I have pneumatic cylinder on on milling machine tool changer that has a leaking internal seal. It works on the outward stroke but air exhausts out of the back valve on the return stroke.
Does anyone know if I could replace the internal seal on this cylinder?
If not does anyone have a spare lying around?
The cylinder is a Joucomatic Isoclair 435 50 438 c 25 A 150 (P max 140psi)
27-10-2015 #3
Hi Chaz, thanks I have been quoted £70 delivered, was yours source any cheaper? Thanks
This is what I paid. My actuator is not 'soft stopping', so doesnt have the adjustment at the end of the travel but still works none the less.
1off - 25mm Bore x 160mm Stroke D/Acting Pneumatic Cylinder @ £40.39
1off - 3 Station Solenoid Valve Manifold @ £24.71
3off - 1/4"bsp 5/2 Solenoid/Spring Valve 110v c/w Led DinPlug @ £27.00 each
(*The easiset option for the 3 way valve is to use a 5 way and blank one of the outlets)
4off - 1/4"bsp x 6mm Straight Adaptor @ £0.65 each (Manifold Inlet & Vent / Outlet for 3 way Valve)
4off - 1/4"bsp x 4mm Straight Adaptor @ £0.65 each (Outlets for 5 way Valves)
4off - 1/4"bsp Blanking Plug @ £0.60 each (1off for 3 way valve / 3off for blanking one side of valve manifold)
1off - Carriage @ £10.00
Total @ £163.70 + Vat
The supplier details are:-
Shelley Automation Ltd
Block One
Nortonthorpe Mills
Scissett
Huddersfield
HD8 9LA
Tel: 01484 860920
Fax: 01484 860672
Email: [email protected]
VAT: 694 8526 78
17-11-2015 #5
Thanks for the replies.
Went to my local pneumatic supplier in Bristol(Harrier Pneumatics) and got a Parker PIA-5025MS-0150 as a direct replacement for £64.
ATC is working fine now.
FOR SALE: Denford Triac
By asto in forum Items For SaleReplies: 19Last Post: 07-02-2016, 08:28 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
RFQ: Triac / Mach 3 help
By suesi34e in forum Projects, Jobs & RequestsReplies: 0Last Post: 10-08-2013, 01:59 PM -
WANTED: Wanted Denford Triac CNC Mill
By angusnoble in forum Items WantedReplies: 1Last Post: 15-07-2012, 06:45 PM -
FOR SALE: Univer pneumatic cylinder
By m_c in forum Items For SaleReplies: 0Last Post: 18-12-2008, 09:27 PM
