I have made some more space in my enclosure. The 48V PSU now mounts on the outside of the enclosure back panel. I have made up a box with appropriate venting to enclose it. I even painted it the same colour. This will make a big difference to the space I have to play with inside.
I decided it was "Out of the box thinking". LOL..Clive
28-11-2015 #2
28-11-2015 #3
If your going to have Inaccurate home switches then there's no point having them at all really.! . . The whole point is accurecy and repeatabilty and you'll lose this thru a relay.
If the KK01 can accept 24V then it's simple just drop the relay and put resistor in series. It's the weak 5v signal that's the main issue so removing this removes the problems with sharing switches and complexity of using a relay.
If your planning on sharing switches for both then make it even simpler and make the Switches Travel with axis then sense adustable Targets at each end. This way only need 3 switches and one Input total.
Prox swithces are much better than Micro switches and cost about £1.50 so it's cheap as chips.!
The Following 3 Users Say Thank You to JAZZCNC For This Useful Post:
28-11-2015 #4
Where can I buy Prox switches for £1.50?
28-11-2015 #5
Well here's one £1.40 http://www.ebay.co.uk/itm/LJ12A3-4-Z...kAAOSwvt1WQ~SR
Look harder and you'll buy several of them working out at roughly £1
Here's the very switch I tested to show how well they work on a router.
28-11-2015 #6
Excellent. I like your idea that sounds better and much more accurate.
What confused me was this diagram in the KK01 manual showing that I might need to put extra resistors in the driver wiring as well if I was running 24v through the KK01.
That put me off.
Excuse me for being dumb again, what are the prox switches actually looking for - a magnet (target wise)?
I've looked and can't find any info.
Look what I got this afternoon - happy days!
My cousin cut them for me in his engineering shop.
The CNC mills he's got are serious.
They are perfect the bearings have dropped in beautifully.
So I can start building my machine now.
Thanks Jazz for your excellent input.
MartinLast edited by mturneruk; 28-11-2015 at 06:42 PM.
28-11-2015 #7
Strange, i have asked Ebay (but only for P. switch without sensor) and the lowest price was £3.60.
28-11-2015 #8
28-11-2015 #9
Nothing dumb in not under standing. Would be dumb if you didn't understand and Didn't ask.!!
They are Inductive sensors so they sense Metal. You can get Sensors that detect Magnets Called HALL Affect sensors. Both are used to do the same job in different conditions.
Inductive are good for routers because no flying metal chips but on a Mill not so good.!
28-11-2015 #10
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
