    H-Bot 3D Printer HB1 dry test No.22 - YouTube
    anyone done that yet?
    with the torch height from a cable
    yes, with dual shaft motors, with twin belts top and bottom or single?
    twin bar y axis with turn-buckles each end between them for tensioning.
    does anyone make a idler pulley mount that slots into 45mm t-slot ends
    would you use a single 25mm belt 2525mm long closed loop and get a table about 400mm square
    2525mm divided by 6 -= 420mm square so 600 by 220 or 500 by 320mm
    or would you d twin 15mm pulleys top and bottomso as to not stress the motor shafts so much
    COULD you in fact run 4 motors one in each corner
  1. 10' x 5' Plasma table design
    By Kerryfisher in forum Plasma Table Machines
    Last Post: 20-02-2013, 09:28 AM
  2. NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
    By AGB in forum New Member Introductions
    Last Post: 06-02-2013, 03:16 AM
  3. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  4. 3M x 2M Plasma table build
    By MonoNeuron in forum DIY Plasma Build Logs
    Last Post: 01-09-2009, 11:11 AM
  5. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
