    Hi guys 0/
    I'm doing some small boxes 110 mm x 66 mm buy 30 mm deep, out of hard wood. I want to give it a nice round over as the boxes will be hand held. But I'm not sure what to use. I have a full router table and looked at the trend bits, the smallest I could find was :
    Dimensions:
    D=19 mm
    C=3/8 inch
    C=9.5 mm
    B=9.5 mm
    B2=12.7 mm
    R=1/8 inch
    R=3.2 mm
    Shank Diameter=8 mm
    I think 3.2 Radius might be to large, I'm really only trying to take of the sharp edges but I want it neat and sanding is a bit hit and miss.
    Any suggestions on a bit that could work, I don't need it to be self guiding I can set the fence up to guide along.
    Five
    Ralph Waldo Emerson
    Hi Fivetide
    Long time no hear.
    I got some small bearing guided roundover bits for doing the same job on Spilka spec windows i made for the house. Think i got them from Wealden tools.
    Regards
    Mike
    If you can't find a smaller roundover maybe you could use a 45 degree cutter and adjust the fence so it was just skimming the arris.
    2.4mm radius
    http://www.trenddirectuk.com/mb-06x1-4tc.html
    Or you could make your own 'scratch stock' from an old hacksaw blade
    Just use a portion of the edge of Ogee or Ovolo cutter like Roman ogee or bead ovolo or maybe some other formed tool. It won't give full round over but just breaks the sharp edge.
    Hi Fivetide
    Long time no hear.
    Regards
    Mike
    Thanks guys .. as usual excellent advice :)
    Yeah Mike been a while .. had to actually go back to work lol .. bummer ! But I've started puting together a new workshop at my dads house.. bought a small metal lathe as a Christmas present still have the Black Cat CNC.. messing as I always do with ideas :)
    Eddy , thats the baby ! I'll try and find one on ebay.. :)
    Ralph Waldo Emerson
    You can get bearing guided 1/16" roundover bits.
    Most major manufacturers make them.
    http://www.boschtools.com/Products/A...d=85289M#specs
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    wow even better , thanks Ger21
    Ralph Waldo Emerson
    http://www.ebay.co.uk/itm/1-4-Shank-...65517985&rt=nc
    GBP 2.93 all the way from sunny China, 1/8" rad just adjust hight and fence so it breaks the corner to your satisfaction.
    Mike
    OK, I am confused here, not difficult I know but.........
    What is the function of the bearing when used on a CNC machine?, surely it is not needed??, not like on a hand held router, or am I missing something here like I usually do??
  1. Replies: 11
    Last Post: 01-06-2014, 04:40 PM
  2. NEW MEMBER: tiny
    By tiny in forum New Member Introductions
    Last Post: 02-05-2013, 10:15 PM
  3. WANTED: Need a tiny bit of work done on lathe
    By Tenson in forum Items Wanted
    Last Post: 28-02-2013, 12:22 AM
  4. Tiny tool feedrates
    By Robin Hewitt in forum General Discussion
    Last Post: 08-09-2010, 02:48 PM
  5. This tiny keyboard might come in handy :)
    By Smiler in forum Gantry/Router Machines & Building
    Last Post: 28-12-2009, 06:30 PM
