Thread: Machine couriers,lathe
09-11-2013 #1
Afternoon
Are there any machine couriers on here or can recomend one i bought a lathe 250kg, L 1000mm W 700mm H 800mm needs to get it from brum to leicestershire and dumped in my front yard i can hopefully manage it from there.
i should have worried about it before buying but there you go.
What should i be looking to pay?Last edited by dazza; 09-11-2013 at 07:13 PM.
09-11-2013 #2
throw it on a pallet and use a courier.
Pallet Couriers UK Nationwide & European Pallet DistributionLast edited by i2i; 09-11-2013 at 10:13 PM.
10-11-2013 #3
National Pallets as per i2i's suggestion, or if whoever you bought it of is incapable of getting it on a pallet, stick it up on shiply and see what offers you get.
Given the relatively short distance, you might find somebody on shiply that's just as cheap, and it only takes 5 minutes to stick up a request.
04-04-2017 #4
Hi Deisel
If you still need to get your lathe shifted speak with these guys haulage services . They have real human beings on the other end of the phone and will try to put you in touch with a local haulier or 'owner driver'.
04-04-2017 #6
04-04-2017 #7
I've heard very good things of LandyLift, they offer a true rigger service rather than simply courier so you will know your machine has spent the entire journey the right way up and securely strapped down ;-)
04-04-2017 #8
04-04-2017 #9https://emvioeng.com
04-04-2017 #10Current Activity: Viewing Is a 600W AC servo better than a matching asyncrounous single phase AC motor?
Which is easier to machine on a manual lathe 12.9 or EN24 steel?
By newtoid1986 in forum Metalwork DiscussionReplies: 1Last Post: 18-09-2013, 07:20 PM -
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
