Thread: Safe Z Speed
Page 1 of 3 123 LastLast
    dudz's Avatar
    Lives in Dunedin, New Zealand. Current Activity: Viewing Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    Using Mach3
    How do we speed up the X and Y axis in the safe Z moves ?
    In other words, A G'code is executed..... the Z axis has risen to move across the the next location but X and Y are slow until the Z has returned to the work on the next pass again which is then controlled by Feed rates.
    Are you using G1 rather than G0 for the moves at safe height?
    Sent from my iPad using Tapatalk
    dudz's Avatar
    Quote Originally Posted by JohnHaine View Post
    G0
    Isn't that dictated by what is produced in the G-code ?
    Is there a manual speed I can set ?
    dudz's Avatar
    Maybe something to do with "Lock rapid FRO to FEED FRO" ????
    Safe Z is used when homing and not controlled by G-code. G28.1 reference home can be in the g-code and this use's current feed rate so if your feedrate is low so will the homing.!
    Post the g-code file and will check it for you.
    dudz's Avatar
    Hi Jazz, Seems to be most if not All of my G codes. As soon as the Z axis retracts, to move the X and Y to the next point, its annoyingly slow.
    Code:
    ( Made using CamBam - CamBam CNC Software )
    ( clamp 5/18/2014 7:57:49 PM )
    ( T1 : 6.0 )
    ( T2 : 4.0 )
    G21 G90 G64 G40
    G0 Z50.0
    ( T1 : 6.0 )
    T1 M6
    ( 6mm outside )
    G17
    M3 S13000
    G0 X43.2958 Y31.0141
    G0 Z1.0
    G1 F50.0 Z0.0
    G3 F300.0 X25.4506 Y46.678 Z-0.418 I-43.1293 J-31.1383
    G1 X25.4546 Y48.7732 Z-0.4546
    G2 X51.654 Y13.246 Z-1.25 I-25.0606 J-45.9048
    G3 F600.0 X25.4506 Y46.678 I-51.4875 J-13.3702
    G2 X51.654 Y13.246 I-25.0606 J-45.9048
    G1 X54.0063 Y13.7222
    G2 X55.094 Y2.8684 I-53.6123 J-10.8538
    G2 X-26.956 Y-44.5032 I-54.7 J0.0
    G2 X-48.0966 Y-22.4448 I27.35 J47.3716
    G1 X-45.4594 Y-22.4498
    G3 X23.0478 Y45.2255 I45.6258 J22.3257
    G1 X23.0619 Y52.6504
    G2 X54.0063 Y13.7222 I-22.668 J-49.782
    G1 X56.3586 Y14.1985
    G2 X57.494 Y2.8684 I-55.9646 J-11.3301
    G2 X-28.156 Y-46.5817 I-57.1 J0.0
    G2 X-52.1555 Y-19.4692 I28.55 J49.4501
    G3 X-48.7676 Y-20.0436 I3.4076 J9.8208
    G1 X-43.9351 Y-20.0527
    G3 X20.645 Y43.7247 I44.1016 J19.9286
    G1 X20.6688 Y56.2476
    G2 X56.3586 Y14.1985 I-20.2748 J-53.3792
    G0 Z50.0
    G0 X-27.5626 Y47.0693
    G0 Z1.0
    G1 F50.0 Z0.0
    G2 F300.0 X-25.756 Y48.1615 Z-0.0369 I27.9565 J-44.2009
    G2 X-24.9362 Y48.6251 Z-0.0533 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-0.0856
    G3 X-46.8403 Y24.7774 Z-0.6354 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-0.6399
    G2 X-25.756 Y48.1615 Z-1.2012 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-1.2177 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-1.25
    G3 F600.0 X-46.8403 Y24.7774 I25.1062 J-46.8979
    G2 X-25.756 Y48.1615 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 I26.15 J-45.2931
    G1 X-22.5397 Y46.7691
    G1 X-22.5425 Y45.3121
    G3 X-45.3742 Y22.3746 I22.709 J-45.4363
    G1 X-48.7517 Y22.381
    G3 X-50.7666 Y22.2253 I-0.0243 J-12.7952
    G2 X-26.956 Y50.24 I51.1605 J-19.3569
    G2 X-22.5288 Y52.5337 I27.35 J-47.3716
    G1 X-20.1397 Y46.7646
    G1 X-20.1453 Y43.8022
    G3 X-43.8591 Y19.9717 I20.3118 J-43.9264
    G1 X-48.7562 Y19.981
    G3 X-54.6126 Y18.1878 I-0.0197 J-10.3952
    G2 X-28.156 Y52.3184 I55.0066 J-15.3194
    G2 X-20.1219 Y56.1554 I28.55 J-49.4501
    G1 X-17.7397 Y46.76
    G1 X-17.7483 Y42.2388
    G3 X-42.2896 Y17.5688 I17.9148 J-42.3629
    G1 X-48.7608 Y17.581
    G3 X-56.7711 Y9.5566 I-0.0152 J-7.9952
    G1 X-56.7357 Y-0.1222
    G1 X-56.7394 Y-2.076
    G3 X-56.7295 Y-2.4886 I7.9952 J-0.0152
    G1 X-56.7431 Y-9.6332
    G3 X-48.7631 Y-17.6436 I7.9952 J-0.0152
    G1 X-42.3565 Y-17.6557
    G3 X18.242 Y42.1704 I42.523 J17.5315
    G1 X18.2699 Y56.8415
    G3 X17.9531 Y59.7184 I-12.9952 J0.0247
    G2 X59.894 Y2.8684 I-17.5591 J-56.85
    G2 X-29.356 Y-48.6601 I-59.5 J0.0
    G2 Y54.3969 I29.75 J51.5285
    G2 X-17.4257 Y59.6373 I29.75 J-51.5285
    G3 X-17.7204 Y56.9099 I12.7004 J-2.7521
    G1 X-17.7397 Y46.76
    G1 X-15.3397 Y46.7554
    G1 X-15.3514 Y40.6157
    G3 X-40.6595 Y15.1657 I15.5179 J-40.7399
    G1 X-48.7653 Y15.181
    G3 X-54.3711 Y9.5654 I-0.0106 J-5.5952
    G1 X-54.3357 Y-0.1201
    G1 X-54.3394 Y-2.0806
    G3 X-54.3294 Y-2.4257 I5.5952 J-0.0106
    G1 X-54.3431 Y-9.6377
    G3 X-48.7585 Y-15.2436 I5.5952 J-0.0106
    G1 X-40.7173 Y-15.2588
    G3 X15.839 Y40.5565 I40.8838 J15.1347
    G1 X15.8699 Y56.8461
    G3 X13.6717 Y63.3276 I-10.5952 J0.0201
    G2 X62.294 Y2.8684 I-13.2778 J-60.4592
    G2 X-30.556 Y-50.7386 I-61.9 J0.0
    G2 Y56.4754 I30.95 J53.607
    G2 X-13.1882 Y63.2599 I30.95 J-53.607
    G3 X-15.3204 Y56.9053 I8.463 J-6.3747
    G0 Z50.0
    G0 X-63.4971 Y10.1087
    G0 Z1.0
    G1 F50.0 Z0.0
    G2 F300.0 X-31.756 Y58.5538 Z-1.0487 I63.8911 J-7.2404
    G2 X-21.3055 Y63.3963 Z-1.25 I32.15 J-55.6854
    G2 F600.0 X64.694 Y2.8684 I21.6995 J-60.5279
    G2 X-31.756 Y-52.817 I-64.3 J0.0
    G2 Y58.5538 I32.15 J55.6854
    G2 X-21.3055 Y63.3963 I32.15 J-55.6854
    G0 Z50.0
    G0 X30.7385 Y27.4945
    G0 Z1.0
    G1 F50.0 Z0.0
    G3 F300.0 X13.4406 Y38.8789 Z-0.3654 I-30.572 J-27.6187
    G1 X13.4747 Y56.8507 Z-0.6791
    G3 X5.2903 Y65.0662 Z-0.9039 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-1.0785
    G3 X-12.3578 Y59.8825 Z-1.25 I-0.0156 J-8.2
    G3 F600.0 X-12.9252 Y56.9008 I7.6326 J-2.9973
    G1 X-12.9594 Y38.929
    G3 X-38.9647 Y12.7672 I13.1259 J-39.0532
    G1 X-48.7699 Y12.7858
    G3 X-51.9759 Y9.5741 I-0.0061 J-3.2
    G1 X-51.9405 Y-0.1179
    G1 X-51.9442 Y-2.0851
    G3 X-51.934 Y-2.346 I3.2 J-0.0061
    G1 X-51.9479 Y-9.6423
    G3 X-48.754 Y-12.8484 I3.2 J-0.0061
    G1 X-39.0134 Y-12.8669
    G3 X13.4406 Y38.8789 I39.1799 J12.7427
    G3 X5.2903 Y65.0662 I-8.2 J0.0156
    G3 X-12.3578 Y59.8825 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G3 F300.0 X13.4406 Y38.8789 Z-1.6154 I-30.572 J-27.6187
    G1 X13.4747 Y56.8507 Z-1.9291
    G3 X5.2903 Y65.0662 Z-2.1539 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-2.3285
    G3 X-12.3578 Y59.8825 Z-2.5 I-0.0156 J-8.2
    G0 Z50.0
    G0 X-29.1094 Y46.0522
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G2 F300.0 X-25.756 Y48.1615 Z-1.3192 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-1.3356 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-1.3679
    G3 X-46.8403 Y24.7774 Z-1.9177 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-1.9222
    G2 X-25.756 Y48.1615 Z-2.4836 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-2.5 I26.15 J-45.2931
    G1 F600.0 X-24.9397 Y46.7737
    G3 X-46.8403 Y24.7774 I25.1062 J-46.8979
    G0 Z50.0
    G0 X-27.0729 Y42.7497
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G3 F300.0 X-45.3742 Y22.3746 Z-1.734 I27.2394 J-42.8738
    G1 X-48.7517 Y22.381 Z-1.793
    G3 X-50.7666 Y22.2253 Z-1.8283 I-0.0243 J-12.7952
    G2 X-26.956 Y50.24 Z-2.4828 I51.1605 J-19.3569
    G2 X-26.0986 Y50.7248 Z-2.5 I27.35 J-47.3716
    G2 F600.0 X-22.5288 Y52.5337 I26.4925 J-47.8564
    G2 X-26.0986 Y50.7248 I27.35 J-47.3716
    G0 Z50.0
    G0 X-35.5075 Y32.5785
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G3 F300.0 X-43.8591 Y19.9717 Z-1.515 I35.674 J-32.7027
    G1 X-48.7562 Y19.981 Z-1.6005
    G3 X-54.6126 Y18.1878 Z-1.709 I-0.0197 J-10.3952
    G2 X-28.156 Y52.3184 Z-2.4821 I55.0066 J-15.3194
    G2 X-27.2609 Y52.8245 Z-2.5 I28.55 J-49.4501
    G2 F600.0 X-20.1219 Y56.1554 I27.6549 J-49.9562
    G2 X-27.2609 Y52.8245 I28.55 J-49.4501
    G0 Z50.0
    G0 X40.6141 Y36.2993
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G2 F300.0 X51.654 Y13.246 Z-1.7007 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-2.4634 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-2.5
    G2 F600.0 X51.654 Y13.246 I-25.0606 J-45.9048
    G3 X25.4506 Y46.678 I-51.4875 J-13.3702
    G0 Z50.0
    G0 X50.7904 Y-4.2925
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G3 F300.0 X23.0478 Y45.2255 Z-2.3013 I-50.6239 J4.1683
    G1 X23.0619 Y52.6504 Z-2.4309
    G2 X26.6046 Y50.8798 Z-2.5 I-22.668 J-49.782
    G2 F600.0 X55.094 Y2.8684 I-26.2106 J-48.0114
    G2 X26.6046 Y50.8798 I-22.668 J-49.782
    G0 Z50.0
    G0 X48.4285 Y3.4635
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G3 F300.0 X20.645 Y43.7247 Z-2.1452 I-48.262 J-3.5877
    G1 X20.6688 Y56.2476 Z-2.3637
    G2 X27.7546 Y52.9863 Z-2.5 I-20.2748 J-53.3792
    G2 F600.0 X57.494 Y2.8684 I-27.3607 J-50.1179
    G2 X27.7546 Y52.9863 I-20.2748 J-53.3792
    G0 Z50.0
    G0 X44.7216 Y11.295
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G3 F300.0 X18.242 Y42.1704 Z-1.9854 I-44.5551 J-11.4191
    G1 X18.2699 Y56.8415 Z-2.2415
    G3 X17.9531 Y59.7184 Z-2.2921 I-12.9952 J0.0247
    G2 X28.9046 Y55.0928 Z-2.5 I-17.5591 J-56.85
    G2 F600.0 X59.894 Y2.8684 I-28.5107 J-52.2244
    G2 X28.9046 Y55.0928 I-17.5591 J-56.85
    G0 Z50.0
    G0 X38.4981 Y20.6418
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G3 F300.0 X15.839 Y40.5565 Z-1.7877 I-38.3316 J-20.766
    G1 X15.8699 Y56.8461 Z-2.072
    G3 X13.6717 Y63.3276 Z-2.1937 I-10.5952 J0.0201
    G2 X30.0546 Y57.1994 Z-2.5 I-13.2778 J-60.4592
    G2 F600.0 X62.294 Y2.8684 I-29.6607 J-54.331
    G2 X30.0546 Y57.1994 I-13.2778 J-60.4592
    G0 Z50.0
    G0 X-36.6527 Y55.4235
    G0 Z-0.25
    G1 F50.0 Z-1.25
    G2 F300.0 X-31.756 Y58.5538 Z-1.3515 I37.0466 J-52.5551
    G2 X31.2046 Y59.3059 Z-2.5 I32.15 J-55.6854
    G2 F600.0 X64.694 Y2.8684 I-30.8107 J-56.4375
    G2 X31.2046 Y59.3059 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-1.5
    G1 F50.0 Z-2.5
    G2 F300.0 X51.654 Y13.246 Z-2.9507 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-3.7134 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-3.75
    G1 X26.6046 Y50.8798
    G2 X55.094 Y2.8684 I-26.2106 J-48.0114
    G1 X27.7546 Y52.9863
    G2 X57.494 Y2.8684 I-27.3607 J-50.1179
    G0 Z50.0
    G0 Z-1.5
    G1 F50.0 Z-2.5
    G2 F300.0 X-25.756 Y48.1615 Z-2.5692 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-2.5856 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-2.6179
    G3 X-46.8403 Y24.7774 Z-3.1677 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-3.1722
    G2 X-25.756 Y48.1615 Z-3.7336 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-3.75 I26.15 J-45.2931
    G1 X-26.0986 Y50.7248
    G2 X-22.5288 Y52.5337 I26.4925 J-47.8564
    G1 X-27.2609 Y52.8245
    G2 X-20.1219 Y56.1554 I27.6549 J-49.9562
    G0 Z50.0
    G0 X-58.5374 Y-5.3381
    G0 Z-1.5
    G1 F50.0 Z-2.5
    G2 F300.0 X-29.356 Y54.3969 Z-3.7313 I58.9314 J8.2064
    G2 X-28.4233 Y54.9243 Z-3.75 I29.75 J-51.5285
    G2 F600.0 X-17.4257 Y59.6373 I28.8173 J-52.0559
    G2 X-28.4233 Y54.9243 I29.75 J-51.5285
    G0 Z50.0
    G0 X-61.246 Y-2.7999
    G0 Z-1.5
    G1 F50.0 Z-2.5
    G2 F300.0 X-30.556 Y56.4754 Z-3.7305 I61.6399 J5.6682
    G2 X-29.5857 Y57.024 Z-3.75 I30.95 J-53.607
    G2 F600.0 X-13.1882 Y63.2599 I29.9796 J-54.1556
    G2 X-29.5857 Y57.024 I30.95 J-53.607
    G0 Z50.0
    G0 X-63.8304 Y-0.2501
    G0 Z-1.5
    G1 F50.0 Z-2.5
    G2 F300.0 X-31.756 Y58.5538 Z-3.7298 I64.2243 J3.1185
    G2 X-30.7481 Y59.1237 Z-3.75 I32.15 J-55.6854
    G2 F600.0 X64.694 Y2.8684 I31.142 J-56.2553
    G2 X-30.7481 Y59.1237 I32.15 J-55.6854
    G0 Z50.0
    G0 X29.1038 Y29.2028
    G0 Z-1.5
    G1 F50.0 Z-2.5
    G3 F300.0 X13.4406 Y38.8789 Z-2.8241 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-3.1378
    G3 X5.2903 Y65.0662 Z-3.3626 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-3.5372
    G3 X-12.8951 Y57.588 Z-3.75 I-0.0156 J-8.2
    G3 F600.0 X-12.9252 Y56.9008 I8.1698 J-0.7028
    G3 X-12.8951 Y57.588 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-2.75
    G1 F50.0 Z-3.75
    G3 F300.0 X13.4406 Y38.8789 Z-4.0741 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-4.3878
    G3 X5.2903 Y65.0662 Z-4.6126 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-4.7872
    G3 X-12.8951 Y57.588 Z-5.0 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-2.75
    G1 F50.0 Z-3.75
    G2 F300.0 X-25.756 Y48.1615 Z-3.8192 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-3.8356 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-3.8679
    G3 X-46.8403 Y24.7774 Z-4.4177 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-4.4222
    G2 X-25.756 Y48.1615 Z-4.9836 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-5.0 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-2.75
    G1 F50.0 Z-3.75
    G2 F300.0 X51.654 Y13.246 Z-4.2007 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-4.9634 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-5.0
    G0 Z50.0
    G0 X44.7216 Y11.295
    G0 Z-2.75
    G1 F50.0 Z-3.75
    G3 F300.0 X18.242 Y42.1704 Z-4.4854 I-44.5551 J-11.4191
    G1 X18.2699 Y56.8415 Z-4.7415
    G3 X17.9531 Y59.7184 Z-4.7921 I-12.9952 J0.0247
    G2 X28.9046 Y55.0928 Z-5.0 I-17.5591 J-56.85
    G0 Z50.0
    G0 Z-2.75
    G1 F50.0 Z-3.75
    G3 F300.0 X15.839 Y40.5565 Z-4.2877 I-38.3316 J-20.766
    G1 X15.8699 Y56.8461 Z-4.572
    G3 X13.6717 Y63.3276 Z-4.6937 I-10.5952 J0.0201
    G2 X30.0546 Y57.1994 Z-5.0 I-13.2778 J-60.4592
    G0 Z50.0
    G0 Z-2.75
    G1 F50.0 Z-3.75
    G2 F300.0 X-31.756 Y58.5538 Z-3.8515 I37.0466 J-52.5551
    G2 X31.2046 Y59.3059 Z-5.0 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-4.0
    G1 F50.0 Z-5.0
    G2 F300.0 X51.654 Y13.246 Z-5.4507 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-6.2134 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-6.25
    G0 Z50.0
    G0 Z-4.0
    G1 F50.0 Z-5.0
    G2 F300.0 X-25.756 Y48.1615 Z-5.0692 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-5.0856 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-5.1179
    G3 X-46.8403 Y24.7774 Z-5.6677 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-5.6722
    G2 X-25.756 Y48.1615 Z-6.2336 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-6.25 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-4.0
    G1 F50.0 Z-5.0
    G2 F300.0 X-29.356 Y54.3969 Z-6.2313 I58.9314 J8.2064
    G2 X-28.4233 Y54.9243 Z-6.25 I29.75 J-51.5285
    G0 Z50.0
    G0 Z-4.0
    G1 F50.0 Z-5.0
    G2 F300.0 X-30.556 Y56.4754 Z-6.2305 I61.6399 J5.6682
    G2 X-29.5857 Y57.024 Z-6.25 I30.95 J-53.607
    G0 Z50.0
    G0 Z-4.0
    G1 F50.0 Z-5.0
    G2 F300.0 X-31.756 Y58.5538 Z-6.2298 I64.2243 J3.1185
    G2 X-30.7481 Y59.1237 Z-6.25 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-4.0
    G1 F50.0 Z-5.0
    G3 F300.0 X13.4406 Y38.8789 Z-5.3241 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-5.6378
    G3 X5.2903 Y65.0662 Z-5.8626 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-6.0372
    G3 X-12.8951 Y57.588 Z-6.25 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-5.25
    G1 F50.0 Z-6.25
    G3 F300.0 X13.4406 Y38.8789 Z-6.5741 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-6.8878
    G3 X5.2903 Y65.0662 Z-7.1126 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-7.2872
    G3 X-12.8951 Y57.588 Z-7.5 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-5.25
    G1 F50.0 Z-6.25
    G2 F300.0 X-25.756 Y48.1615 Z-6.3192 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-6.3356 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-6.3679
    G3 X-46.8403 Y24.7774 Z-6.9177 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-6.9222
    G2 X-25.756 Y48.1615 Z-7.4836 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-7.5 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-5.25
    G1 F50.0 Z-6.25
    G2 F300.0 X51.654 Y13.246 Z-6.7007 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-7.4634 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-7.5
    G0 Z50.0
    G0 X44.7216 Y11.295
    G0 Z-5.25
    G1 F50.0 Z-6.25
    G3 F300.0 X18.242 Y42.1704 Z-6.9854 I-44.5551 J-11.4191
    G1 X18.2699 Y56.8415 Z-7.2415
    G3 X17.9531 Y59.7184 Z-7.2921 I-12.9952 J0.0247
    G2 X28.9046 Y55.0928 Z-7.5 I-17.5591 J-56.85
    G0 Z50.0
    G0 Z-5.25
    G1 F50.0 Z-6.25
    G3 F300.0 X15.839 Y40.5565 Z-6.7877 I-38.3316 J-20.766
    G1 X15.8699 Y56.8461 Z-7.072
    G3 X13.6717 Y63.3276 Z-7.1937 I-10.5952 J0.0201
    G2 X30.0546 Y57.1994 Z-7.5 I-13.2778 J-60.4592
    G0 Z50.0
    G0 Z-5.25
    G1 F50.0 Z-6.25
    G2 F300.0 X-31.756 Y58.5538 Z-6.3515 I37.0466 J-52.5551
    G2 X31.2046 Y59.3059 Z-7.5 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-6.5
    G1 F50.0 Z-7.5
    G2 F300.0 X51.654 Y13.246 Z-7.9507 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-8.7134 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-8.75
    G0 Z50.0
    G0 Z-6.5
    G1 F50.0 Z-7.5
    G2 F300.0 X-25.756 Y48.1615 Z-7.5692 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-7.5856 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-7.6179
    G3 X-46.8403 Y24.7774 Z-8.1677 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-8.1722
    G2 X-25.756 Y48.1615 Z-8.7336 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-8.75 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-6.5
    G1 F50.0 Z-7.5
    G2 F300.0 X-29.356 Y54.3969 Z-8.7313 I58.9314 J8.2064
    G2 X-28.4233 Y54.9243 Z-8.75 I29.75 J-51.5285
    G0 Z50.0
    G0 Z-6.5
    G1 F50.0 Z-7.5
    G2 F300.0 X-30.556 Y56.4754 Z-8.7305 I61.6399 J5.6682
    G2 X-29.5857 Y57.024 Z-8.75 I30.95 J-53.607
    G0 Z50.0
    G0 Z-6.5
    G1 F50.0 Z-7.5
    G2 F300.0 X-31.756 Y58.5538 Z-8.7298 I64.2243 J3.1185
    G2 X-30.7481 Y59.1237 Z-8.75 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-6.5
    G1 F50.0 Z-7.5
    G3 F300.0 X13.4406 Y38.8789 Z-7.8241 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-8.1378
    G3 X5.2903 Y65.0662 Z-8.3626 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-8.5372
    G3 X-12.8951 Y57.588 Z-8.75 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-7.75
    G1 F50.0 Z-8.75
    G3 F300.0 X13.4406 Y38.8789 Z-9.0741 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-9.3878
    G3 X5.2903 Y65.0662 Z-9.6126 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-9.7872
    G3 X-12.8951 Y57.588 Z-10.0 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-7.75
    G1 F50.0 Z-8.75
    G2 F300.0 X-25.756 Y48.1615 Z-8.8192 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-8.8356 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-8.8679
    G3 X-46.8403 Y24.7774 Z-9.4177 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-9.4222
    G2 X-25.756 Y48.1615 Z-9.9836 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-10.0 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-7.75
    G1 F50.0 Z-8.75
    G2 F300.0 X51.654 Y13.246 Z-9.2007 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-9.9634 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-10.0
    G0 Z50.0
    G0 X44.7216 Y11.295
    G0 Z-7.75
    G1 F50.0 Z-8.75
    G3 F300.0 X18.242 Y42.1704 Z-9.4854 I-44.5551 J-11.4191
    G1 X18.2699 Y56.8415 Z-9.7415
    G3 X17.9531 Y59.7184 Z-9.7921 I-12.9952 J0.0247
    G2 X28.9046 Y55.0928 Z-10.0 I-17.5591 J-56.85
    G0 Z50.0
    G0 Z-7.75
    G1 F50.0 Z-8.75
    G3 F300.0 X15.839 Y40.5565 Z-9.2877 I-38.3316 J-20.766
    G1 X15.8699 Y56.8461 Z-9.572
    G3 X13.6717 Y63.3276 Z-9.6937 I-10.5952 J0.0201
    G2 X30.0546 Y57.1994 Z-10.0 I-13.2778 J-60.4592
    G0 Z50.0
    G0 Z-7.75
    G1 F50.0 Z-8.75
    G2 F300.0 X-31.756 Y58.5538 Z-8.8515 I37.0466 J-52.5551
    G2 X31.2046 Y59.3059 Z-10.0 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-9.0
    G1 F50.0 Z-10.0
    G2 F300.0 X51.654 Y13.246 Z-10.4507 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-11.2134 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-11.25
    G0 Z50.0
    G0 Z-9.0
    G1 F50.0 Z-10.0
    G2 F300.0 X-25.756 Y48.1615 Z-10.0692 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-10.0856 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-10.1179
    G3 X-46.8403 Y24.7774 Z-10.6677 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-10.6722
    G2 X-25.756 Y48.1615 Z-11.2336 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-11.25 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-9.0
    G1 F50.0 Z-10.0
    G2 F300.0 X-29.356 Y54.3969 Z-11.2313 I58.9314 J8.2064
    G2 X-28.4233 Y54.9243 Z-11.25 I29.75 J-51.5285
    G0 Z50.0
    G0 Z-9.0
    G1 F50.0 Z-10.0
    G2 F300.0 X-30.556 Y56.4754 Z-11.2305 I61.6399 J5.6682
    G2 X-29.5857 Y57.024 Z-11.25 I30.95 J-53.607
    G0 Z50.0
    G0 Z-9.0
    G1 F50.0 Z-10.0
    G2 F300.0 X-31.756 Y58.5538 Z-11.2298 I64.2243 J3.1185
    G2 X-30.7481 Y59.1237 Z-11.25 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-9.0
    G1 F50.0 Z-10.0
    G3 F300.0 X13.4406 Y38.8789 Z-10.3241 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-10.6378
    G3 X5.2903 Y65.0662 Z-10.8626 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-11.0372
    G3 X-12.8951 Y57.588 Z-11.25 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-10.25
    G1 F50.0 Z-11.25
    G3 F300.0 X13.4406 Y38.8789 Z-11.5741 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-11.8878
    G3 X5.2903 Y65.0662 Z-12.1126 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-12.2872
    G3 X-12.8951 Y57.588 Z-12.5 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-10.25
    G1 F50.0 Z-11.25
    G2 F300.0 X-25.756 Y48.1615 Z-11.3192 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-11.3356 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-11.3679
    G3 X-46.8403 Y24.7774 Z-11.9177 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-11.9222
    G2 X-25.756 Y48.1615 Z-12.4836 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-12.5 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-10.25
    G1 F50.0 Z-11.25
    G2 F300.0 X51.654 Y13.246 Z-11.7007 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-12.4634 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-12.5
    G0 Z50.0
    G0 X44.7216 Y11.295
    G0 Z-10.25
    G1 F50.0 Z-11.25
    G3 F300.0 X18.242 Y42.1704 Z-11.9854 I-44.5551 J-11.4191
    G1 X18.2699 Y56.8415 Z-12.2415
    G3 X17.9531 Y59.7184 Z-12.2921 I-12.9952 J0.0247
    G2 X28.9046 Y55.0928 Z-12.5 I-17.5591 J-56.85
    G0 Z50.0
    G0 Z-10.25
    G1 F50.0 Z-11.25
    G3 F300.0 X15.839 Y40.5565 Z-11.7877 I-38.3316 J-20.766
    G1 X15.8699 Y56.8461 Z-12.072
    G3 X13.6717 Y63.3276 Z-12.1937 I-10.5952 J0.0201
    G2 X30.0546 Y57.1994 Z-12.5 I-13.2778 J-60.4592
    G0 Z50.0
    G0 Z-10.25
    G1 F50.0 Z-11.25
    G2 F300.0 X-31.756 Y58.5538 Z-11.3515 I37.0466 J-52.5551
    G2 X31.2046 Y59.3059 Z-12.5 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-11.5
    G1 F50.0 Z-12.5
    G2 F300.0 X51.654 Y13.246 Z-12.9507 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-13.7134 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-13.75
    G0 Z50.0
    G0 Z-11.5
    G1 F50.0 Z-12.5
    G2 F300.0 X-25.756 Y48.1615 Z-12.5692 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-12.5856 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-12.6179
    G3 X-46.8403 Y24.7774 Z-13.1677 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-13.1722
    G2 X-25.756 Y48.1615 Z-13.7336 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-13.75 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-11.5
    G1 F50.0 Z-12.5
    G2 F300.0 X-29.356 Y54.3969 Z-13.7313 I58.9314 J8.2064
    G2 X-28.4233 Y54.9243 Z-13.75 I29.75 J-51.5285
    G0 Z50.0
    G0 Z-11.5
    G1 F50.0 Z-12.5
    G2 F300.0 X-30.556 Y56.4754 Z-13.7305 I61.6399 J5.6682
    G2 X-29.5857 Y57.024 Z-13.75 I30.95 J-53.607
    G0 Z50.0
    G0 Z-11.5
    G1 F50.0 Z-12.5
    G2 F300.0 X-31.756 Y58.5538 Z-13.7298 I64.2243 J3.1185
    G2 X-30.7481 Y59.1237 Z-13.75 I32.15 J-55.6854
    G0 Z50.0
    G0 Z-11.5
    G1 F50.0 Z-12.5
    G3 F300.0 X13.4406 Y38.8789 Z-12.8241 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-13.1378
    G3 X5.2903 Y65.0662 Z-13.3626 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-13.5372
    G3 X-12.8951 Y57.588 Z-13.75 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-12.75
    G1 F50.0 Z-13.75
    G3 F300.0 X13.4406 Y38.8789 Z-14.0741 I-28.9373 J-29.327
    G1 X13.4747 Y56.8507 Z-14.3878
    G3 X5.2903 Y65.0662 Z-14.6126 I-8.2 J0.0156
    G1 X-4.7097 Y65.0852 Z-14.7872
    G3 X-12.8951 Y57.588 Z-15.0 I-0.0156 J-8.2
    G0 Z50.0
    G0 Z-12.75
    G1 F50.0 Z-13.75
    G2 F300.0 X-25.756 Y48.1615 Z-13.8192 I29.5034 J-43.1838
    G2 X-24.9362 Y48.6251 Z-13.8356 I26.15 J-45.2931
    G1 X-24.9397 Y46.7737 Z-13.8679
    G3 X-46.8403 Y24.7774 Z-14.4177 I25.1062 J-46.8979
    G1 X-47.0957 Y24.7779 Z-14.4222
    G2 X-25.756 Y48.1615 Z-14.9836 I47.4896 J-21.9095
    G2 X-24.9362 Y48.6251 Z-15.0 I26.15 J-45.2931
    G0 Z50.0
    G0 Z-12.75
    G1 F50.0 Z-13.75
    G2 F300.0 X51.654 Y13.246 Z-14.2007 I-40.2202 J-33.4309
    G3 X25.4506 Y46.678 Z-14.9634 I-51.4875 J-13.3702
    G1 X25.4546 Y48.7732 Z-15.0
    G0 Z50.0
    G0 X44.7216 Y11.295
    G0 Z-12.75
    G1 F50.0 Z-13.75
    G3 F300.0 X18.242 Y42.1704 Z-14.4854 I-44.5551 J-11.4191
    G1 X18.2699 Y56.8415 Z-14.7415
    G3 X17.9531 Y59.7184 Z-14.7921 I-12.9952 J0.0247
    G2 X28.9046 Y55.0928 Z-15.0 I-17.5591 J-56.85
    G0 Z50.0
    G0 Z-12.75
    G1 F50.0 Z-13.75
    G3 F300.0 X15.839 Y40.5565 Z-14.2877 I-38.3316 J-20.766
    G1 X15.8699 Y56.8461 Z-14.572
    G3 X13.6717 Y63.3276 Z-14.6937 I-10.5952 J0.0201
    G2 X30.0546 Y57.1994 Z-15.0 I-13.2778 J-60.4592
    G0 Z50.0
    G0 Z-12.75
    G1 F50.0 Z-13.75
    G2 F300.0 X-31.756 Y58.5538 Z-13.8515 I37.0466 J-52.5551
    G2 X31.2046 Y59.3059 Z-15.0 I32.15 J-55.6854
    G0 Z50.0
    G0 X44.7675 Y28.8669
    G0 Z-14.0
    G1 F50.0 Z-15.0
    G3 F300.0 X25.4506 Y46.678 Z-15.4634 I-44.601 J-28.991
    G1 X25.4546 Y48.7732 Z-15.5
    G0 Z50.0
    G0 X-45.0578 Y28.7417
    G0 Z-14.0
    G1 F50.0 Z-15.0
    G2 F300.0 X-25.756 Y48.1615 Z-15.4836 I45.4517 J-25.8733
    G2 X-24.9362 Y48.6251 Z-15.5 I26.15 J-45.2931
    G0 Z50.0
    G0 X-49.252 Y35.6636
    G0 Z-14.0
    G1 F50.0 Z-15.0
    G2 F300.0 X-29.356 Y54.3969 Z-15.4813 I49.646 J-32.7952
    G2 X-28.4233 Y54.9243 Z-15.5 I29.75 J-51.5285
    G0 Z50.0
    G0 X-50.6087 Y37.9445
    G0 Z-14.0
    G1 F50.0 Z-15.0
    G2 F300.0 X-30.556 Y56.4754 Z-15.4805 I51.0027 J-35.0761
    G2 X-29.5857 Y57.024 Z-15.5 I30.95 J-53.607
    G0 Z50.0
    G0 X-51.949 Y40.2141
    G0 Z-14.0
    G1 F50.0 Z-15.0
    G2 F300.0 X-31.756 Y58.5538 Z-15.4798 I52.343 J-37.3457
    G2 X-30.7481 Y59.1237 Z-15.5 I32.15 J-55.6854
    G0 Z50.0
    G0 X11.0926 Y62.6448
    G0 Z-14.0
    G1 F50.0 Z-15.0
    G3 F300.0 X5.2903 Y65.0662 Z-15.1126 I-5.8179 J-5.7786
    G1 X-4.7097 Y65.0852 Z-15.2872
    G3 X-12.8951 Y57.588 Z-15.5 I-0.0156 J-8.2
    ( 6mm outside clean up )
    S13000
    G0 Z50.0
    G0 X52.1827 Y11.4807
    G0 Z16.5
    G1 F50.0 Z15.5
    G2 F300.0 X52.7939 Y6.1089 Z15.4056 I-51.7888 J-8.6123
    G3 X25.2504 Y46.5587 Z14.5177 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z14.4732
    G2 X52.7939 Y6.1089 Z13.5424 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z12.6545 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z12.61
    G2 X52.7939 Y6.1089 Z11.6792 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z10.7913 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z10.7468
    G2 X52.7939 Y6.1089 Z9.816 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z8.9281 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z8.8836
    G2 X52.7939 Y6.1089 Z7.9528 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z7.0649 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z7.0204
    G2 X52.7939 Y6.1089 Z6.0896 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z5.2017 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z5.1572
    G2 X52.7939 Y6.1089 Z4.2264 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z3.3385 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z3.294
    G2 X52.7939 Y6.1089 Z2.3632 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z1.4753 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z1.4308
    G2 X52.7939 Y6.1089 Z0.5 I-24.8613 J-46.2403
    G3 F600.0 X25.2504 Y46.5587 I-52.6274 J-6.2331
    G2 X52.7939 Y6.1089 I-24.8613 J-46.2403
    G1 X50.4105 Y5.8266
    G3 X22.8476 Y45.1024 I-50.244 J-5.9508
    G1 X22.8625 Y52.96
    G2 X55.294 Y2.8684 I-22.4686 J-50.0916
    G2 X-27.056 Y-44.6764 I-54.9 J0.0
    G2 X-48.4258 Y-22.2442 I27.45 J47.5448
    G1 X-45.3343 Y-22.2501
    G3 X50.4105 Y5.8266 I45.5008 J22.1259
    G1 X48.0272 Y5.5443
    G3 X20.4448 Y43.5973 I-47.8607 J-5.6685
    G1 X20.4693 Y56.5365
    G2 X57.694 Y2.8684 I-20.0754 J-53.6681
    G2 X-28.256 Y-46.7549 I-57.3 J0.0
    G2 X-52.519 Y-19.1205 I28.65 J49.6233
    G3 X-48.7673 Y-19.8436 I3.7711 J9.4721
    G1 X-43.8057 Y-19.853
    G3 X48.0272 Y5.5443 I43.9722 J19.7288
    G0 Z50.0
    G0 X-46.4827 Y25.0223
    G0 Z16.5
    G1 F50.0 Z15.5
    G3 F300.0 X-46.7199 Y24.5772 Z15.4912 I46.6492 J-25.1464
    G1 X-47.4069 Y24.5785 Z15.4792
    G2 X-25.856 Y48.3347 Z14.9102 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z14.8878 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z14.8475
    G3 X-46.7199 Y24.5772 Z14.2956 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z14.2836
    G2 X-25.856 Y48.3347 Z13.7146 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z13.6922 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z13.6519
    G3 X-46.7199 Y24.5772 Z13.0999 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z13.088
    G2 X-25.856 Y48.3347 Z12.519 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z12.4966 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z12.4562
    G3 X-46.7199 Y24.5772 Z11.9043 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z11.8923
    G2 X-25.856 Y48.3347 Z11.3234 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z11.3009 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z11.2606
    G3 X-46.7199 Y24.5772 Z10.7087 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z10.6967
    G2 X-25.856 Y48.3347 Z10.1277 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z10.1053 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z10.065
    G3 X-46.7199 Y24.5772 Z9.5131 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z9.5011
    G2 X-25.856 Y48.3347 Z8.9321 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z8.9097 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z8.8694
    G3 X-46.7199 Y24.5772 Z8.3174 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z8.3055
    G2 X-25.856 Y48.3347 Z7.7365 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z7.7141 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z7.6737
    G3 X-46.7199 Y24.5772 Z7.1218 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z7.1098
    G2 X-25.856 Y48.3347 Z6.5409 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z6.5184 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z6.4781
    G3 X-46.7199 Y24.5772 Z5.9262 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z5.9142
    G2 X-25.856 Y48.3347 Z5.3452 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z5.3228 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z5.2825
    G3 X-46.7199 Y24.5772 Z4.7306 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z4.7186
    G2 X-25.856 Y48.3347 Z4.1496 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z4.1272 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z4.0869
    G3 X-46.7199 Y24.5772 Z3.535 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z3.523
    G2 X-25.856 Y48.3347 Z2.954 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z2.9316 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z2.8912
    G3 X-46.7199 Y24.5772 Z2.3393 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z2.3273
    G2 X-25.856 Y48.3347 Z1.7584 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z1.7359 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z1.6956
    G3 X-46.7199 Y24.5772 Z1.1437 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z1.1317
    G2 X-25.856 Y48.3347 Z0.5627 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z0.5403 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z0.5
    G3 F600.0 X-46.7199 Y24.5772 I24.9064 J-46.7778
    G2 X-25.856 Y48.3347 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 I26.25 J-45.4663
    G1 X-23.612 Y44.5352
    G3 X-45.2499 Y22.1744 I23.7785 J-44.6594
    G1 X-48.752 Y22.181
    G3 X-51.0761 Y21.9692 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 I27.45 J-47.5448
    G1 X-22.3427 Y45.1882
    G3 X-23.612 Y44.5352 I22.5092 J-45.3124
    G1 X-22.484 Y42.4168
    G3 X-43.7304 Y19.7715 I22.6505 J-42.5409
    G1 X-48.7566 Y19.781
    G3 X-54.9544 Y17.6956 I-0.0194 J-10.1952
    G2 X-28.256 Y52.4916 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 I28.65 J-49.6233
    G1 X-19.9456 Y43.674
    G3 X-22.484 Y42.4168 I20.1121 J-43.7982
    G1 X-21.3561 Y40.2983
    G3 X-42.1562 Y17.3685 I21.5226 J-40.4225
    G1 X-48.7611 Y17.381
    G3 X-56.5711 Y9.5573 I-0.0148 J-7.7952
    G1 X-56.5357 Y-0.122
    G1 X-56.5394 Y-2.0764
    G3 X-56.5295 Y-2.4838 I7.7952 J-0.0148
    G1 X-56.5431 Y-9.6336
    G3 X-48.7627 Y-17.4436 I7.7952 J-0.0148
    G1 X-42.2223 Y-17.456
    G3 X18.0418 Y42.0383 I42.3888 J17.3318
    G1 X18.0699 Y56.8419
    G3 X17.6772 Y60.0119 I-12.7952 J0.0243
    G2 X60.094 Y2.8684 I-17.2833 J-57.1435
    G2 X-29.456 Y-48.8333 I-59.7 J0.0
    G2 Y54.5701 I29.85 J51.7017
    G2 X-17.1525 Y59.9316 I29.85 J-51.7017
    G3 X-17.5204 Y56.9095 I12.4273 J-3.0464
    G1 X-17.5485 Y42.1059
    G3 X-21.3561 Y40.2983 I17.715 J-42.2301
    G1 X-20.2282 Y38.1799
    G3 X-40.5207 Y14.9654 I20.3947 J-38.3041
    G1 X-48.7657 Y14.981
    G3 X-54.1711 Y9.5661 I-0.0102 J-5.3952
    G1 X-54.1357 Y-0.1199
    G1 X-54.1394 Y-2.081
    G3 X-54.1294 Y-2.4198 I5.3952 J-0.0102
    G1 X-54.1431 Y-9.6381
    G3 X-48.7581 Y-15.0436 I5.3952 J-0.0102
    G1 X-40.5777 Y-15.0591
    G3 X15.6387 Y40.4191 I40.7442 J14.9349
    G1 X15.6699 Y56.8465
    G3 X13.1577 Y63.6425 I-10.3952 J0.0197
    G2 X62.494 Y2.8684 I-12.7638 J-60.7741
    G2 X-30.656 Y-50.9118 I-62.1 J0.0
    G2 Y56.6486 I31.05 J53.7802
    G2 X-12.6806 Y63.5764 I31.05 J-53.7802
    G3 X-15.1204 Y56.905 I7.9554 J-6.6912
    G1 X-15.1516 Y40.4775
    G3 X-20.2282 Y38.1799 I15.3181 J-40.6017
    G0 Z50.0
    G0 X-61.498 Y21.0243
    G0 Z16.5
    G1 F50.0 Z15.5
    G2 F300.0 X-32.1337 Y58.5658 Z14.6479 I61.8919 J-18.156
    G2 X-31.856 Y58.727 Z14.6423 I32.5276 J-55.6974
    G2 X64.894 Y2.8684 Z12.2843 I32.25 J-55.8586
    G2 X-31.856 Y-52.9903 Z9.9263 I-64.5 J0.0
    G2 X-32.1337 Y58.5658 Z7.5739 I32.25 J55.8586
    G2 X-31.856 Y58.727 Z7.5683 I32.5276 J-55.6974
    G2 X64.894 Y2.8684 Z5.2104 I32.25 J-55.8586
    G2 X-31.856 Y-52.9903 Z2.8524 I-64.5 J0.0
    G2 X-32.1337 Y58.5658 Z0.5 I32.25 J55.8586
    G2 F600.0 X-31.856 Y58.727 I32.5276 J-55.6974
    G2 X64.894 Y2.8684 I32.25 J-55.8586
    G2 X-31.856 Y-52.9903 I-64.5 J0.0
    G2 X-32.1337 Y58.5658 I32.25 J55.8586
    G0 Z50.0
    G0 X-33.9787 Y-22.8201
    G0 Z16.5
    G1 F50.0 Z15.5
    G3 F300.0 X13.2403 Y38.7355 Z12.7796 I34.1452 J22.6959
    G1 X13.2747 Y56.851 Z12.4634
    G3 X5.2899 Y64.8662 Z12.2441 I-8.0 J0.0152
    G1 X-4.7101 Y64.8852 Z12.0695
    G3 X-12.7103 Y57.3748 Z11.8585 I-0.0152 J-8.0
    G3 X-12.7252 Y56.9004 Z11.8502 I7.985 J-0.4896
    G1 X-12.7596 Y38.7849 Z11.534
    G3 X-38.8199 Y12.567 Z10.8646 I12.9261 J-38.9091
    G1 X-48.7703 Y12.5858 Z10.6909
    G3 X-51.7759 Y9.5749 Z10.6084 I-0.0057 J-3.0
    G1 X-51.7405 Y-0.1178 Z10.4392
    G1 X-51.7442 Y-2.0855 Z10.4048
    G3 X-51.734 Y-2.3381 Z10.4004 I3.0 J-0.0057
    G1 X-51.7479 Y-9.6427 Z10.2729
    G3 X-48.7536 Y-12.6484 Z10.1906 I3.0 J-0.0057
    G1 X-38.8678 Y-12.6671 Z10.0181
    G3 X13.2403 Y38.7355 Z7.1004 I39.0343 J12.543
    G1 X13.2747 Y56.851 Z6.7842
    G3 X5.2899 Y64.8662 Z6.5648 I-8.0 J0.0152
    G1 X-4.7101 Y64.8852 Z6.3903
    G3 X-12.7103 Y57.3748 Z6.1792 I-0.0152 J-8.0
    G3 X-12.7252 Y56.9004 Z6.1709 I7.985 J-0.4896
    G1 X-12.7596 Y38.7849 Z5.8547
    G3 X-38.8199 Y12.567 Z5.1854 I12.9261 J-38.9091
    G1 X-48.7703 Y12.5858 Z5.0117
    G3 X-51.7759 Y9.5749 Z4.9291 I-0.0057 J-3.0
    G1 X-51.7405 Y-0.1178 Z4.7599
    G1 X-51.7442 Y-2.0855 Z4.7256
    G3 X-51.734 Y-2.3381 Z4.7212 I3.0 J-0.0057
    G1 X-51.7479 Y-9.6427 Z4.5937
    G3 X-48.7536 Y-12.6484 Z4.5114 I3.0 J-0.0057
    G1 X-38.8678 Y-12.6671 Z4.3389
    G3 X13.2403 Y38.7355 Z1.4212 I39.0343 J12.543
    G1 X13.2747 Y56.851 Z1.105
    G3 X5.2899 Y64.8662 Z0.8856 I-8.0 J0.0152
    G1 X-4.7101 Y64.8852 Z0.7111
    G3 X-12.7103 Y57.3748 Z0.5 I-0.0152 J-8.0
    G3 F600.0 X-12.7252 Y56.9004 I7.985 J-0.4896
    G3 X-38.8199 Y12.567 I12.9261 J-38.9091
    G3 X-51.7759 Y9.5749 I-0.0057 J-3.0
    G3 X-51.734 Y-2.3381 I3.0 J-0.0057
    G3 X-48.7536 Y-12.6484 I3.0 J-0.0057
    G3 X13.2403 Y38.7355 I39.0343 J12.543
    G1 X13.2747 Y56.851
    G3 X5.2899 Y64.8662 I-8.0 J0.0152
    G3 X-12.7103 Y57.3748 I-0.0152 J-8.0
    G0 Z50.0
    G0 Z1.5
    G1 F50.0 Z0.5
    G3 F300.0 X13.2403 Y38.7355 Z-2.2204 I34.1452 J22.6959
    G1 X13.2747 Y56.851 Z-2.5366
    G3 X5.2899 Y64.8662 Z-2.7559 I-8.0 J0.0152
    G1 X-4.7101 Y64.8852 Z-2.9305
    G3 X-12.7103 Y57.3748 Z-3.1415 I-0.0152 J-8.0
    G3 X-12.7252 Y56.9004 Z-3.1498 I7.985 J-0.4896
    G1 X-12.7596 Y38.7849 Z-3.466
    G3 X-38.8199 Y12.567 Z-4.1354 I12.9261 J-38.9091
    G1 X-48.7703 Y12.5858 Z-4.3091
    G3 X-51.7759 Y9.5749 Z-4.3916 I-0.0057 J-3.0
    G1 X-51.7405 Y-0.1178 Z-4.5608
    G1 X-51.7442 Y-2.0855 Z-4.5952
    G3 X-51.734 Y-2.3381 Z-4.5996 I3.0 J-0.0057
    G1 X-51.7479 Y-9.6427 Z-4.7271
    G3 X-48.7536 Y-12.6484 Z-4.8094 I3.0 J-0.0057
    G1 X-38.8678 Y-12.6671 Z-4.9819
    G3 X13.2403 Y38.7355 Z-7.8996 I39.0343 J12.543
    G1 X13.2747 Y56.851 Z-8.2158
    G3 X5.2899 Y64.8662 Z-8.4352 I-8.0 J0.0152
    G1 X-4.7101 Y64.8852 Z-8.6097
    G3 X-12.7103 Y57.3748 Z-8.8208 I-0.0152 J-8.0
    G3 X-12.7252 Y56.9004 Z-8.8291 I7.985 J-0.4896
    G1 X-12.7596 Y38.7849 Z-9.1453
    G3 X-38.8199 Y12.567 Z-9.8146 I12.9261 J-38.9091
    G1 X-48.7703 Y12.5858 Z-9.9883
    G3 X-51.7759 Y9.5749 Z-10.0709 I-0.0057 J-3.0
    G1 X-51.7405 Y-0.1178 Z-10.2401
    G1 X-51.7442 Y-2.0855 Z-10.2744
    G3 X-51.734 Y-2.3381 Z-10.2788 I3.0 J-0.0057
    G1 X-51.7479 Y-9.6427 Z-10.4063
    G3 X-48.7536 Y-12.6484 Z-10.4886 I3.0 J-0.0057
    G1 X-38.8678 Y-12.6671 Z-10.6611
    G3 X13.2403 Y38.7355 Z-13.5788 I39.0343 J12.543
    G1 X13.2747 Y56.851 Z-13.895
    G3 X5.2899 Y64.8662 Z-14.1144 I-8.0 J0.0152
    G1 X-4.7101 Y64.8852 Z-14.2889
    G3 X-12.7103 Y57.3748 Z-14.5 I-0.0152 J-8.0
    G1 X13.2747 Y56.851
    G0 Z50.0
    G0 X-45.3427 Y27.031
    G0 Z1.5
    G1 F50.0 Z0.5
    G3 F300.0 X-46.7199 Y24.5772 Z0.4509 I45.5092 J-27.1552
    G1 X-47.4069 Y24.5785 Z0.4389
    G2 X-25.856 Y48.3347 Z-0.1301 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-0.1525 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-0.1928
    G3 X-46.7199 Y24.5772 Z-0.7447 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-0.7567
    G2 X-25.856 Y48.3347 Z-1.3257 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-1.3481 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-1.3884
    G3 X-46.7199 Y24.5772 Z-1.9404 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-1.9524
    G2 X-25.856 Y48.3347 Z-2.5213 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-2.5438 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-2.5841
    G3 X-46.7199 Y24.5772 Z-3.136 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-3.148
    G2 X-25.856 Y48.3347 Z-3.717 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-3.7394 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-3.7797
    G3 X-46.7199 Y24.5772 Z-4.3316 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-4.3436
    G2 X-25.856 Y48.3347 Z-4.9126 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-4.935 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-4.9753
    G3 X-46.7199 Y24.5772 Z-5.5272 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-5.5392
    G2 X-25.856 Y48.3347 Z-6.1082 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-6.1306 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-6.1709
    G3 X-46.7199 Y24.5772 Z-6.7229 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-6.7349
    G2 X-25.856 Y48.3347 Z-7.3038 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-7.3263 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-7.3666
    G3 X-46.7199 Y24.5772 Z-7.9185 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-7.9305
    G2 X-25.856 Y48.3347 Z-8.4994 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-8.5219 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-8.5622
    G3 X-46.7199 Y24.5772 Z-9.1141 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-9.1261
    G2 X-25.856 Y48.3347 Z-9.6951 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-9.7175 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-9.7578
    G3 X-46.7199 Y24.5772 Z-10.3097 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-10.3217
    G2 X-25.856 Y48.3347 Z-10.8907 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-10.9131 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-10.9534
    G3 X-46.7199 Y24.5772 Z-11.5054 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-11.5174
    G2 X-25.856 Y48.3347 Z-12.0863 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-12.1088 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-12.1491
    G3 X-46.7199 Y24.5772 Z-12.701 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-12.713
    G2 X-25.856 Y48.3347 Z-13.2819 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-13.3044 I26.25 J-45.4663
    G1 X-24.7399 Y46.6536 Z-13.3447
    G3 X-46.7199 Y24.5772 Z-13.8966 I24.9064 J-46.7778
    G1 X-47.4069 Y24.5785 Z-13.9086
    G2 X-25.856 Y48.3347 Z-14.4776 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-14.5 I26.25 J-45.4663
    G1 F600.0 X-24.7399 Y46.6536
    G3 X-46.7199 Y24.5772 I24.9064 J-46.7778
    G0 Z50.0
    G0 X-47.6111 Y22.1789
    G0 Z1.5
    G1 F50.0 Z0.5
    G1 F300.0 X-48.752 Y22.181 Z0.4801
    G3 X-51.0761 Y21.9692 Z0.4393 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-0.2237 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-0.3165 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-0.3844
    G1 X-22.3427 Y45.1882 Z-0.4502
    G3 X-45.2499 Y22.1744 Z-1.0272 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-1.0883
    G3 X-51.0761 Y21.9692 Z-1.1291 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-1.7921 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-1.8849 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-1.9528
    G1 X-22.3427 Y45.1882 Z-2.0186
    G3 X-45.2499 Y22.1744 Z-2.5956 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-2.6567
    G3 X-51.0761 Y21.9692 Z-2.6975 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-3.3605 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-3.4533 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-3.5212
    G1 X-22.3427 Y45.1882 Z-3.587
    G3 X-45.2499 Y22.1744 Z-4.164 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-4.2251
    G3 X-51.0761 Y21.9692 Z-4.2659 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-4.9289 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-5.0217 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-5.0896
    G1 X-22.3427 Y45.1882 Z-5.1554
    G3 X-45.2499 Y22.1744 Z-5.7324 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-5.7935
    G3 X-51.0761 Y21.9692 Z-5.8343 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-6.4973 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-6.5901 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-6.658
    G1 X-22.3427 Y45.1882 Z-6.7238
    G3 X-45.2499 Y22.1744 Z-7.3008 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-7.3619
    G3 X-51.0761 Y21.9692 Z-7.4027 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-8.0657 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-8.1585 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-8.2264
    G1 X-22.3427 Y45.1882 Z-8.2922
    G3 X-45.2499 Y22.1744 Z-8.8692 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-8.9303
    G3 X-51.0761 Y21.9692 Z-8.9711 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-9.6341 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-9.727 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-9.7948
    G1 X-22.3427 Y45.1882 Z-9.8606
    G3 X-45.2499 Y22.1744 Z-10.4376 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-10.4987
    G3 X-51.0761 Y21.9692 Z-10.5395 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-11.2025 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-11.2954 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-11.3632
    G1 X-22.3427 Y45.1882 Z-11.429
    G3 X-45.2499 Y22.1744 Z-12.006 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-12.0671
    G3 X-51.0761 Y21.9692 Z-12.1079 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-12.7709 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-12.8638 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-12.9316
    G1 X-22.3427 Y45.1882 Z-12.9974
    G3 X-45.2499 Y22.1744 Z-13.5744 I22.5092 J-45.3124
    G1 X-48.752 Y22.181 Z-13.6355
    G3 X-51.0761 Y21.9692 Z-13.6763 I-0.0239 J-12.5952
    G2 X-27.056 Y50.4132 Z-14.3393 I51.4701 J-19.1009
    G2 X-22.3282 Y52.8455 Z-14.4322 I27.45 J-47.5448
    G1 X-22.3355 Y48.9589 Z-14.5
    G1 F600.0 X-22.3427 Y45.1882
    G3 X-45.2499 Y22.1744 I22.5092 J-45.3124
    G1 X-48.752 Y22.181
    G0 Z50.0
    G0 X-49.8168 Y19.7278
    G0 Z1.5
    G1 F50.0 Z0.5
    G3 F300.0 X-54.9544 Y17.6956 Z0.4023 I1.0409 J-10.1419
    G2 X-28.256 Y52.4916 Z-0.3832 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 Z-0.5445 I28.65 J-49.6233
    G1 X-19.9355 Y48.9544 Z-0.6752
    G1 X-19.9456 Y43.674 Z-0.7674
    G3 X-43.7304 Y19.7715 Z-1.3687 I20.1121 J-43.7982
    G1 X-48.7566 Y19.781 Z-1.4564
    G3 X-54.9544 Y17.6956 Z-1.5726 I-0.0194 J-10.1952
    G2 X-28.256 Y52.4916 Z-2.3582 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 Z-2.5194 I28.65 J-49.6233
    G1 X-19.9355 Y48.9544 Z-2.6502
    G1 X-19.9456 Y43.674 Z-2.7424
    G3 X-43.7304 Y19.7715 Z-3.3437 I20.1121 J-43.7982
    G1 X-48.7566 Y19.781 Z-3.4314
    G3 X-54.9544 Y17.6956 Z-3.5476 I-0.0194 J-10.1952
    G2 X-28.256 Y52.4916 Z-4.3332 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 Z-4.4944 I28.65 J-49.6233
    G1 X-19.9355 Y48.9544 Z-4.6252
    G1 X-19.9456 Y43.674 Z-4.7173
    G3 X-43.7304 Y19.7715 Z-5.3186 I20.1121 J-43.7982
    G1 X-48.7566 Y19.781 Z-5.4064
    G3 X-54.9544 Y17.6956 Z-5.5226 I-0.0194 J-10.1952
    G2 X-28.256 Y52.4916 Z-6.3082 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 Z-6.4694 I28.65 J-49.6233
    G1 X-19.9355 Y48.9544 Z-6.6001
    G1 X-19.9456 Y43.674 Z-6.6923
    G3 X-43.7304 Y19.7715 Z-7.2936 I20.1121 J-43.7982
    G1 X-48.7566 Y19.781 Z-7.3813
    G3 X-54.9544 Y17.6956 Z-7.4975 I-0.0194 J-10.1952
    G2 X-28.256 Y52.4916 Z-8.2831 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 Z-8.4443 I28.65 J-49.6233
    G1 X-19.9355 Y48.9544 Z-8.5751
    G1 X-19.9456 Y43.674 Z-8.6673
    G3 X-43.7304 Y19.7715 Z-9.2686 I20.1121 J-43.7982
    G1 X-48.7566 Y19.781 Z-9.3563
    G3 X-54.9544 Y17.6956 Z-9.4725 I-0.0194 J-10.1952
    G2 X-28.256 Y52.4916 Z-10.2581 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 Z-10.4193 I28.65 J-49.6233
    G1 X-19.9355 Y48.9544 Z-10.5501
    G1 X-19.9456 Y43.674 Z-10.6422
    G3 X-43.7304 Y19.7715 Z-11.2435 I20.1121 J-43.7982
    G1 X-48.7566 Y19.781 Z-11.3313
    G3 X-54.9544 Y17.6956 Z-11.4475 I-0.0194 J-10.1952
    G2 X-28.256 Y52.4916 Z-12.2331 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 Z-12.3943 I28.65 J-49.6233
    G1 X-19.9355 Y48.9544 Z-12.525
    G1 X-19.9456 Y43.674 Z-12.6172
    G3 X-43.7304 Y19.7715 Z-13.2185 I20.1121 J-43.7982
    G1 X-48.7566 Y19.781 Z-13.3062
    G3 X-54.9544 Y17.6956 Z-13.4224 I-0.0194 J-10.1952
    G2 X-28.256 Y52.4916 Z-14.208 I55.3484 J-14.8273
    G2 X-19.9213 Y56.4462 Z-14.3692 I28.65 J-49.6233
    G1 X-19.9355 Y48.9544 Z-14.5
    G1 F600.0 X-19.9456 Y43.674
    G3 X-43.7304 Y19.7715 I20.1121 J-43.7982
    G0 Z50.0
    G0 X27.9358 Y45.0129
    G0 Z1.5
    G1 F50.0 Z0.5
    G3 F300.0 X25.2504 Y46.5587 Z0.4459 I-27.7693 J-45.1371
    G1 X25.2548 Y48.8686 Z0.4056
    G1 X25.2552 Y49.1087 Z0.4014
    G2 X52.7939 Y6.1089 Z-0.5294 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z-1.4173 I-52.6274 J-6.2331
    G1 X25.2548 Y48.8686 Z-1.4576
    G1 X25.2552 Y49.1087 Z-1.4618
    G2 X52.7939 Y6.1089 Z-2.3926 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z-3.2805 I-52.6274 J-6.2331
    G1 X25.2548 Y48.8686 Z-3.3208
    G1 X25.2552 Y49.1087 Z-3.325
    G2 X52.7939 Y6.1089 Z-4.2558 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z-5.1437 I-52.6274 J-6.2331
    G1 X25.2548 Y48.8686 Z-5.184
    G1 X25.2552 Y49.1087 Z-5.1882
    G2 X52.7939 Y6.1089 Z-6.119 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z-7.0069 I-52.6274 J-6.2331
    G1 X25.2548 Y48.8686 Z-7.0472
    G1 X25.2552 Y49.1087 Z-7.0514
    G2 X52.7939 Y6.1089 Z-7.9822 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z-8.8701 I-52.6274 J-6.2331
    G1 X25.2548 Y48.8686 Z-8.9104
    G1 X25.2552 Y49.1087 Z-8.9146
    G2 X52.7939 Y6.1089 Z-9.8454 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z-10.7333 I-52.6274 J-6.2331
    G1 X25.2548 Y48.8686 Z-10.7736
    G1 X25.2552 Y49.1087 Z-10.7778
    G2 X52.7939 Y6.1089 Z-11.7086 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z-12.5965 I-52.6274 J-6.2331
    G1 X25.2548 Y48.8686 Z-12.6368
    G1 X25.2552 Y49.1087 Z-12.641
    G2 X52.7939 Y6.1089 Z-13.5718 I-24.8613 J-46.2403
    G3 X25.2504 Y46.5587 Z-14.4597 I-52.6274 J-6.2331
    G1 X25.2548 Y48.8686 Z-14.5
    G1 F600.0 X25.2552 Y49.1087
    G3 X25.2504 Y46.5587 I-52.6274 J-6.2331
    G0 Z50.0
    G0 X44.5935 Y24.0856
    G0 Z1.5
    G1 F50.0 Z0.5
    G3 F300.0 X22.8476 Y45.1024 Z-0.0361 I-44.427 J-24.2097
    G1 X22.8548 Y48.8731 Z-0.1019
    G1 X22.8625 Y52.96 Z-0.1732
    G2 X55.294 Y2.8684 Z-1.2744 I-22.4686 J-50.0916
    G2 X-27.056 Y-44.6764 Z-3.2815 I-54.9 J0.0
    G2 X-48.4258 Y-22.2442 Z-3.8297 I27.45 J47.5448
    G1 X-45.3343 Y-22.2501 Z-3.8837
    G3 X22.8476 Y45.1024 Z-7.2351 I45.5008 J22.1259
    G1 X22.8548 Y48.8731 Z-7.3009
    G1 X22.8625 Y52.96 Z-7.3723
    G2 X55.294 Y2.8684 Z-8.4735 I-22.4686 J-50.0916
    G2 X-27.056 Y-44.6764 Z-10.4805 I-54.9 J0.0
    G2 X-48.4258 Y-22.2442 Z-11.0288 I27.45 J47.5448
    G1 X-45.3343 Y-22.2501 Z-11.0827
    G3 X22.8476 Y45.1024 Z-14.4342 I45.5008 J22.1259
    G1 X22.8548 Y48.8731 Z-14.5
    G1 F600.0 X22.8625 Y52.96
    G3 X22.8476 Y45.1024 I45.5008 J22.1259
    G0 Z50.0
    G0 X22.4042 Y55.7725
    G0 Z1.5
    G1 F50.0 Z0.5
    G2 F300.0 X57.694 Y2.8684 Z-0.6767 I-22.0102 J-52.9041
    G2 X-28.256 Y-46.7549 Z-2.7715 I-57.3 J0.0
    G2 X-52.519 Y-19.1205 Z-3.425 I28.65 J49.6233
    G3 X-48.7673 Y-19.8436 Z-3.4921 I3.7711 J9.4721
    G1 X-43.8057 Y-19.853 Z-3.5787
    G3 X20.4448 Y43.5973 Z-6.8228 I43.9722 J19.7288
    G1 X20.4548 Y48.8777 Z-6.915
    G1 X20.4693 Y56.5365 Z-7.0487
    G2 X57.694 Y2.8684 Z-8.2617 I-20.0754 J-53.6681
    G2 X-28.256 Y-46.7549 Z-10.3565 I-57.3 J0.0
    G2 X-52.519 Y-19.1205 Z-11.01 I28.65 J49.6233
    G3 X-48.7673 Y-19.8436 Z-11.0771 I3.7711 J9.4721
    G1 X-43.8057 Y-19.853 Z-11.1637
    G3 X20.4448 Y43.5973 Z-14.4078 I43.9722 J19.7288
    G1 X20.4548 Y48.8777 Z-14.5
    G1 F600.0 X20.4693 Y56.5365
    G3 X20.4448 Y43.5973 I43.9722 J19.7288
    G0 Z50.0
    G0 X-56.5315 Y-3.5362
    G0 Z1.5
    G1 F50.0 Z0.5
    G1 F300.0 X-56.5431 Y-9.6336 Z0.3936
    G3 X-48.7627 Y-17.4436 Z0.1798 I7.7952 J-0.0148
    G1 X-42.2223 Y-17.456 Z0.0657
    G3 X18.0418 Y42.0383 Z-3.0704 I42.3888 J17.3318
    G1 X18.0548 Y48.8822 Z-3.1899
    G1 X18.0699 Y56.8419 Z-3.3288
    G3 X17.6772 Y60.0119 Z-3.3847 I-12.7952 J0.0243
    G2 X60.094 Y2.8684 Z-4.7155 I-17.2833 J-57.1435
    G2 X-29.456 Y-48.8333 Z-6.898 I-59.7 J0.0
    G2 Y54.5701 Z-9.0805 I29.85 J51.7017
    G2 X-17.1525 Y59.9316 Z-9.3153 I29.85 J-51.7017
    G3 X-17.5204 Y56.9095 Z-9.3686 I12.4273 J-3.0464
    G1 X-17.5485 Y42.1059 Z-9.627
    G3 X-42.1562 Y17.3685 Z-10.2518 I17.715 J-42.2301
    G1 X-48.7611 Y17.381 Z-10.3671
    G3 X-56.5711 Y9.5573 Z-10.5816 I-0.0148 J-7.7952
    G1 X-56.5357 Y-0.122 Z-10.7505
    G1 X-56.5394 Y-2.0764 Z-10.7846
    G3 X-56.5295 Y-2.4838 Z-10.7918 I7.7952 J-0.0148
    G1 X-56.5431 Y-9.6336 Z-10.9166
    G3 X-48.7627 Y-17.4436 Z-11.1303 I7.7952 J-0.0148
    G1 X-42.2223 Y-17.456 Z-11.2444
    G3 X18.0418 Y42.0383 Z-14.3805 I42.3888 J17.3318
    G1 X18.0548 Y48.8822 Z-14.5
    G1 F600.0 X18.0699 Y56.8419
    G3 X-42.1562 Y17.3685 I17.715 J-42.2301
    G0 Z50.0
    G0 X-43.2333 Y-15.0541
    G0 Z1.5
    G1 F50.0 Z0.5
    G1 F300.0 X-40.5777 Y-15.0591 Z0.4536
    G3 X15.6387 Y40.4191 Z-2.5736 I40.7442 J14.9349
    G1 X15.6548 Y48.8868 Z-2.7214
    G1 X15.6699 Y56.8465 Z-2.8603
    G3 X13.1577 Y63.6425 Z-2.9895 I-10.3952 J0.0197
    G2 X62.494 Y2.8684 Z-4.4678 I-12.7638 J-60.7741
    G2 X-30.656 Y-50.9118 Z-6.738 I-62.1 J0.0
    G2 Y56.6486 Z-9.0082 I31.05 J53.7802
    G2 X-12.6806 Y63.5764 Z-9.3459 I31.05 J-53.7802
    G3 X-15.1204 Y56.905 Z-9.4724 I7.9554 J-6.6912
    G1 X-15.1516 Y40.4775 Z-9.7591
    G3 X-40.5207 Y14.9654 Z-10.4067 I15.3181 J-40.6017
    G1 X-48.7657 Y14.981 Z-10.5506
    G3 X-54.1711 Y9.5661 Z-10.6991 I-0.0102 J-5.3952
    G1 X-54.1357 Y-0.1199 Z-10.8681
    G1 X-54.1394 Y-2.081 Z-10.9024
    G3 X-54.1294 Y-2.4198 Z-10.9083 I5.3952 J-0.0102
    G1 X-54.1431 Y-9.6381 Z-11.0343
    G3 X-48.7581 Y-15.0436 Z-11.1822 I5.3952 J-0.0102
    G1 X-40.5777 Y-15.0591 Z-11.325
    G3 X15.6387 Y40.4191 Z-14.3522 I40.7442 J14.9349
    G1 X15.6548 Y48.8868 Z-14.5
    G1 F600.0 X15.6699 Y56.8465
    G3 X-40.5207 Y14.9654 I15.3181 J-40.6017
    G0 Z50.0
    G0 X-26.8843 Y61.3162
    G0 Z1.5
    G1 F50.0 Z0.5
    G2 F300.0 X20.6965 Y64.0898 Z-0.3521 I27.2783 J-58.4478
    G2 X64.894 Y2.8684 Z-1.7601 I-20.3025 J-61.2214
    G2 X-31.856 Y-52.9903 Z-4.1181 I-64.5 J0.0
    G2 Y58.727 Z-6.4761 I32.25 J55.8586
    G2 X20.6965 Y64.0898 Z-7.4261 I32.25 J-55.8586
    G2 X64.894 Y2.8684 Z-8.834 I-20.3025 J-61.2214
    G2 X-31.856 Y-52.9903 Z-11.192 I-64.5 J0.0
    G2 Y58.727 Z-13.55 I32.25 J55.8586
    G2 X20.6965 Y64.0898 Z-14.5 I32.25 J-55.8586
    G2 F600.0 X64.894 Y2.8684 I-20.3025 J-61.2214
    G2 Y58.727 I32.25 J55.8586
    G2 X20.6965 Y64.0898 I32.25 J-55.8586
    G0 Z50.0
    G0 X38.2928 Y14.955
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G3 F300.0 X13.2403 Y38.7355 Z-15.1224 I-38.1263 J-15.0792
    G1 X13.2747 Y56.851 Z-15.4386
    G3 X12.5194 Y60.2596 Z-15.5 I-8.0 J0.0152
    G3 F600.0 X5.2899 Y64.8662 I-7.2446 J-3.3934
    G3 X-12.7252 Y56.9004 I-0.0152 J-8.0
    G1 X13.2747 Y56.851
    G3 X12.5194 Y60.2596 I-8.0 J0.0152
    G0 Z50.0
    G0 X52.4125 Y9.9618
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G2 F300.0 X52.7939 Y6.1089 Z-14.5676 I-52.0186 J-7.0934
    G3 X25.2504 Y46.5587 Z-15.4555 I-52.6274 J-6.2331
    G1 X25.2552 Y49.1087 Z-15.5
    G2 F600.0 X52.7939 Y6.1089 I-24.8613 J-46.2403
    G0 Z50.0
    G0 X50.6909 Y2.5512
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G3 F300.0 X22.8476 Y45.1024 Z-15.43 I-50.5244 J-2.6754
    G1 X22.8552 Y49.1133 Z-15.5
    G0 Z50.0
    G0 X48.268 Y2.8793
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G3 F300.0 X20.4448 Y43.5973 Z-15.4036 I-48.1015 J-3.0035
    G1 X20.4552 Y49.1178 Z-15.5
    G0 Z50.0
    G0 X-32.2065 Y41.8339
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G3 F300.0 X-46.7199 Y24.5772 Z-14.8966 I32.373 J-41.9581
    G1 X-47.4069 Y24.5785 Z-14.9086
    G2 X-25.856 Y48.3347 Z-15.4776 I47.8009 J-21.7101
    G2 X-24.7355 Y48.9635 Z-15.5 I26.25 J-45.4663
    G1 X-48.752 Y22.181
    G0 Z50.0
    G0 X-52.075 Y31.3482
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G2 F300.0 X-29.456 Y54.5701 Z-15.073 I52.4689 J-28.4799
    G2 X-17.1525 Y59.9316 Z-15.3078 I29.85 J-51.7017
    G3 X-17.5204 Y56.9095 Z-15.3611 I12.4273 J-3.0464
    G1 X-17.5356 Y48.9498 Z-15.5
    G1 F600.0 X-17.5485 Y42.1059
    G0 Z50.0
    G0 X-47.8526 Y41.9667
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G2 F300.0 X-30.656 Y56.6486 Z-14.8969 I48.2466 J-39.0983
    G2 X-12.6806 Y63.5764 Z-15.2345 I31.05 J-53.7802
    G3 X-15.1204 Y56.905 Z-15.3611 I7.9554 J-6.6912
    G1 X-15.1356 Y48.9453 Z-15.5
    G1 F600.0 X-15.1516 Y40.4775
    G0 Z50.0
    G0 X-60.028 Y25.4392
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G2 F300.0 X-31.856 Y58.727 Z-15.2765 I60.4219 J-22.5708
    G2 X-20.2062 Y63.9902 Z-15.5 I32.25 J-55.8586
    G2 F600.0 X64.894 Y2.8684 I20.6002 J-61.1219
    G2 X-20.2062 Y63.9902 I32.25 J-55.8586
    ( 6mm center )
    S13000
    G0 Z50.0
    G0 X-0.2321 Y-0.0561
    G0 Z16.5
    G1 F50.0 Z15.5
    G2 F300.0 X-0.0324 Y0.2744 Z15.493 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z15.4783 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.4637 I-0.4 J0.0
    G2 Y0.2744 Z15.4491 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.4345 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.4198 I-0.4 J0.0
    G2 Y0.2744 Z15.4052 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.3906 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.376 I-0.4 J0.0
    G2 Y0.2744 Z15.3614 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.3467 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.3321 I-0.4 J0.0
    G2 Y0.2744 Z15.3175 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.3029 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.2882 I-0.4 J0.0
    G2 Y0.2744 Z15.2736 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.259 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.2444 I-0.4 J0.0
    G2 Y0.2744 Z15.2297 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.2151 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.2005 I-0.4 J0.0
    G2 Y0.2744 Z15.1859 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.1713 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.1566 I-0.4 J0.0
    G2 Y0.2744 Z15.142 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.1274 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.1128 I-0.4 J0.0
    G2 Y0.2744 Z15.0981 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.0835 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.0689 I-0.4 J0.0
    G2 Y0.2744 Z15.0543 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z15.0396 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z15.025 I-0.4 J0.0
    G2 Y0.2744 Z15.0104 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.9958 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.9812 I-0.4 J0.0
    G2 Y0.2744 Z14.9665 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.9519 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.9373 I-0.4 J0.0
    G2 Y0.2744 Z14.9227 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.908 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.8934 I-0.4 J0.0
    G2 Y0.2744 Z14.8788 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.8642 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.8495 I-0.4 J0.0
    G2 Y0.2744 Z14.8349 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.8203 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.8057 I-0.4 J0.0
    G2 Y0.2744 Z14.7911 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.7764 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.7618 I-0.4 J0.0
    G2 Y0.2744 Z14.7472 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.7326 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.7179 I-0.4 J0.0
    G2 Y0.2744 Z14.7033 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.6887 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.6741 I-0.4 J0.0
    G2 Y0.2744 Z14.6594 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.6448 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.6302 I-0.4 J0.0
    G2 Y0.2744 Z14.6156 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.601 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.5863 I-0.4 J0.0
    G2 Y0.2744 Z14.5717 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.5571 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.5425 I-0.4 J0.0
    G2 Y0.2744 Z14.5278 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.5132 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.4986 I-0.4 J0.0
    G2 Y0.2744 Z14.484 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.4693 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.4547 I-0.4 J0.0
    G2 Y0.2744 Z14.4401 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.4255 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.4109 I-0.4 J0.0
    G2 Y0.2744 Z14.3962 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.3816 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.367 I-0.4 J0.0
    G2 Y0.2744 Z14.3524 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.3377 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.3231 I-0.4 J0.0
    G2 Y0.2744 Z14.3085 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.2939 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.2792 I-0.4 J0.0
    G2 Y0.2744 Z14.2646 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.25 I0.2 J-0.3464
    G2 F600.0 X-0.0324 Y-0.4184 I-0.4 J0.0
    G2 Y0.2744 I0.2 J0.3464
    G2 X0.5676 Y-0.072 I0.2 J-0.3464
    G1 X2.9676
    G2 X-1.2324 Y-2.4968 I-2.8 J0.0
    G2 Y2.3529 I1.4 J2.4249
    G2 X2.9676 Y-0.072 I1.4 J-2.4249
    G1 X5.3676
    G2 X-2.4324 Y-4.5753 I-5.2 J0.0
    G2 Y4.4314 I2.6 J4.5033
    G2 X5.3676 Y-0.072 I2.6 J-4.5033
    G1 X7.7676
    G2 X-3.6324 Y-6.6538 I-7.6 J0.0
    G2 Y6.5098 I3.8 J6.5818
    G2 X7.7676 Y-0.072 I3.8 J-6.5818
    G1 X10.1676
    G2 X-4.8324 Y-8.7322 I-10.0 J0.0
    G2 Y8.5883 I5.0 J8.6603
    G2 X10.1676 Y-0.072 I5.0 J-8.6603
    G1 X12.5676
    G2 X-6.0324 Y-10.8107 I-12.4 J0.0
    G2 Y10.6667 I6.2 J10.7387
    G2 X12.5676 Y-0.072 I6.2 J-10.7387
    G1 X14.9676
    G2 X-7.2324 Y-12.8891 I-14.8 J0.0
    G2 Y12.7452 I7.4 J12.8172
    G2 X14.9676 Y-0.072 I7.4 J-12.8172
    G1 X17.3676
    G2 X-8.4324 Y-14.9676 I-17.2 J0.0
    G2 Y14.8237 I8.6 J14.8956
    G2 X17.3676 Y-0.072 I8.6 J-14.8956
    G1 X19.7676
    G2 X-9.6324 Y-17.0461 I-19.6 J0.0
    G2 Y16.9021 I9.8 J16.9741
    G2 X19.7676 Y-0.072 I9.8 J-16.9741
    G1 X22.1676
    G2 X-10.8324 Y-19.1245 I-22.0 J0.0
    G2 Y18.9806 I11.0 J19.0526
    G2 X22.1676 Y-0.072 I11.0 J-19.0526
    G1 X24.5676
    G2 X-12.0324 Y-21.203 I-24.4 J0.0
    G2 Y21.059 I12.2 J21.131
    G2 X24.5676 Y-0.072 I12.2 J-21.131
    G0 Z50.0
    G0 Z15.25
    G1 F50.0 Z14.25
    G2 F300.0 X-0.0324 Y0.2744 Z14.243 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z14.2283 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.2137 I-0.4 J0.0
    G2 Y0.2744 Z14.1991 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.1845 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.1698 I-0.4 J0.0
    G2 Y0.2744 Z14.1552 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.1406 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.126 I-0.4 J0.0
    G2 Y0.2744 Z14.1114 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.0967 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.0821 I-0.4 J0.0
    G2 Y0.2744 Z14.0675 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.0529 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z14.0382 I-0.4 J0.0
    G2 Y0.2744 Z14.0236 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z14.009 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.9944 I-0.4 J0.0
    G2 Y0.2744 Z13.9797 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.9651 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.9505 I-0.4 J0.0
    G2 Y0.2744 Z13.9359 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.9213 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.9066 I-0.4 J0.0
    G2 Y0.2744 Z13.892 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.8774 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.8628 I-0.4 J0.0
    G2 Y0.2744 Z13.8481 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.8335 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.8189 I-0.4 J0.0
    G2 Y0.2744 Z13.8043 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.7896 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.775 I-0.4 J0.0
    G2 Y0.2744 Z13.7604 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.7458 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.7312 I-0.4 J0.0
    G2 Y0.2744 Z13.7165 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.7019 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.6873 I-0.4 J0.0
    G2 Y0.2744 Z13.6727 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.658 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.6434 I-0.4 J0.0
    G2 Y0.2744 Z13.6288 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.6142 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.5995 I-0.4 J0.0
    G2 Y0.2744 Z13.5849 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.5703 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.5557 I-0.4 J0.0
    G2 Y0.2744 Z13.5411 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.5264 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.5118 I-0.4 J0.0
    G2 Y0.2744 Z13.4972 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.4826 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.4679 I-0.4 J0.0
    G2 Y0.2744 Z13.4533 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.4387 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.4241 I-0.4 J0.0
    G2 Y0.2744 Z13.4094 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.3948 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.3802 I-0.4 J0.0
    G2 Y0.2744 Z13.3656 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.351 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.3363 I-0.4 J0.0
    G2 Y0.2744 Z13.3217 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.3071 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.2925 I-0.4 J0.0
    G2 Y0.2744 Z13.2778 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.2632 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.2486 I-0.4 J0.0
    G2 Y0.2744 Z13.234 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.2193 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.2047 I-0.4 J0.0
    G2 Y0.2744 Z13.1901 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.1755 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.1609 I-0.4 J0.0
    G2 Y0.2744 Z13.1462 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.1316 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.117 I-0.4 J0.0
    G2 Y0.2744 Z13.1024 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.0877 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.0731 I-0.4 J0.0
    G2 Y0.2744 Z13.0585 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.0439 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z13.0292 I-0.4 J0.0
    G2 Y0.2744 Z13.0146 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z13.0 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z14.0
    G1 F50.0 Z13.0
    G2 F300.0 X-0.0324 Y0.2744 Z12.993 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z12.9783 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.9637 I-0.4 J0.0
    G2 Y0.2744 Z12.9491 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.9345 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.9198 I-0.4 J0.0
    G2 Y0.2744 Z12.9052 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.8906 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.876 I-0.4 J0.0
    G2 Y0.2744 Z12.8614 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.8467 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.8321 I-0.4 J0.0
    G2 Y0.2744 Z12.8175 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.8029 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.7882 I-0.4 J0.0
    G2 Y0.2744 Z12.7736 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.759 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.7444 I-0.4 J0.0
    G2 Y0.2744 Z12.7297 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.7151 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.7005 I-0.4 J0.0
    G2 Y0.2744 Z12.6859 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.6713 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.6566 I-0.4 J0.0
    G2 Y0.2744 Z12.642 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.6274 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.6128 I-0.4 J0.0
    G2 Y0.2744 Z12.5981 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.5835 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.5689 I-0.4 J0.0
    G2 Y0.2744 Z12.5543 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.5396 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.525 I-0.4 J0.0
    G2 Y0.2744 Z12.5104 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.4958 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.4812 I-0.4 J0.0
    G2 Y0.2744 Z12.4665 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.4519 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.4373 I-0.4 J0.0
    G2 Y0.2744 Z12.4227 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.408 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.3934 I-0.4 J0.0
    G2 Y0.2744 Z12.3788 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.3642 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.3495 I-0.4 J0.0
    G2 Y0.2744 Z12.3349 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.3203 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.3057 I-0.4 J0.0
    G2 Y0.2744 Z12.2911 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.2764 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.2618 I-0.4 J0.0
    G2 Y0.2744 Z12.2472 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.2326 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.2179 I-0.4 J0.0
    G2 Y0.2744 Z12.2033 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.1887 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.1741 I-0.4 J0.0
    G2 Y0.2744 Z12.1594 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.1448 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.1302 I-0.4 J0.0
    G2 Y0.2744 Z12.1156 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.101 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.0863 I-0.4 J0.0
    G2 Y0.2744 Z12.0717 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.0571 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z12.0425 I-0.4 J0.0
    G2 Y0.2744 Z12.0278 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z12.0132 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.9986 I-0.4 J0.0
    G2 Y0.2744 Z11.984 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.9693 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.9547 I-0.4 J0.0
    G2 Y0.2744 Z11.9401 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.9255 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.9109 I-0.4 J0.0
    G2 Y0.2744 Z11.8962 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.8816 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.867 I-0.4 J0.0
    G2 Y0.2744 Z11.8524 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.8377 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.8231 I-0.4 J0.0
    G2 Y0.2744 Z11.8085 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.7939 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.7792 I-0.4 J0.0
    G2 Y0.2744 Z11.7646 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.75 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z12.75
    G1 F50.0 Z11.75
    G2 F300.0 X-0.0324 Y0.2744 Z11.743 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z11.7283 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.7137 I-0.4 J0.0
    G2 Y0.2744 Z11.6991 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.6845 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.6698 I-0.4 J0.0
    G2 Y0.2744 Z11.6552 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.6406 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.626 I-0.4 J0.0
    G2 Y0.2744 Z11.6114 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.5967 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.5821 I-0.4 J0.0
    G2 Y0.2744 Z11.5675 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.5529 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.5382 I-0.4 J0.0
    G2 Y0.2744 Z11.5236 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.509 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.4944 I-0.4 J0.0
    G2 Y0.2744 Z11.4797 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.4651 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.4505 I-0.4 J0.0
    G2 Y0.2744 Z11.4359 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.4213 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.4066 I-0.4 J0.0
    G2 Y0.2744 Z11.392 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.3774 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.3628 I-0.4 J0.0
    G2 Y0.2744 Z11.3481 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.3335 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.3189 I-0.4 J0.0
    G2 Y0.2744 Z11.3043 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.2896 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.275 I-0.4 J0.0
    G2 Y0.2744 Z11.2604 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.2458 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.2312 I-0.4 J0.0
    G2 Y0.2744 Z11.2165 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.2019 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.1873 I-0.4 J0.0
    G2 Y0.2744 Z11.1727 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.158 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.1434 I-0.4 J0.0
    G2 Y0.2744 Z11.1288 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.1142 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.0995 I-0.4 J0.0
    G2 Y0.2744 Z11.0849 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.0703 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.0557 I-0.4 J0.0
    G2 Y0.2744 Z11.0411 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z11.0264 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z11.0118 I-0.4 J0.0
    G2 Y0.2744 Z10.9972 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.9826 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.9679 I-0.4 J0.0
    G2 Y0.2744 Z10.9533 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.9387 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.9241 I-0.4 J0.0
    G2 Y0.2744 Z10.9094 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.8948 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.8802 I-0.4 J0.0
    G2 Y0.2744 Z10.8656 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.851 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.8363 I-0.4 J0.0
    G2 Y0.2744 Z10.8217 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.8071 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.7925 I-0.4 J0.0
    G2 Y0.2744 Z10.7778 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.7632 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.7486 I-0.4 J0.0
    G2 Y0.2744 Z10.734 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.7193 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.7047 I-0.4 J0.0
    G2 Y0.2744 Z10.6901 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.6755 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.6609 I-0.4 J0.0
    G2 Y0.2744 Z10.6462 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.6316 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.617 I-0.4 J0.0
    G2 Y0.2744 Z10.6024 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.5877 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.5731 I-0.4 J0.0
    G2 Y0.2744 Z10.5585 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.5439 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.5292 I-0.4 J0.0
    G2 Y0.2744 Z10.5146 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.5 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z11.5
    G1 F50.0 Z10.5
    G2 F300.0 X-0.0324 Y0.2744 Z10.493 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z10.4783 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.4637 I-0.4 J0.0
    G2 Y0.2744 Z10.4491 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.4345 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.4198 I-0.4 J0.0
    G2 Y0.2744 Z10.4052 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.3906 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.376 I-0.4 J0.0
    G2 Y0.2744 Z10.3614 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.3467 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.3321 I-0.4 J0.0
    G2 Y0.2744 Z10.3175 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.3029 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.2882 I-0.4 J0.0
    G2 Y0.2744 Z10.2736 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.259 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.2444 I-0.4 J0.0
    G2 Y0.2744 Z10.2297 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.2151 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.2005 I-0.4 J0.0
    G2 Y0.2744 Z10.1859 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.1713 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.1566 I-0.4 J0.0
    G2 Y0.2744 Z10.142 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.1274 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.1128 I-0.4 J0.0
    G2 Y0.2744 Z10.0981 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.0835 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.0689 I-0.4 J0.0
    G2 Y0.2744 Z10.0543 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z10.0396 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z10.025 I-0.4 J0.0
    G2 Y0.2744 Z10.0104 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.9958 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.9812 I-0.4 J0.0
    G2 Y0.2744 Z9.9665 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.9519 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.9373 I-0.4 J0.0
    G2 Y0.2744 Z9.9227 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.908 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.8934 I-0.4 J0.0
    G2 Y0.2744 Z9.8788 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.8642 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.8495 I-0.4 J0.0
    G2 Y0.2744 Z9.8349 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.8203 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.8057 I-0.4 J0.0
    G2 Y0.2744 Z9.7911 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.7764 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.7618 I-0.4 J0.0
    G2 Y0.2744 Z9.7472 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.7326 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.7179 I-0.4 J0.0
    G2 Y0.2744 Z9.7033 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.6887 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.6741 I-0.4 J0.0
    G2 Y0.2744 Z9.6594 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.6448 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.6302 I-0.4 J0.0
    G2 Y0.2744 Z9.6156 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.601 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.5863 I-0.4 J0.0
    G2 Y0.2744 Z9.5717 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.5571 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.5425 I-0.4 J0.0
    G2 Y0.2744 Z9.5278 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.5132 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.4986 I-0.4 J0.0
    G2 Y0.2744 Z9.484 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.4693 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.4547 I-0.4 J0.0
    G2 Y0.2744 Z9.4401 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.4255 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.4109 I-0.4 J0.0
    G2 Y0.2744 Z9.3962 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.3816 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.367 I-0.4 J0.0
    G2 Y0.2744 Z9.3524 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.3377 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.3231 I-0.4 J0.0
    G2 Y0.2744 Z9.3085 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.2939 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.2792 I-0.4 J0.0
    G2 Y0.2744 Z9.2646 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.25 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z10.25
    G1 F50.0 Z9.25
    G2 F300.0 X-0.0324 Y0.2744 Z9.243 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z9.2283 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.2137 I-0.4 J0.0
    G2 Y0.2744 Z9.1991 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.1845 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.1698 I-0.4 J0.0
    G2 Y0.2744 Z9.1552 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.1406 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.126 I-0.4 J0.0
    G2 Y0.2744 Z9.1114 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.0967 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.0821 I-0.4 J0.0
    G2 Y0.2744 Z9.0675 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.0529 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z9.0382 I-0.4 J0.0
    G2 Y0.2744 Z9.0236 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z9.009 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.9944 I-0.4 J0.0
    G2 Y0.2744 Z8.9797 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.9651 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.9505 I-0.4 J0.0
    G2 Y0.2744 Z8.9359 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.9213 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.9066 I-0.4 J0.0
    G2 Y0.2744 Z8.892 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.8774 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.8628 I-0.4 J0.0
    G2 Y0.2744 Z8.8481 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.8335 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.8189 I-0.4 J0.0
    G2 Y0.2744 Z8.8043 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.7896 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.775 I-0.4 J0.0
    G2 Y0.2744 Z8.7604 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.7458 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.7312 I-0.4 J0.0
    G2 Y0.2744 Z8.7165 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.7019 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.6873 I-0.4 J0.0
    G2 Y0.2744 Z8.6727 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.658 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.6434 I-0.4 J0.0
    G2 Y0.2744 Z8.6288 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.6142 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.5995 I-0.4 J0.0
    G2 Y0.2744 Z8.5849 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.5703 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.5557 I-0.4 J0.0
    G2 Y0.2744 Z8.5411 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.5264 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.5118 I-0.4 J0.0
    G2 Y0.2744 Z8.4972 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.4826 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.4679 I-0.4 J0.0
    G2 Y0.2744 Z8.4533 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.4387 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.4241 I-0.4 J0.0
    G2 Y0.2744 Z8.4094 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.3948 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.3802 I-0.4 J0.0
    G2 Y0.2744 Z8.3656 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.351 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.3363 I-0.4 J0.0
    G2 Y0.2744 Z8.3217 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.3071 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.2925 I-0.4 J0.0
    G2 Y0.2744 Z8.2778 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.2632 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.2486 I-0.4 J0.0
    G2 Y0.2744 Z8.234 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.2193 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.2047 I-0.4 J0.0
    G2 Y0.2744 Z8.1901 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.1755 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.1609 I-0.4 J0.0
    G2 Y0.2744 Z8.1462 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.1316 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.117 I-0.4 J0.0
    G2 Y0.2744 Z8.1024 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.0877 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.0731 I-0.4 J0.0
    G2 Y0.2744 Z8.0585 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.0439 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z8.0292 I-0.4 J0.0
    G2 Y0.2744 Z8.0146 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z8.0 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z9.0
    G1 F50.0 Z8.0
    G2 F300.0 X-0.0324 Y0.2744 Z7.993 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z7.9783 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.9637 I-0.4 J0.0
    G2 Y0.2744 Z7.9491 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.9345 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.9198 I-0.4 J0.0
    G2 Y0.2744 Z7.9052 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.8906 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.876 I-0.4 J0.0
    G2 Y0.2744 Z7.8614 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.8467 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.8321 I-0.4 J0.0
    G2 Y0.2744 Z7.8175 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.8029 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.7882 I-0.4 J0.0
    G2 Y0.2744 Z7.7736 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.759 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.7444 I-0.4 J0.0
    G2 Y0.2744 Z7.7297 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.7151 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.7005 I-0.4 J0.0
    G2 Y0.2744 Z7.6859 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.6713 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.6566 I-0.4 J0.0
    G2 Y0.2744 Z7.642 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.6274 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.6128 I-0.4 J0.0
    G2 Y0.2744 Z7.5981 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.5835 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.5689 I-0.4 J0.0
    G2 Y0.2744 Z7.5543 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.5396 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.525 I-0.4 J0.0
    G2 Y0.2744 Z7.5104 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.4958 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.4812 I-0.4 J0.0
    G2 Y0.2744 Z7.4665 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.4519 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.4373 I-0.4 J0.0
    G2 Y0.2744 Z7.4227 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.408 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.3934 I-0.4 J0.0
    G2 Y0.2744 Z7.3788 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.3642 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.3495 I-0.4 J0.0
    G2 Y0.2744 Z7.3349 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.3203 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.3057 I-0.4 J0.0
    G2 Y0.2744 Z7.2911 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.2764 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.2618 I-0.4 J0.0
    G2 Y0.2744 Z7.2472 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.2326 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.2179 I-0.4 J0.0
    G2 Y0.2744 Z7.2033 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.1887 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.1741 I-0.4 J0.0
    G2 Y0.2744 Z7.1594 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.1448 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.1302 I-0.4 J0.0
    G2 Y0.2744 Z7.1156 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.101 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.0863 I-0.4 J0.0
    G2 Y0.2744 Z7.0717 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.0571 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z7.0425 I-0.4 J0.0
    G2 Y0.2744 Z7.0278 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z7.0132 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.9986 I-0.4 J0.0
    G2 Y0.2744 Z6.984 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.9693 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.9547 I-0.4 J0.0
    G2 Y0.2744 Z6.9401 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.9255 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.9109 I-0.4 J0.0
    G2 Y0.2744 Z6.8962 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.8816 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.867 I-0.4 J0.0
    G2 Y0.2744 Z6.8524 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.8377 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.8231 I-0.4 J0.0
    G2 Y0.2744 Z6.8085 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.7939 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.7792 I-0.4 J0.0
    G2 Y0.2744 Z6.7646 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.75 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z7.75
    G1 F50.0 Z6.75
    G2 F300.0 X-0.0324 Y0.2744 Z6.743 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z6.7283 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.7137 I-0.4 J0.0
    G2 Y0.2744 Z6.6991 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.6845 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.6698 I-0.4 J0.0
    G2 Y0.2744 Z6.6552 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.6406 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.626 I-0.4 J0.0
    G2 Y0.2744 Z6.6114 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.5967 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.5821 I-0.4 J0.0
    G2 Y0.2744 Z6.5675 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.5529 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.5382 I-0.4 J0.0
    G2 Y0.2744 Z6.5236 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.509 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.4944 I-0.4 J0.0
    G2 Y0.2744 Z6.4797 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.4651 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.4505 I-0.4 J0.0
    G2 Y0.2744 Z6.4359 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.4213 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.4066 I-0.4 J0.0
    G2 Y0.2744 Z6.392 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.3774 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.3628 I-0.4 J0.0
    G2 Y0.2744 Z6.3481 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.3335 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.3189 I-0.4 J0.0
    G2 Y0.2744 Z6.3043 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.2896 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.275 I-0.4 J0.0
    G2 Y0.2744 Z6.2604 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.2458 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.2312 I-0.4 J0.0
    G2 Y0.2744 Z6.2165 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.2019 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.1873 I-0.4 J0.0
    G2 Y0.2744 Z6.1727 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.158 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.1434 I-0.4 J0.0
    G2 Y0.2744 Z6.1288 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.1142 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.0995 I-0.4 J0.0
    G2 Y0.2744 Z6.0849 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.0703 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.0557 I-0.4 J0.0
    G2 Y0.2744 Z6.0411 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z6.0264 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z6.0118 I-0.4 J0.0
    G2 Y0.2744 Z5.9972 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.9826 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.9679 I-0.4 J0.0
    G2 Y0.2744 Z5.9533 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.9387 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.9241 I-0.4 J0.0
    G2 Y0.2744 Z5.9094 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.8948 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.8802 I-0.4 J0.0
    G2 Y0.2744 Z5.8656 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.851 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.8363 I-0.4 J0.0
    G2 Y0.2744 Z5.8217 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.8071 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.7925 I-0.4 J0.0
    G2 Y0.2744 Z5.7778 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.7632 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.7486 I-0.4 J0.0
    G2 Y0.2744 Z5.734 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.7193 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.7047 I-0.4 J0.0
    G2 Y0.2744 Z5.6901 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.6755 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.6609 I-0.4 J0.0
    G2 Y0.2744 Z5.6462 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.6316 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.617 I-0.4 J0.0
    G2 Y0.2744 Z5.6024 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.5877 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.5731 I-0.4 J0.0
    G2 Y0.2744 Z5.5585 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.5439 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.5292 I-0.4 J0.0
    G2 Y0.2744 Z5.5146 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.5 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z6.5
    G1 F50.0 Z5.5
    G2 F300.0 X-0.0324 Y0.2744 Z5.493 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z5.4783 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.4637 I-0.4 J0.0
    G2 Y0.2744 Z5.4491 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.4345 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.4198 I-0.4 J0.0
    G2 Y0.2744 Z5.4052 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.3906 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.376 I-0.4 J0.0
    G2 Y0.2744 Z5.3614 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.3467 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.3321 I-0.4 J0.0
    G2 Y0.2744 Z5.3175 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.3029 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.2882 I-0.4 J0.0
    G2 Y0.2744 Z5.2736 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.259 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.2444 I-0.4 J0.0
    G2 Y0.2744 Z5.2297 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.2151 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.2005 I-0.4 J0.0
    G2 Y0.2744 Z5.1859 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.1713 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.1566 I-0.4 J0.0
    G2 Y0.2744 Z5.142 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.1274 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.1128 I-0.4 J0.0
    G2 Y0.2744 Z5.0981 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.0835 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.0689 I-0.4 J0.0
    G2 Y0.2744 Z5.0543 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z5.0396 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z5.025 I-0.4 J0.0
    G2 Y0.2744 Z5.0104 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.9958 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.9812 I-0.4 J0.0
    G2 Y0.2744 Z4.9665 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.9519 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.9373 I-0.4 J0.0
    G2 Y0.2744 Z4.9227 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.908 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.8934 I-0.4 J0.0
    G2 Y0.2744 Z4.8788 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.8642 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.8495 I-0.4 J0.0
    G2 Y0.2744 Z4.8349 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.8203 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.8057 I-0.4 J0.0
    G2 Y0.2744 Z4.7911 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.7764 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.7618 I-0.4 J0.0
    G2 Y0.2744 Z4.7472 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.7326 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.7179 I-0.4 J0.0
    G2 Y0.2744 Z4.7033 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.6887 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.6741 I-0.4 J0.0
    G2 Y0.2744 Z4.6594 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.6448 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.6302 I-0.4 J0.0
    G2 Y0.2744 Z4.6156 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.601 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.5863 I-0.4 J0.0
    G2 Y0.2744 Z4.5717 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.5571 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.5425 I-0.4 J0.0
    G2 Y0.2744 Z4.5278 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.5132 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.4986 I-0.4 J0.0
    G2 Y0.2744 Z4.484 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.4693 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.4547 I-0.4 J0.0
    G2 Y0.2744 Z4.4401 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.4255 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.4109 I-0.4 J0.0
    G2 Y0.2744 Z4.3962 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.3816 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.367 I-0.4 J0.0
    G2 Y0.2744 Z4.3524 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.3377 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.3231 I-0.4 J0.0
    G2 Y0.2744 Z4.3085 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.2939 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.2792 I-0.4 J0.0
    G2 Y0.2744 Z4.2646 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.25 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z5.25
    G1 F50.0 Z4.25
    G2 F300.0 X-0.0324 Y0.2744 Z4.243 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z4.2283 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.2137 I-0.4 J0.0
    G2 Y0.2744 Z4.1991 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.1845 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.1698 I-0.4 J0.0
    G2 Y0.2744 Z4.1552 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.1406 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.126 I-0.4 J0.0
    G2 Y0.2744 Z4.1114 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.0967 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.0821 I-0.4 J0.0
    G2 Y0.2744 Z4.0675 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.0529 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z4.0382 I-0.4 J0.0
    G2 Y0.2744 Z4.0236 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z4.009 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.9944 I-0.4 J0.0
    G2 Y0.2744 Z3.9797 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.9651 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.9505 I-0.4 J0.0
    G2 Y0.2744 Z3.9359 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.9213 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.9066 I-0.4 J0.0
    G2 Y0.2744 Z3.892 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.8774 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.8628 I-0.4 J0.0
    G2 Y0.2744 Z3.8481 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.8335 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.8189 I-0.4 J0.0
    G2 Y0.2744 Z3.8043 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.7896 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.775 I-0.4 J0.0
    G2 Y0.2744 Z3.7604 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.7458 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.7312 I-0.4 J0.0
    G2 Y0.2744 Z3.7165 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.7019 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.6873 I-0.4 J0.0
    G2 Y0.2744 Z3.6727 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.658 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.6434 I-0.4 J0.0
    G2 Y0.2744 Z3.6288 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.6142 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.5995 I-0.4 J0.0
    G2 Y0.2744 Z3.5849 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.5703 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.5557 I-0.4 J0.0
    G2 Y0.2744 Z3.5411 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.5264 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.5118 I-0.4 J0.0
    G2 Y0.2744 Z3.4972 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.4826 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.4679 I-0.4 J0.0
    G2 Y0.2744 Z3.4533 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.4387 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.4241 I-0.4 J0.0
    G2 Y0.2744 Z3.4094 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.3948 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.3802 I-0.4 J0.0
    G2 Y0.2744 Z3.3656 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.351 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.3363 I-0.4 J0.0
    G2 Y0.2744 Z3.3217 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.3071 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.2925 I-0.4 J0.0
    G2 Y0.2744 Z3.2778 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.2632 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.2486 I-0.4 J0.0
    G2 Y0.2744 Z3.234 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.2193 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.2047 I-0.4 J0.0
    G2 Y0.2744 Z3.1901 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.1755 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.1609 I-0.4 J0.0
    G2 Y0.2744 Z3.1462 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.1316 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.117 I-0.4 J0.0
    G2 Y0.2744 Z3.1024 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.0877 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.0731 I-0.4 J0.0
    G2 Y0.2744 Z3.0585 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.0439 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z3.0292 I-0.4 J0.0
    G2 Y0.2744 Z3.0146 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z3.0 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z4.0
    G1 F50.0 Z3.0
    G2 F300.0 X-0.0324 Y0.2744 Z2.993 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z2.9783 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.9637 I-0.4 J0.0
    G2 Y0.2744 Z2.9491 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.9345 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.9198 I-0.4 J0.0
    G2 Y0.2744 Z2.9052 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.8906 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.876 I-0.4 J0.0
    G2 Y0.2744 Z2.8614 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.8467 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.8321 I-0.4 J0.0
    G2 Y0.2744 Z2.8175 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.8029 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.7882 I-0.4 J0.0
    G2 Y0.2744 Z2.7736 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.759 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.7444 I-0.4 J0.0
    G2 Y0.2744 Z2.7297 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.7151 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.7005 I-0.4 J0.0
    G2 Y0.2744 Z2.6859 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.6713 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.6566 I-0.4 J0.0
    G2 Y0.2744 Z2.642 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.6274 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.6128 I-0.4 J0.0
    G2 Y0.2744 Z2.5981 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.5835 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.5689 I-0.4 J0.0
    G2 Y0.2744 Z2.5543 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.5396 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.525 I-0.4 J0.0
    G2 Y0.2744 Z2.5104 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.4958 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.4812 I-0.4 J0.0
    G2 Y0.2744 Z2.4665 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.4519 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.4373 I-0.4 J0.0
    G2 Y0.2744 Z2.4227 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.408 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.3934 I-0.4 J0.0
    G2 Y0.2744 Z2.3788 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.3642 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.3495 I-0.4 J0.0
    G2 Y0.2744 Z2.3349 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.3203 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.3057 I-0.4 J0.0
    G2 Y0.2744 Z2.2911 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.2764 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.2618 I-0.4 J0.0
    G2 Y0.2744 Z2.2472 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.2326 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.2179 I-0.4 J0.0
    G2 Y0.2744 Z2.2033 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.1887 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.1741 I-0.4 J0.0
    G2 Y0.2744 Z2.1594 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.1448 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.1302 I-0.4 J0.0
    G2 Y0.2744 Z2.1156 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.101 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.0863 I-0.4 J0.0
    G2 Y0.2744 Z2.0717 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.0571 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z2.0425 I-0.4 J0.0
    G2 Y0.2744 Z2.0278 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z2.0132 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.9986 I-0.4 J0.0
    G2 Y0.2744 Z1.984 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.9693 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.9547 I-0.4 J0.0
    G2 Y0.2744 Z1.9401 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.9255 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.9109 I-0.4 J0.0
    G2 Y0.2744 Z1.8962 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.8816 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.867 I-0.4 J0.0
    G2 Y0.2744 Z1.8524 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.8377 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.8231 I-0.4 J0.0
    G2 Y0.2744 Z1.8085 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.7939 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.7792 I-0.4 J0.0
    G2 Y0.2744 Z1.7646 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.75 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z2.75
    G1 F50.0 Z1.75
    G2 F300.0 X-0.0324 Y0.2744 Z1.743 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z1.7283 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.7137 I-0.4 J0.0
    G2 Y0.2744 Z1.6991 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.6845 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.6698 I-0.4 J0.0
    G2 Y0.2744 Z1.6552 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.6406 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.626 I-0.4 J0.0
    G2 Y0.2744 Z1.6114 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.5967 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.5821 I-0.4 J0.0
    G2 Y0.2744 Z1.5675 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.5529 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.5382 I-0.4 J0.0
    G2 Y0.2744 Z1.5236 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.509 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.4944 I-0.4 J0.0
    G2 Y0.2744 Z1.4797 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.4651 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.4505 I-0.4 J0.0
    G2 Y0.2744 Z1.4359 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.4213 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.4066 I-0.4 J0.0
    G2 Y0.2744 Z1.392 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.3774 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.3628 I-0.4 J0.0
    G2 Y0.2744 Z1.3481 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.3335 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.3189 I-0.4 J0.0
    G2 Y0.2744 Z1.3043 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.2896 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.275 I-0.4 J0.0
    G2 Y0.2744 Z1.2604 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.2458 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.2312 I-0.4 J0.0
    G2 Y0.2744 Z1.2165 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.2019 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.1873 I-0.4 J0.0
    G2 Y0.2744 Z1.1727 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.158 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.1434 I-0.4 J0.0
    G2 Y0.2744 Z1.1288 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.1142 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.0995 I-0.4 J0.0
    G2 Y0.2744 Z1.0849 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.0703 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.0557 I-0.4 J0.0
    G2 Y0.2744 Z1.0411 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z1.0264 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z1.0118 I-0.4 J0.0
    G2 Y0.2744 Z0.9972 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.9826 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.9679 I-0.4 J0.0
    G2 Y0.2744 Z0.9533 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.9387 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.9241 I-0.4 J0.0
    G2 Y0.2744 Z0.9094 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.8948 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.8802 I-0.4 J0.0
    G2 Y0.2744 Z0.8656 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.851 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.8363 I-0.4 J0.0
    G2 Y0.2744 Z0.8217 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.8071 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.7925 I-0.4 J0.0
    G2 Y0.2744 Z0.7778 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.7632 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.7486 I-0.4 J0.0
    G2 Y0.2744 Z0.734 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.7193 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.7047 I-0.4 J0.0
    G2 Y0.2744 Z0.6901 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.6755 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.6609 I-0.4 J0.0
    G2 Y0.2744 Z0.6462 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.6316 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.617 I-0.4 J0.0
    G2 Y0.2744 Z0.6024 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.5877 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.5731 I-0.4 J0.0
    G2 Y0.2744 Z0.5585 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.5439 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.5292 I-0.4 J0.0
    G2 Y0.2744 Z0.5146 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.5 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z1.5
    G1 F50.0 Z0.5
    G2 F300.0 X-0.0324 Y0.2744 Z0.493 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z0.4783 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.4637 I-0.4 J0.0
    G2 Y0.2744 Z0.4491 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.4345 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.4198 I-0.4 J0.0
    G2 Y0.2744 Z0.4052 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.3906 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.376 I-0.4 J0.0
    G2 Y0.2744 Z0.3614 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.3467 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.3321 I-0.4 J0.0
    G2 Y0.2744 Z0.3175 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.3029 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.2882 I-0.4 J0.0
    G2 Y0.2744 Z0.2736 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.259 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.2444 I-0.4 J0.0
    G2 Y0.2744 Z0.2297 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.2151 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.2005 I-0.4 J0.0
    G2 Y0.2744 Z0.1859 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.1713 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.1566 I-0.4 J0.0
    G2 Y0.2744 Z0.142 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.1274 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.1128 I-0.4 J0.0
    G2 Y0.2744 Z0.0981 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.0835 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.0689 I-0.4 J0.0
    G2 Y0.2744 Z0.0543 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z0.0396 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z0.025 I-0.4 J0.0
    G2 Y0.2744 Z0.0104 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.0042 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.0188 I-0.4 J0.0
    G2 Y0.2744 Z-0.0335 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.0481 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.0627 I-0.4 J0.0
    G2 Y0.2744 Z-0.0773 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.092 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.1066 I-0.4 J0.0
    G2 Y0.2744 Z-0.1212 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.1358 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.1505 I-0.4 J0.0
    G2 Y0.2744 Z-0.1651 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.1797 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.1943 I-0.4 J0.0
    G2 Y0.2744 Z-0.2089 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.2236 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.2382 I-0.4 J0.0
    G2 Y0.2744 Z-0.2528 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.2674 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.2821 I-0.4 J0.0
    G2 Y0.2744 Z-0.2967 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.3113 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.3259 I-0.4 J0.0
    G2 Y0.2744 Z-0.3406 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.3552 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.3698 I-0.4 J0.0
    G2 Y0.2744 Z-0.3844 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.399 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.4137 I-0.4 J0.0
    G2 Y0.2744 Z-0.4283 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.4429 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.4575 I-0.4 J0.0
    G2 Y0.2744 Z-0.4722 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.4868 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.5014 I-0.4 J0.0
    G2 Y0.2744 Z-0.516 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.5307 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.5453 I-0.4 J0.0
    G2 Y0.2744 Z-0.5599 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.5745 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.5891 I-0.4 J0.0
    G2 Y0.2744 Z-0.6038 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.6184 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.633 I-0.4 J0.0
    G2 Y0.2744 Z-0.6476 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.6623 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.6769 I-0.4 J0.0
    G2 Y0.2744 Z-0.6915 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.7061 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.7208 I-0.4 J0.0
    G2 Y0.2744 Z-0.7354 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.75 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z0.25
    G1 F50.0 Z-0.75
    G2 F300.0 X-0.0324 Y0.2744 Z-0.757 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-0.7717 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.7863 I-0.4 J0.0
    G2 Y0.2744 Z-0.8009 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.8155 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.8302 I-0.4 J0.0
    G2 Y0.2744 Z-0.8448 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.8594 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.874 I-0.4 J0.0
    G2 Y0.2744 Z-0.8886 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.9033 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.9179 I-0.4 J0.0
    G2 Y0.2744 Z-0.9325 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.9471 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-0.9618 I-0.4 J0.0
    G2 Y0.2744 Z-0.9764 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-0.991 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.0056 I-0.4 J0.0
    G2 Y0.2744 Z-1.0203 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.0349 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.0495 I-0.4 J0.0
    G2 Y0.2744 Z-1.0641 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.0787 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.0934 I-0.4 J0.0
    G2 Y0.2744 Z-1.108 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.1226 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.1372 I-0.4 J0.0
    G2 Y0.2744 Z-1.1519 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.1665 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.1811 I-0.4 J0.0
    G2 Y0.2744 Z-1.1957 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.2104 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.225 I-0.4 J0.0
    G2 Y0.2744 Z-1.2396 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.2542 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.2688 I-0.4 J0.0
    G2 Y0.2744 Z-1.2835 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.2981 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.3127 I-0.4 J0.0
    G2 Y0.2744 Z-1.3273 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.342 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.3566 I-0.4 J0.0
    G2 Y0.2744 Z-1.3712 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.3858 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.4005 I-0.4 J0.0
    G2 Y0.2744 Z-1.4151 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.4297 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.4443 I-0.4 J0.0
    G2 Y0.2744 Z-1.4589 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.4736 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.4882 I-0.4 J0.0
    G2 Y0.2744 Z-1.5028 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.5174 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.5321 I-0.4 J0.0
    G2 Y0.2744 Z-1.5467 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.5613 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.5759 I-0.4 J0.0
    G2 Y0.2744 Z-1.5906 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.6052 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.6198 I-0.4 J0.0
    G2 Y0.2744 Z-1.6344 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.649 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.6637 I-0.4 J0.0
    G2 Y0.2744 Z-1.6783 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.6929 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.7075 I-0.4 J0.0
    G2 Y0.2744 Z-1.7222 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.7368 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.7514 I-0.4 J0.0
    G2 Y0.2744 Z-1.766 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.7807 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.7953 I-0.4 J0.0
    G2 Y0.2744 Z-1.8099 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.8245 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.8391 I-0.4 J0.0
    G2 Y0.2744 Z-1.8538 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.8684 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.883 I-0.4 J0.0
    G2 Y0.2744 Z-1.8976 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.9123 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.9269 I-0.4 J0.0
    G2 Y0.2744 Z-1.9415 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-1.9561 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-1.9708 I-0.4 J0.0
    G2 Y0.2744 Z-1.9854 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.0 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z-1.0
    G1 F50.0 Z-2.0
    G2 F300.0 X-0.0324 Y0.2744 Z-2.007 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-2.0217 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.0363 I-0.4 J0.0
    G2 Y0.2744 Z-2.0509 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.0655 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.0802 I-0.4 J0.0
    G2 Y0.2744 Z-2.0948 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.1094 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.124 I-0.4 J0.0
    G2 Y0.2744 Z-2.1386 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.1533 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.1679 I-0.4 J0.0
    G2 Y0.2744 Z-2.1825 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.1971 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.2118 I-0.4 J0.0
    G2 Y0.2744 Z-2.2264 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.241 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.2556 I-0.4 J0.0
    G2 Y0.2744 Z-2.2703 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.2849 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.2995 I-0.4 J0.0
    G2 Y0.2744 Z-2.3141 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.3287 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.3434 I-0.4 J0.0
    G2 Y0.2744 Z-2.358 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.3726 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.3872 I-0.4 J0.0
    G2 Y0.2744 Z-2.4019 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.4165 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.4311 I-0.4 J0.0
    G2 Y0.2744 Z-2.4457 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.4604 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.475 I-0.4 J0.0
    G2 Y0.2744 Z-2.4896 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.5042 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.5188 I-0.4 J0.0
    G2 Y0.2744 Z-2.5335 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.5481 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.5627 I-0.4 J0.0
    G2 Y0.2744 Z-2.5773 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.592 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.6066 I-0.4 J0.0
    G2 Y0.2744 Z-2.6212 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.6358 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.6505 I-0.4 J0.0
    G2 Y0.2744 Z-2.6651 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.6797 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.6943 I-0.4 J0.0
    G2 Y0.2744 Z-2.7089 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.7236 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.7382 I-0.4 J0.0
    G2 Y0.2744 Z-2.7528 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.7674 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.7821 I-0.4 J0.0
    G2 Y0.2744 Z-2.7967 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.8113 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.8259 I-0.4 J0.0
    G2 Y0.2744 Z-2.8406 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.8552 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.8698 I-0.4 J0.0
    G2 Y0.2744 Z-2.8844 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.899 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.9137 I-0.4 J0.0
    G2 Y0.2744 Z-2.9283 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.9429 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-2.9575 I-0.4 J0.0
    G2 Y0.2744 Z-2.9722 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-2.9868 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.0014 I-0.4 J0.0
    G2 Y0.2744 Z-3.016 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.0307 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.0453 I-0.4 J0.0
    G2 Y0.2744 Z-3.0599 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.0745 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.0891 I-0.4 J0.0
    G2 Y0.2744 Z-3.1038 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.1184 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.133 I-0.4 J0.0
    G2 Y0.2744 Z-3.1476 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.1623 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.1769 I-0.4 J0.0
    G2 Y0.2744 Z-3.1915 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.2061 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.2208 I-0.4 J0.0
    G2 Y0.2744 Z-3.2354 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.25 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z-2.25
    G1 F50.0 Z-3.25
    G2 F300.0 X-0.0324 Y0.2744 Z-3.257 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-3.2717 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.2863 I-0.4 J0.0
    G2 Y0.2744 Z-3.3009 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.3155 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.3302 I-0.4 J0.0
    G2 Y0.2744 Z-3.3448 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.3594 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.374 I-0.4 J0.0
    G2 Y0.2744 Z-3.3886 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.4033 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.4179 I-0.4 J0.0
    G2 Y0.2744 Z-3.4325 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.4471 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.4618 I-0.4 J0.0
    G2 Y0.2744 Z-3.4764 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.491 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.5056 I-0.4 J0.0
    G2 Y0.2744 Z-3.5203 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.5349 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.5495 I-0.4 J0.0
    G2 Y0.2744 Z-3.5641 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.5787 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.5934 I-0.4 J0.0
    G2 Y0.2744 Z-3.608 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.6226 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.6372 I-0.4 J0.0
    G2 Y0.2744 Z-3.6519 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.6665 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.6811 I-0.4 J0.0
    G2 Y0.2744 Z-3.6957 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.7104 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.725 I-0.4 J0.0
    G2 Y0.2744 Z-3.7396 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.7542 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.7688 I-0.4 J0.0
    G2 Y0.2744 Z-3.7835 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.7981 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.8127 I-0.4 J0.0
    G2 Y0.2744 Z-3.8273 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.842 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.8566 I-0.4 J0.0
    G2 Y0.2744 Z-3.8712 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.8858 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.9005 I-0.4 J0.0
    G2 Y0.2744 Z-3.9151 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.9297 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.9443 I-0.4 J0.0
    G2 Y0.2744 Z-3.9589 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-3.9736 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-3.9882 I-0.4 J0.0
    G2 Y0.2744 Z-4.0028 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.0174 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.0321 I-0.4 J0.0
    G2 Y0.2744 Z-4.0467 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.0613 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.0759 I-0.4 J0.0
    G2 Y0.2744 Z-4.0906 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.1052 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.1198 I-0.4 J0.0
    G2 Y0.2744 Z-4.1344 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.149 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.1637 I-0.4 J0.0
    G2 Y0.2744 Z-4.1783 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.1929 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.2075 I-0.4 J0.0
    G2 Y0.2744 Z-4.2222 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.2368 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.2514 I-0.4 J0.0
    G2 Y0.2744 Z-4.266 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.2807 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.2953 I-0.4 J0.0
    G2 Y0.2744 Z-4.3099 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.3245 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.3391 I-0.4 J0.0
    G2 Y0.2744 Z-4.3538 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.3684 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.383 I-0.4 J0.0
    G2 Y0.2744 Z-4.3976 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.4123 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.4269 I-0.4 J0.0
    G2 Y0.2744 Z-4.4415 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.4561 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.4708 I-0.4 J0.0
    G2 Y0.2744 Z-4.4854 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.5 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z-3.5
    G1 F50.0 Z-4.5
    G2 F300.0 X-0.0324 Y0.2744 Z-4.507 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-4.5217 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.5363 I-0.4 J0.0
    G2 Y0.2744 Z-4.5509 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.5655 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.5802 I-0.4 J0.0
    G2 Y0.2744 Z-4.5948 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.6094 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.624 I-0.4 J0.0
    G2 Y0.2744 Z-4.6386 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.6533 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.6679 I-0.4 J0.0
    G2 Y0.2744 Z-4.6825 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.6971 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.7118 I-0.4 J0.0
    G2 Y0.2744 Z-4.7264 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.741 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.7556 I-0.4 J0.0
    G2 Y0.2744 Z-4.7703 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.7849 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.7995 I-0.4 J0.0
    G2 Y0.2744 Z-4.8141 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.8287 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.8434 I-0.4 J0.0
    G2 Y0.2744 Z-4.858 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.8726 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.8872 I-0.4 J0.0
    G2 Y0.2744 Z-4.9019 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.9165 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.9311 I-0.4 J0.0
    G2 Y0.2744 Z-4.9457 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-4.9604 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-4.975 I-0.4 J0.0
    G2 Y0.2744 Z-4.9896 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.0042 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.0188 I-0.4 J0.0
    G2 Y0.2744 Z-5.0335 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.0481 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.0627 I-0.4 J0.0
    G2 Y0.2744 Z-5.0773 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.092 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.1066 I-0.4 J0.0
    G2 Y0.2744 Z-5.1212 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.1358 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.1505 I-0.4 J0.0
    G2 Y0.2744 Z-5.1651 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.1797 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.1943 I-0.4 J0.0
    G2 Y0.2744 Z-5.2089 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.2236 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.2382 I-0.4 J0.0
    G2 Y0.2744 Z-5.2528 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.2674 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.2821 I-0.4 J0.0
    G2 Y0.2744 Z-5.2967 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.3113 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.3259 I-0.4 J0.0
    G2 Y0.2744 Z-5.3406 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.3552 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.3698 I-0.4 J0.0
    G2 Y0.2744 Z-5.3844 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.399 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.4137 I-0.4 J0.0
    G2 Y0.2744 Z-5.4283 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.4429 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.4575 I-0.4 J0.0
    G2 Y0.2744 Z-5.4722 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.4868 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.5014 I-0.4 J0.0
    G2 Y0.2744 Z-5.516 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.5307 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.5453 I-0.4 J0.0
    G2 Y0.2744 Z-5.5599 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.5745 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.5891 I-0.4 J0.0
    G2 Y0.2744 Z-5.6038 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.6184 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.633 I-0.4 J0.0
    G2 Y0.2744 Z-5.6476 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.6623 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.6769 I-0.4 J0.0
    G2 Y0.2744 Z-5.6915 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.7061 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.7208 I-0.4 J0.0
    G2 Y0.2744 Z-5.7354 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.75 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z-4.75
    G1 F50.0 Z-5.75
    G2 F300.0 X-0.0324 Y0.2744 Z-5.757 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-5.7717 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.7863 I-0.4 J0.0
    G2 Y0.2744 Z-5.8009 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.8155 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.8302 I-0.4 J0.0
    G2 Y0.2744 Z-5.8448 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.8594 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.874 I-0.4 J0.0
    G2 Y0.2744 Z-5.8886 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.9033 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.9179 I-0.4 J0.0
    G2 Y0.2744 Z-5.9325 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.9471 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-5.9618 I-0.4 J0.0
    G2 Y0.2744 Z-5.9764 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-5.991 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.0056 I-0.4 J0.0
    G2 Y0.2744 Z-6.0203 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.0349 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.0495 I-0.4 J0.0
    G2 Y0.2744 Z-6.0641 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.0787 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.0934 I-0.4 J0.0
    G2 Y0.2744 Z-6.108 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.1226 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.1372 I-0.4 J0.0
    G2 Y0.2744 Z-6.1519 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.1665 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.1811 I-0.4 J0.0
    G2 Y0.2744 Z-6.1957 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.2104 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.225 I-0.4 J0.0
    G2 Y0.2744 Z-6.2396 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.2542 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.2688 I-0.4 J0.0
    G2 Y0.2744 Z-6.2835 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.2981 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.3127 I-0.4 J0.0
    G2 Y0.2744 Z-6.3273 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.342 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.3566 I-0.4 J0.0
    G2 Y0.2744 Z-6.3712 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.3858 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.4005 I-0.4 J0.0
    G2 Y0.2744 Z-6.4151 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.4297 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.4443 I-0.4 J0.0
    G2 Y0.2744 Z-6.4589 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.4736 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.4882 I-0.4 J0.0
    G2 Y0.2744 Z-6.5028 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.5174 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.5321 I-0.4 J0.0
    G2 Y0.2744 Z-6.5467 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.5613 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.5759 I-0.4 J0.0
    G2 Y0.2744 Z-6.5906 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.6052 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.6198 I-0.4 J0.0
    G2 Y0.2744 Z-6.6344 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.649 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.6637 I-0.4 J0.0
    G2 Y0.2744 Z-6.6783 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.6929 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.7075 I-0.4 J0.0
    G2 Y0.2744 Z-6.7222 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.7368 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.7514 I-0.4 J0.0
    G2 Y0.2744 Z-6.766 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.7807 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.7953 I-0.4 J0.0
    G2 Y0.2744 Z-6.8099 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.8245 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.8391 I-0.4 J0.0
    G2 Y0.2744 Z-6.8538 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.8684 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.883 I-0.4 J0.0
    G2 Y0.2744 Z-6.8976 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.9123 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.9269 I-0.4 J0.0
    G2 Y0.2744 Z-6.9415 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-6.9561 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-6.9708 I-0.4 J0.0
    G2 Y0.2744 Z-6.9854 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.0 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 X-0.2321 Y-0.0561
    G0 Z-6.0
    G1 F50.0 Z-7.0
    G2 F300.0 X-0.0324 Y0.2744 Z-7.007 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-7.0217 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.0363 I-0.4 J0.0
    G2 Y0.2744 Z-7.0509 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.0655 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.0802 I-0.4 J0.0
    G2 Y0.2744 Z-7.0948 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.1094 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.124 I-0.4 J0.0
    G2 Y0.2744 Z-7.1386 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.1533 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.1679 I-0.4 J0.0
    G2 Y0.2744 Z-7.1825 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.1971 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.2118 I-0.4 J0.0
    G2 Y0.2744 Z-7.2264 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.241 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.2556 I-0.4 J0.0
    G2 Y0.2744 Z-7.2703 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.2849 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.2995 I-0.4 J0.0
    G2 Y0.2744 Z-7.3141 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.3287 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.3434 I-0.4 J0.0
    G2 Y0.2744 Z-7.358 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.3726 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.3872 I-0.4 J0.0
    G2 Y0.2744 Z-7.4019 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.4165 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.4311 I-0.4 J0.0
    G2 Y0.2744 Z-7.4457 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.4604 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.475 I-0.4 J0.0
    G2 Y0.2744 Z-7.4896 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.5042 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.5188 I-0.4 J0.0
    G2 Y0.2744 Z-7.5335 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.5481 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.5627 I-0.4 J0.0
    G2 Y0.2744 Z-7.5773 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.592 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.6066 I-0.4 J0.0
    G2 Y0.2744 Z-7.6212 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.6358 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.6505 I-0.4 J0.0
    G2 Y0.2744 Z-7.6651 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.6797 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.6943 I-0.4 J0.0
    G2 Y0.2744 Z-7.7089 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.7236 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.7382 I-0.4 J0.0
    G2 Y0.2744 Z-7.7528 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.7674 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.7821 I-0.4 J0.0
    G2 Y0.2744 Z-7.7967 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.8113 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.8259 I-0.4 J0.0
    G2 Y0.2744 Z-7.8406 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.8552 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.8698 I-0.4 J0.0
    G2 Y0.2744 Z-7.8844 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.899 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.9137 I-0.4 J0.0
    G2 Y0.2744 Z-7.9283 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.9429 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-7.9575 I-0.4 J0.0
    G2 Y0.2744 Z-7.9722 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-7.9868 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.0014 I-0.4 J0.0
    G2 Y0.2744 Z-8.016 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.0307 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.0453 I-0.4 J0.0
    G2 Y0.2744 Z-8.0599 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.0745 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.0891 I-0.4 J0.0
    G2 Y0.2744 Z-8.1038 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.1184 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.133 I-0.4 J0.0
    G2 Y0.2744 Z-8.1476 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.1623 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.1769 I-0.4 J0.0
    G2 Y0.2744 Z-8.1915 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.2061 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.2208 I-0.4 J0.0
    G2 Y0.2744 Z-8.2354 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.25 I0.2 J-0.3464
    G2 F600.0 X-0.0324 Y-0.4184 I-0.4 J0.0
    G2 Y0.2744 I0.2 J0.3464
    G2 X0.5676 Y-0.072 I0.2 J-0.3464
    G1 X2.9676
    G2 X-1.2324 Y-2.4968 I-2.8 J0.0
    G2 Y2.3529 I1.4 J2.4249
    G2 X2.9676 Y-0.072 I1.4 J-2.4249
    G1 X5.3676
    G2 X-2.4324 Y-4.5753 I-5.2 J0.0
    G2 Y4.4314 I2.6 J4.5033
    G2 X5.3676 Y-0.072 I2.6 J-4.5033
    G1 X7.7676
    G2 X-3.6324 Y-6.6538 I-7.6 J0.0
    G2 Y6.5098 I3.8 J6.5818
    G2 X7.7676 Y-0.072 I3.8 J-6.5818
    G1 X10.1676
    G2 X-4.8324 Y-8.7322 I-10.0 J0.0
    G2 Y8.5883 I5.0 J8.6603
    G2 X10.1676 Y-0.072 I5.0 J-8.6603
    G1 X12.5676
    G2 X-6.0324 Y-10.8107 I-12.4 J0.0
    G2 Y10.6667 I6.2 J10.7387
    G2 X12.5676 Y-0.072 I6.2 J-10.7387
    G1 X14.9676
    G2 X-7.2324 Y-12.8891 I-14.8 J0.0
    G2 Y12.7452 I7.4 J12.8172
    G2 X14.9676 Y-0.072 I7.4 J-12.8172
    G1 X17.3676
    G2 X-8.4324 Y-14.9676 I-17.2 J0.0
    G2 Y14.8237 I8.6 J14.8956
    G2 X17.3676 Y-0.072 I8.6 J-14.8956
    G1 X19.7676
    G2 X-9.6324 Y-17.0461 I-19.6 J0.0
    G2 Y16.9021 I9.8 J16.9741
    G2 X19.7676 Y-0.072 I9.8 J-16.9741
    G1 X22.1676
    G2 X-10.8324 Y-19.1245 I-22.0 J0.0
    G2 Y18.9806 I11.0 J19.0526
    G2 X22.1676 Y-0.072 I11.0 J-19.0526
    G1 X24.5676
    G2 X-12.0324 Y-21.203 I-24.4 J0.0
    G2 Y21.059 I12.2 J21.131
    G2 X24.5676 Y-0.072 I12.2 J-21.131
    G0 Z50.0
    G0 Z-7.25
    G1 F50.0 Z-8.25
    G2 F300.0 X-0.0324 Y0.2744 Z-8.257 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-8.2717 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.2863 I-0.4 J0.0
    G2 Y0.2744 Z-8.3009 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.3155 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.3302 I-0.4 J0.0
    G2 Y0.2744 Z-8.3448 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.3594 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.374 I-0.4 J0.0
    G2 Y0.2744 Z-8.3886 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.4033 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.4179 I-0.4 J0.0
    G2 Y0.2744 Z-8.4325 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.4471 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.4618 I-0.4 J0.0
    G2 Y0.2744 Z-8.4764 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.491 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.5056 I-0.4 J0.0
    G2 Y0.2744 Z-8.5203 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.5349 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.5495 I-0.4 J0.0
    G2 Y0.2744 Z-8.5641 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.5787 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.5934 I-0.4 J0.0
    G2 Y0.2744 Z-8.608 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.6226 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.6372 I-0.4 J0.0
    G2 Y0.2744 Z-8.6519 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.6665 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.6811 I-0.4 J0.0
    G2 Y0.2744 Z-8.6957 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.7104 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.725 I-0.4 J0.0
    G2 Y0.2744 Z-8.7396 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.7542 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.7688 I-0.4 J0.0
    G2 Y0.2744 Z-8.7835 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.7981 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.8127 I-0.4 J0.0
    G2 Y0.2744 Z-8.8273 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.842 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.8566 I-0.4 J0.0
    G2 Y0.2744 Z-8.8712 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.8858 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.9005 I-0.4 J0.0
    G2 Y0.2744 Z-8.9151 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.9297 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.9443 I-0.4 J0.0
    G2 Y0.2744 Z-8.9589 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-8.9736 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-8.9882 I-0.4 J0.0
    G2 Y0.2744 Z-9.0028 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.0174 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.0321 I-0.4 J0.0
    G2 Y0.2744 Z-9.0467 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.0613 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.0759 I-0.4 J0.0
    G2 Y0.2744 Z-9.0906 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.1052 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.1198 I-0.4 J0.0
    G2 Y0.2744 Z-9.1344 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.149 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.1637 I-0.4 J0.0
    G2 Y0.2744 Z-9.1783 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.1929 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.2075 I-0.4 J0.0
    G2 Y0.2744 Z-9.2222 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.2368 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.2514 I-0.4 J0.0
    G2 Y0.2744 Z-9.266 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.2807 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.2953 I-0.4 J0.0
    G2 Y0.2744 Z-9.3099 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.3245 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.3391 I-0.4 J0.0
    G2 Y0.2744 Z-9.3538 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.3684 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.383 I-0.4 J0.0
    G2 Y0.2744 Z-9.3976 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.4123 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.4269 I-0.4 J0.0
    G2 Y0.2744 Z-9.4415 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.4561 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.4708 I-0.4 J0.0
    G2 Y0.2744 Z-9.4854 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.5 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z-8.5
    G1 F50.0 Z-9.5
    G2 F300.0 X-0.0324 Y0.2744 Z-9.507 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-9.5217 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.5363 I-0.4 J0.0
    G2 Y0.2744 Z-9.5509 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.5655 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.5802 I-0.4 J0.0
    G2 Y0.2744 Z-9.5948 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.6094 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.624 I-0.4 J0.0
    G2 Y0.2744 Z-9.6386 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.6533 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.6679 I-0.4 J0.0
    G2 Y0.2744 Z-9.6825 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.6971 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.7118 I-0.4 J0.0
    G2 Y0.2744 Z-9.7264 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.741 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.7556 I-0.4 J0.0
    G2 Y0.2744 Z-9.7703 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.7849 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.7995 I-0.4 J0.0
    G2 Y0.2744 Z-9.8141 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.8287 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.8434 I-0.4 J0.0
    G2 Y0.2744 Z-9.858 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.8726 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.8872 I-0.4 J0.0
    G2 Y0.2744 Z-9.9019 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.9165 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.9311 I-0.4 J0.0
    G2 Y0.2744 Z-9.9457 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-9.9604 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-9.975 I-0.4 J0.0
    G2 Y0.2744 Z-9.9896 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.0042 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.0188 I-0.4 J0.0
    G2 Y0.2744 Z-10.0335 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.0481 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.0627 I-0.4 J0.0
    G2 Y0.2744 Z-10.0773 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.092 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.1066 I-0.4 J0.0
    G2 Y0.2744 Z-10.1212 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.1358 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.1505 I-0.4 J0.0
    G2 Y0.2744 Z-10.1651 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.1797 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.1943 I-0.4 J0.0
    G2 Y0.2744 Z-10.2089 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.2236 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.2382 I-0.4 J0.0
    G2 Y0.2744 Z-10.2528 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.2674 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.2821 I-0.4 J0.0
    G2 Y0.2744 Z-10.2967 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.3113 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.3259 I-0.4 J0.0
    G2 Y0.2744 Z-10.3406 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.3552 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.3698 I-0.4 J0.0
    G2 Y0.2744 Z-10.3844 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.399 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.4137 I-0.4 J0.0
    G2 Y0.2744 Z-10.4283 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.4429 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.4575 I-0.4 J0.0
    G2 Y0.2744 Z-10.4722 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.4868 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.5014 I-0.4 J0.0
    G2 Y0.2744 Z-10.516 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.5307 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.5453 I-0.4 J0.0
    G2 Y0.2744 Z-10.5599 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.5745 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.5891 I-0.4 J0.0
    G2 Y0.2744 Z-10.6038 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.6184 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.633 I-0.4 J0.0
    G2 Y0.2744 Z-10.6476 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.6623 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.6769 I-0.4 J0.0
    G2 Y0.2744 Z-10.6915 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.7061 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.7208 I-0.4 J0.0
    G2 Y0.2744 Z-10.7354 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.75 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z-9.75
    G1 F50.0 Z-10.75
    G2 F300.0 X-0.0324 Y0.2744 Z-10.757 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-10.7717 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.7863 I-0.4 J0.0
    G2 Y0.2744 Z-10.8009 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.8155 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.8302 I-0.4 J0.0
    G2 Y0.2744 Z-10.8448 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.8594 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.874 I-0.4 J0.0
    G2 Y0.2744 Z-10.8886 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.9033 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.9179 I-0.4 J0.0
    G2 Y0.2744 Z-10.9325 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.9471 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-10.9618 I-0.4 J0.0
    G2 Y0.2744 Z-10.9764 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-10.991 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.0056 I-0.4 J0.0
    G2 Y0.2744 Z-11.0203 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.0349 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.0495 I-0.4 J0.0
    G2 Y0.2744 Z-11.0641 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.0787 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.0934 I-0.4 J0.0
    G2 Y0.2744 Z-11.108 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.1226 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.1372 I-0.4 J0.0
    G2 Y0.2744 Z-11.1519 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.1665 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.1811 I-0.4 J0.0
    G2 Y0.2744 Z-11.1957 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.2104 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.225 I-0.4 J0.0
    G2 Y0.2744 Z-11.2396 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.2542 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.2688 I-0.4 J0.0
    G2 Y0.2744 Z-11.2835 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.2981 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.3127 I-0.4 J0.0
    G2 Y0.2744 Z-11.3273 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.342 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.3566 I-0.4 J0.0
    G2 Y0.2744 Z-11.3712 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.3858 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.4005 I-0.4 J0.0
    G2 Y0.2744 Z-11.4151 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.4297 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.4443 I-0.4 J0.0
    G2 Y0.2744 Z-11.4589 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.4736 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.4882 I-0.4 J0.0
    G2 Y0.2744 Z-11.5028 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.5174 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.5321 I-0.4 J0.0
    G2 Y0.2744 Z-11.5467 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.5613 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.5759 I-0.4 J0.0
    G2 Y0.2744 Z-11.5906 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.6052 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.6198 I-0.4 J0.0
    G2 Y0.2744 Z-11.6344 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.649 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.6637 I-0.4 J0.0
    G2 Y0.2744 Z-11.6783 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.6929 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.7075 I-0.4 J0.0
    G2 Y0.2744 Z-11.7222 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.7368 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.7514 I-0.4 J0.0
    G2 Y0.2744 Z-11.766 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.7807 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.7953 I-0.4 J0.0
    G2 Y0.2744 Z-11.8099 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.8245 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.8391 I-0.4 J0.0
    G2 Y0.2744 Z-11.8538 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.8684 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.883 I-0.4 J0.0
    G2 Y0.2744 Z-11.8976 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.9123 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.9269 I-0.4 J0.0
    G2 Y0.2744 Z-11.9415 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-11.9561 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-11.9708 I-0.4 J0.0
    G2 Y0.2744 Z-11.9854 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.0 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z-11.0
    G1 F50.0 Z-12.0
    G2 F300.0 X-0.0324 Y0.2744 Z-12.007 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-12.0217 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.0363 I-0.4 J0.0
    G2 Y0.2744 Z-12.0509 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.0655 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.0802 I-0.4 J0.0
    G2 Y0.2744 Z-12.0948 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.1094 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.124 I-0.4 J0.0
    G2 Y0.2744 Z-12.1386 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.1533 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.1679 I-0.4 J0.0
    G2 Y0.2744 Z-12.1825 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.1971 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.2118 I-0.4 J0.0
    G2 Y0.2744 Z-12.2264 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.241 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.2556 I-0.4 J0.0
    G2 Y0.2744 Z-12.2703 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.2849 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.2995 I-0.4 J0.0
    G2 Y0.2744 Z-12.3141 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.3287 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.3434 I-0.4 J0.0
    G2 Y0.2744 Z-12.358 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.3726 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.3872 I-0.4 J0.0
    G2 Y0.2744 Z-12.4019 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.4165 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.4311 I-0.4 J0.0
    G2 Y0.2744 Z-12.4457 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.4604 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.475 I-0.4 J0.0
    G2 Y0.2744 Z-12.4896 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.5042 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.5188 I-0.4 J0.0
    G2 Y0.2744 Z-12.5335 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.5481 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.5627 I-0.4 J0.0
    G2 Y0.2744 Z-12.5773 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.592 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.6066 I-0.4 J0.0
    G2 Y0.2744 Z-12.6212 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.6358 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.6505 I-0.4 J0.0
    G2 Y0.2744 Z-12.6651 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.6797 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.6943 I-0.4 J0.0
    G2 Y0.2744 Z-12.7089 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.7236 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.7382 I-0.4 J0.0
    G2 Y0.2744 Z-12.7528 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.7674 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.7821 I-0.4 J0.0
    G2 Y0.2744 Z-12.7967 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.8113 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.8259 I-0.4 J0.0
    G2 Y0.2744 Z-12.8406 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.8552 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.8698 I-0.4 J0.0
    G2 Y0.2744 Z-12.8844 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.899 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.9137 I-0.4 J0.0
    G2 Y0.2744 Z-12.9283 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.9429 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-12.9575 I-0.4 J0.0
    G2 Y0.2744 Z-12.9722 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-12.9868 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.0014 I-0.4 J0.0
    G2 Y0.2744 Z-13.016 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.0307 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.0453 I-0.4 J0.0
    G2 Y0.2744 Z-13.0599 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.0745 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.0891 I-0.4 J0.0
    G2 Y0.2744 Z-13.1038 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.1184 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.133 I-0.4 J0.0
    G2 Y0.2744 Z-13.1476 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.1623 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.1769 I-0.4 J0.0
    G2 Y0.2744 Z-13.1915 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.2061 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.2208 I-0.4 J0.0
    G2 Y0.2744 Z-13.2354 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.25 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 Z-12.25
    G1 F50.0 Z-13.25
    G2 F300.0 X-0.0324 Y0.2744 Z-13.257 I0.3997 J-0.0159
    G2 X0.5676 Y-0.072 Z-13.2717 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.2863 I-0.4 J0.0
    G2 Y0.2744 Z-13.3009 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.3155 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.3302 I-0.4 J0.0
    G2 Y0.2744 Z-13.3448 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.3594 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.374 I-0.4 J0.0
    G2 Y0.2744 Z-13.3886 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.4033 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.4179 I-0.4 J0.0
    G2 Y0.2744 Z-13.4325 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.4471 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.4618 I-0.4 J0.0
    G2 Y0.2744 Z-13.4764 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.491 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.5056 I-0.4 J0.0
    G2 Y0.2744 Z-13.5203 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.5349 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.5495 I-0.4 J0.0
    G2 Y0.2744 Z-13.5641 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.5787 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.5934 I-0.4 J0.0
    G2 Y0.2744 Z-13.608 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.6226 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.6372 I-0.4 J0.0
    G2 Y0.2744 Z-13.6519 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.6665 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.6811 I-0.4 J0.0
    G2 Y0.2744 Z-13.6957 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.7104 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.725 I-0.4 J0.0
    G2 Y0.2744 Z-13.7396 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.7542 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.7688 I-0.4 J0.0
    G2 Y0.2744 Z-13.7835 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.7981 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.8127 I-0.4 J0.0
    G2 Y0.2744 Z-13.8273 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.842 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.8566 I-0.4 J0.0
    G2 Y0.2744 Z-13.8712 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.8858 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.9005 I-0.4 J0.0
    G2 Y0.2744 Z-13.9151 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.9297 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.9443 I-0.4 J0.0
    G2 Y0.2744 Z-13.9589 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-13.9736 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-13.9882 I-0.4 J0.0
    G2 Y0.2744 Z-14.0028 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.0174 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.0321 I-0.4 J0.0
    G2 Y0.2744 Z-14.0467 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.0613 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.0759 I-0.4 J0.0
    G2 Y0.2744 Z-14.0906 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.1052 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.1198 I-0.4 J0.0
    G2 Y0.2744 Z-14.1344 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.149 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.1637 I-0.4 J0.0
    G2 Y0.2744 Z-14.1783 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.1929 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.2075 I-0.4 J0.0
    G2 Y0.2744 Z-14.2222 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.2368 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.2514 I-0.4 J0.0
    G2 Y0.2744 Z-14.266 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.2807 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.2953 I-0.4 J0.0
    G2 Y0.2744 Z-14.3099 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.3245 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.3391 I-0.4 J0.0
    G2 Y0.2744 Z-14.3538 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.3684 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.383 I-0.4 J0.0
    G2 Y0.2744 Z-14.3976 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.4123 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.4269 I-0.4 J0.0
    G2 Y0.2744 Z-14.4415 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.4561 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.4708 I-0.4 J0.0
    G2 Y0.2744 Z-14.4854 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.5 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    G0 Z50.0
    G0 X0.2791 Y-0.4561
    G0 Z-13.5
    G1 F50.0 Z-14.5
    G2 F300.0 X-0.0324 Y-0.4184 Z-14.5056 I-0.1115 J0.3842
    G2 Y0.2744 Z-14.5203 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.5349 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.5495 I-0.4 J0.0
    G2 Y0.2744 Z-14.5641 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.5787 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.5934 I-0.4 J0.0
    G2 Y0.2744 Z-14.608 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.6226 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.6372 I-0.4 J0.0
    G2 Y0.2744 Z-14.6519 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.6665 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.6811 I-0.4 J0.0
    G2 Y0.2744 Z-14.6957 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.7104 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.725 I-0.4 J0.0
    G2 Y0.2744 Z-14.7396 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.7542 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.7688 I-0.4 J0.0
    G2 Y0.2744 Z-14.7835 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.7981 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.8127 I-0.4 J0.0
    G2 Y0.2744 Z-14.8273 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.842 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.8566 I-0.4 J0.0
    G2 Y0.2744 Z-14.8712 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.8858 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.9005 I-0.4 J0.0
    G2 Y0.2744 Z-14.9151 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.9297 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.9443 I-0.4 J0.0
    G2 Y0.2744 Z-14.9589 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-14.9736 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-14.9882 I-0.4 J0.0
    G2 Y0.2744 Z-15.0028 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.0174 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.0321 I-0.4 J0.0
    G2 Y0.2744 Z-15.0467 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.0613 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.0759 I-0.4 J0.0
    G2 Y0.2744 Z-15.0906 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.1052 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.1198 I-0.4 J0.0
    G2 Y0.2744 Z-15.1344 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.149 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.1637 I-0.4 J0.0
    G2 Y0.2744 Z-15.1783 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.1929 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.2075 I-0.4 J0.0
    G2 Y0.2744 Z-15.2222 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.2368 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.2514 I-0.4 J0.0
    G2 Y0.2744 Z-15.266 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.2807 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.2953 I-0.4 J0.0
    G2 Y0.2744 Z-15.3099 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.3245 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.3391 I-0.4 J0.0
    G2 Y0.2744 Z-15.3538 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.3684 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.383 I-0.4 J0.0
    G2 Y0.2744 Z-15.3976 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.4123 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.4269 I-0.4 J0.0
    G2 Y0.2744 Z-15.4415 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.4561 I0.2 J-0.3464
    G2 X-0.0324 Y-0.4184 Z-15.4708 I-0.4 J0.0
    G2 Y0.2744 Z-15.4854 I0.2 J0.3464
    G2 X0.5676 Y-0.072 Z-15.5 I0.2 J-0.3464
    G1 X2.9676
    G1 X5.3676
    G1 X7.7676
    G1 X10.1676
    G1 X12.5676
    G1 X14.9676
    G1 X17.3676
    G1 X19.7676
    G1 X22.1676
    G1 X24.5676
    ( Inside profile )
    S13000
    G0 Z50.0
    G0 X30.7176
    G0 Z16.5
    G1 F100.0 Z0.0
    G2 F1000.0 X-15.1074 Y-26.529 I-30.55 J0.0
    G2 Y26.3851 I15.275 J26.4571
    G2 X30.7176 Y-0.072 I15.275 J-26.4571
    G1 F100.0 Z-15.5
    ( 4mm slot )
    G0 Z50.0
    ( T2 : 4.0 )
    T2 M6
    M3 S18000
    G0 X-28.7404 Y-0.1292
    G0 Z16.5
    G1 F50.0 Z15.5
    G1 F300.0 X-46.7404 Y-0.095 Z14.5
    G1 F800.0 X-28.7404 Y-0.1292
    G1 F300.0 X-46.7404 Y-0.095 Z13.5
    G1 F300.0 X-46.7404 Y-0.095 Z12.5
    G1 F300.0 X-46.7404 Y-0.095 Z11.5
    G1 F300.0 X-46.7404 Y-0.095 Z10.5
    G1 F300.0 X-46.7404 Y-0.095 Z9.5
    G1 F300.0 X-46.7404 Y-0.095 Z8.5
    G1 F300.0 X-46.7404 Y-0.095 Z7.5
    G1 F300.0 X-46.7404 Y-0.095 Z6.5
    G1 F300.0 X-46.7404 Y-0.095 Z5.5
    G1 F300.0 X-46.7404 Y-0.095 Z4.5
    G1 F300.0 X-46.7404 Y-0.095 Z3.5
    G1 F300.0 X-46.7404 Y-0.095 Z2.5
    G1 F300.0 X-46.7404 Y-0.095 Z1.5
    G1 F300.0 X-46.7404 Y-0.095 Z0.5
    G1 F300.0 X-46.7404 Y-0.095 Z-0.5
    G1 F300.0 X-46.7404 Y-0.095 Z-1.5
    G1 F300.0 X-46.7404 Y-0.095 Z-2.5
    G1 F300.0 X-46.7404 Y-0.095 Z-3.5
    G1 F300.0 X-46.7404 Y-0.095 Z-4.5
    G1 F300.0 X-46.7404 Y-0.095 Z-5.5
    G1 F300.0 X-46.7404 Y-0.095 Z-6.5
    G1 F300.0 X-46.7404 Y-0.095 Z-7.5
    G1 F300.0 X-46.7404 Y-0.095 Z-8.5
    G1 F300.0 X-46.7404 Y-0.095 Z-9.5
    G1 F300.0 X-46.7404 Y-0.095 Z-10.5
    G1 F300.0 X-46.7404 Y-0.095 Z-11.5
    G1 F300.0 X-46.7404 Y-0.095 Z-12.5
    G1 F300.0 X-46.7404 Y-0.095 Z-13.5
    G1 F300.0 X-46.7404 Y-0.095 Z-14.5
    G1 F300.0 X-46.7404 Y-0.095 Z-15.5
    G0 Z50.0
    M5
    M30
    Wow dudz I meant post a txt file not the whole 10 million lines of code. . Lol
    Give me 5 and I'll flick thru it.!
    dudz's Avatar
    Lives in Dunedin, New Zealand. Current Activity: Viewing Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    sorry, not sure how to do that
    Nope nothing wrong there all the Z retract and X & Y reposition moves are done at G0 rapid feeds. The feeds in the code are on the low side but I presume you have choose those feeds.?
    Are you having this problem while it's running the G-code and changing position ie say cutting several pockets or when sending machine to Home position when finished.?
    dudz's Avatar
    Feed for 6mm single flute = 600
    Spiral down at 300
    I thought that was about right in Aluminium ?.
    usually both, but def when going between pockets etc...
Page 1 of 3 123 LastLast
  1. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Z safe in g code question
    By Fivetide in forum CAD & CAM Software
    Last Post: 20-02-2013, 08:00 PM
  4. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  5. Safe Z Arghhhhhhhh!! Whats going on!
    By AdCNC in forum Machine Discussion
    Last Post: 18-08-2009, 05:15 PM
