  1. Quote Originally Posted by Robin Hewitt View Post
    Incidentally, I have a new 16mm drill chuk on there, 100% better than the Warco supplied one, got it from RDG tools for £22
    Robin
    Looking good Robin - I wonder how similar my Minor is? BTW, I have the same chuck, is yours on an MT3 or R8 taper?
    Hi Irving it's Morse :D
    I got the lack of travel nearly sorted today by angle grinder. Tested it with a loose Gibb, lost about 1cm with a tight Gibb. Can only be a few thou left to remove think I'll leave that until I need it an extra cm. Pics attached.
    THE BIG BACKLASH TEST (this being the whole point of the exercise)
    Put a DTI on the bed and turned the handle, by hand. I could feel the stepper motor cogging and with the 2.5:1 reduction the slide should move .01mm per clunk, 0.0004".
    Well it didn't move that far when I sat there rocking it back and forth one clunk, but it did move a little bit so backlash is now <10 microns, not bad for 20 micron nuts
    I totally destroyed one of the stepper motors while trying to remove the old pulley. I was thinking to replace them anyway with some of these new fangled hybrids.
    Robin
ID:	355   Click image for larger version.
ID:	356   Click image for larger version.
    I have just sent the picture for the Z axis screw machining to Gary and ordered a girt lump of aluminium.
    The spindle doesn't like running at 5000 rpm which is top whack, 2500 rpm of the pulleys and 100Hz from the inverter, the bearings run hot. I would actually like twice that so I can run tiny ball end mills.
    The plan is a false spindle set inside a 3MT soft end arbor and a lay shaft with two timing belts. That way the false spindle with it's ER11 collet can turn at 9 times the main spindle speed.
    Give me something to do while I wait for the Z screw
ID:	360   Click image for larger version.
  1. Haighton Major
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2022, 02:17 PM
  2. WANTED: Conect Minor or Major CNC Milling Machine Wanted
    By stevy123 in forum Items Wanted
    Last Post: 24-08-2011, 10:35 AM
  3. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
  4. Warco Super Major Mill 3 month old
    By grimreaper in forum Milling Machines, Builds & Conversions
    Last Post: 18-07-2010, 02:50 PM
  5. NEW MEMBER: Warco super major mill
    By ste64 in forum New Member Introductions
    Last Post: 26-05-2010, 04:27 PM
