    Hi MC
    Yea before i strip the machine down the router was running great im going to have to check and see if there is another power supply that was running the router, i know there is one under the table but i thought taht was for the vacuum pump maybe im using the wrong supply, I thought with that one being 110v it would be fine, ill have a look tomorrow and let you know.
    Hi guys heres a couple of phots of the motor under the table that i thought was for the pump, does anyone know how this should be wired as the is no input indication on the end, thanks for the helpClick image for larger version.
ID:	9320Click image for larger version.
    Well to me its looks like the red and blue wires is going to the square block and that is your DC out +ve and -ve at the other end is mains AC in where it is marked L and N but the earth seems to be connected to the bolt that is going through the centre of the transformer and if here is a metal plate on top it could be causing a shorted turn in the transformer. that needs checking out.
    One other point is you need to check if this was wired for 110V or 230V before use and it need a good clean up with new connection block fitted ...Clive
    This is not a motor it is a power supply
    That's a DC powersupply.
    Before you stripped the electrics, did you take a note of where the router was wired previously?
    I'm wondering if somebody had just wired it into the 240 previously...
  5. #15
    Check the motor plate on the porter cable. I had one that was definately 240 v.
  6. #16
    Hi guys
    Thanks for the comments the motor is definitly 120v so i think i will get a 110v site transformer and try one of those I can find any info on the power supply i have and dont want to risk damaging the router motor.
    I'll keep you informed.
    Have you considered charging the router for a good spindle, such as this one:
    WATER-COOLED MOTOR SPINDLE 2.2KW + MATCHING INVERTER d8 | eBay
    Plenty of other threads saying why they're so much better than standard routers...
  8. #18
    HiJonathon
    I have been looking at different routers but i wa s looking to get one the same diameter as the porter cable router to save making any adjustments to the router and also i want one to be able to cut aluminum.
  9. #19
    Quote Originally Posted by Tomnewry View Post
    You would surely only need to make or buy a spindle mount? If you post a picture showing how the current one is mounted then I/we can advise how to change it easily.
    The type I linked to will be far better at cutting aluminium than the one you have since, among other things, it is much stronger.
  10. #20
    Hi Jonathan
    The mount on my machine is for a 102 mm diameter motor its just handy if i don't have to change it.
  1. CY cable terminals
    By kingcreaky in forum Marketplace Discussion
    Last Post: 26-03-2014, 08:24 AM
  2. cable prices
    By deannos in forum Marketplace Discussion
    Last Post: 10-12-2012, 10:25 PM
  3. FOR SALE: Cable Glands...
    Last Post: 07-02-2011, 07:33 PM
  4. FOR SALE: Porter Cable router 7518
    By fasteddy in forum Items For Sale
    Last Post: 28-06-2010, 06:00 PM
  5. WANTED: Looking for cable braid
    By Smiler in forum Items Wanted
    Last Post: 30-05-2009, 06:14 PM
