    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    Ok, so in the ideal world you keep power wiring and logic/control wiring seperate, however the world is far from ideal.
    I'm currently fitting servos to my latest purchase to replace the original stepper motors, and routing things seperately would be quite involved. The original setup used steppers with wires running in beside the limit and home switch wiring, so what's the chances of routing the servo power cables along with everything else causing any problems?
    All the control wiring is 24V, and the encoders are differential. Other than the encoders, it's only the home switches that are connected to the controller. The limit switches are only part of the e-stop circuit.
    Just keep things separated most you can and don't tie things together or try to stuff down cramped trunking and you shouldn't have any troubles.
    Obviously you'll need usual shielded cables and Star grounds etc which sure you'll have so I'd just get on with it and worry about it if/when happens.!
    This might answer some questions ?
    http://tisltd.com/wp-content/uploads/2012/04/EMC-2.pdf
  1. FOR SALE: Various Steppers, servos, drives for sale
    By Peter. in forum Items For Sale
    Last Post: 02-02-2014, 09:56 PM
  2. Big single phase servos and drivers
    Last Post: 04-09-2013, 01:18 AM
  3. Open Source Servos
    By D.C. in forum Open Source Designs & Plans
    Last Post: 07-03-2013, 07:29 PM
  4. Programmable logic controllers
    By cncezee in forum Motor Drivers & Controllers
    Last Post: 15-11-2010, 08:44 PM
  5. Mariss Freimanis Steppers vs Servos Advantages/Disadvantages of both
    By Lee Roberts in forum Stepper & Servo Motors
    Last Post: 02-10-2007, 09:08 AM
