks for data transfer so im limited to 1.5mb per file, which for 2d profilling should be ok.
If I have a breakdown im thinking about converting it to mach 3, so I can fix it myself and not have to rely on expensive thermwood parts and service.CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
501 dsp pendant large files problem
By chris in forum Computer SoftwareReplies: 29Last Post: 21-02-2014, 07:45 PM -
FOR SALE: Large linear power supply
By gavztheouch in forum Items For SaleReplies: 0Last Post: 13-02-2014, 03:37 PM -
FOR SALE: large aliminium modular table £350
By nobby in forum Items For SaleReplies: 0Last Post: 31-01-2014, 05:19 PM -
FOR SALE: Transformer - large toroidial from amplifier
By Jonathan in forum Items For SaleReplies: 1Last Post: 05-06-2011, 05:31 PM -
Measuring large items accurately i.e. +-0.1mm
By alanambrose in forum General DiscussionReplies: 8Last Post: 13-03-2010, 07:57 AM
