Page 3 of 8 FirstFirst 12345 ... LastLast
  1. #21
    Quote Originally Posted by komatias View Post
    Mike, Yes they do. Should have some grease nipples...(hehe) on the side. I like to use moly bearing grease for high load applications, this is commonly known as CVjoint grease too. Do not go crazy though so you can at least make an attempt to keep the rails clean of dust/grease gunk. Frequency depends on use, gut feel indication would be 1/month for occasional use, 1/week for heavy use.
    R's
    I'm not sure about SBR16UU type blocks having grease nipples. External features on the sides of these always look like grub screws to hold the bearing in place. I've not re-greased mine and they've been running fine for years. Where possible I think you would have to slide the relevant axis off the rails to smear some grease onto the balls and that involves quite a strip down. It wouldn't hurt to give them a very light smear of moly grease before assembly:
    But Hiwin style blocks do have them and you can grease them if you can get to them, but you are not using that type:
  2. The Following User Says Thank You to routercnc For This Useful Post:
  3. #22
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Admin Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    No they don't have them :(, the side grub is for taking out any slop allowing you to preload them just right on the TBR units, they also have a locating grub in the top that I think is for locating the bearing unit it's self.
    I thought about engineering up oil lines on too each housing, that would allow the oil to drip directly on to the top of the rail as it passes in to the bearing unit, though I thought for the effort it's probably not much of a job just to oil the rails as you need to manually...
    .Me
    .Me
  4. #23
    Thanks Lee, Routernc and Komatias
    I've not been able to find any info on the web about lubricating these SBRXXUU linear slide bearings. So I might just have to grease / oil the rails (lightly) I guess. I found a useful source for the ballscrew grease (Mobilux EP2) ( here) and much cheaper than Ma*Di* who charge £12 for a 50ml syringe! The tech support guy at Simply Bearings is making enquiries for me , so if I get a reply I'll post it here.
    I hope to start on the electronics soon - within the next 3 weeks, so more questions and photos to come. Thanks to Jazz for posting a solution for the safety circuit and the use of proximity switches for homing. Now I understand how to wire the emergency stop system!
  5. #24
    My bearings are the SBR16UU and I did put grease nipples on side and grease them with the gun mine had no grub on the side only on top side was open, if Lee is correct I may have made an error but the grease certainly arrived where expected, having removed Z axis at one point for adjustment bearings were nicely coated and operation has certainly been slightly quieter since application, at extremes of travel a minor grease line appears at wipes max reach is apparent. I did have some paperwork with the two boxes of chinese bearings recieved in chinese so not read but picture showed top grub for loading bearing and side had grease gun aligned hence my judgement to add nipples and grease. Would be interesting to hear any thoughts if I can find paper recieved with mine will scan and add here, although it may well have been recycled as being of little use.
  6. The Following User Says Thank You to lucan07 For This Useful Post:
  7. #25
    Quote Originally Posted by MikeyC38 View Post
    Just get yourself some lithium 2 grease and that will be fine, it's cheap as well.
    Just consider the bearings glorified skate bearings because that's all they are really, so don't require anything specialised unless you really want to make the effort, grease will last longer than oil but obviously it gets gummy once contaminated and so on, but again the wipers on these units do quite a good job at keeping the raceways clear of foreign bodies.
    I could be wrong on the side grubscrew being there for greasing, they may have improved the design or something but all the open type bearing cages I've handled were closed on the casing, I'll have a look shortly on the TBR I've got here and take some pics but I'm confident on those being closed...
    Edit: Just looked at the EP2 you linked, it says "is a premium quality multi-purpose, lithium-base NLGI No 2 grease".
    The stuff I can get is a multipurpose NLGI lithium 2 grease but it's only £3.50 a tube and doesn't have a major brand name to inflate the price:
    A Premium quality mineral oil, lithium thickened lubricating grease suitable for general purpose applications in plain and anti-friction bearings.
    Conforms to leading bearing manufacturers specifications for general purpose industrial and automotive grease.
    Can send you a tube if you want, I've been using it for everything and for years with np.
    .Me
    .Me
  8. #26
    Thanks Lee for the comment. From my research a lot of ball screw manufacturers recommend the Mobilux EP2 for their ball nuts @ 0.8-1.0ml per 10mm of ball screw diameter, so that's the only reason why I'm choosing it. However £3.50 is much cheaper so I'll have a look around for alternatives as you have suggested. For my 1605 screws this works out to around 1.5ml per ball nut per axis. The SBR16UU and SBR20UU have a side screw but I believe this is for adjustment / pre-loading as you have already said.
  9. #27
    See my edit above ^^
    .Me
  10. The Following User Says Thank You to Lee Roberts For This Useful Post:
  11. #28
    Hi Lee.
    I'll contact you via PM
    Mike
  12. #29
    Had a look for my bearings documentation but could not find picture but did find this one online from same supplier same as picture which was on leaflet which got recycled except for being open bearing for supported rail. As it goes the fact that they all used to be sealed helps me, I have removed nipples on Z axis can always pop one in annualy to grease them again, but they got in the way a little as I hadn't allowed for them.
  13. The Following User Says Thank You to lucan07 For This Useful Post:
  14. #30
    Some more pictures of the build. I've been ill since September 2015 and thus made no progress until March 2016. But the Z axis is in place and moves nicely in the Y axis!
    BTW does anybody know if SBRUU linear bearings have to be lubricated? and if so, with what type of lubricant and how frequently?
    Thanks Everyone for the help and inspiration so far!
    Mike
    I have done the initial stages of the electronics build and the stepper motors have be attached to the machine. I have a video of it working (albeit at a modest 1m/min) until I've done the following:
    1) Limit Switches
    2) E-Stop connected to relay to cut power and signal Mach 3 (rather than signal Mach3 first)
    3) Proximity home switches
    Again thanks to Dean for posting a great schematic of how to do a 24V dc e-stop system. What would we newbies do without your help (and ). And to Lee for the steer on grease for the ballscrews.
    Expect to have above done by mid october so I can start doing the tramming etc.
    In the interim I posted another picture with the spindle mounted (just to show that I am making progress!)
ID:	19249Click image for larger version.
    Wish me luck boys!
  15. The Following User Says Thank You to MikeyC38 For This Useful Post:
  2. Setup for squaring twin X-axis gantry
    By routercnc in forum Gantry/Router Machines & Building
    Last Post: 26-03-2014, 11:13 PM
  3. BUILD LOG: New build - fixed gantry mill using extruded profile
  4. NEW MEMBER: New Member build finally started in Oxfordshire
    By pjchick in forum New Member Introductions
    Last Post: 26-11-2010, 04:02 PM
