    Couple of little projects I made a few weeks back - thought I'd share them here.
    First up is a DTI holder to make it easier to clock the vice.
    Started with a scrap bit of aluminium and marked it out, drilled some holes, and did a trial fit:
    Seems OK so trimmed it to size:
    And there we are. Makes clocking the vice a bit easier - I used various clamps and bolts before and it took a while to set up. Now it is ready in moments:
    ________________________________________
    Second little project is a touch probe. This is a piece if PCB board superglued to a block of aluminium. The PCB provides electrical isolation from the machine bed (otherwise the probe would be active all the time). I glued it to the block to give it some weight to hold it in place, and the PCB was not super flat.
    I've already glued the board to the block, and sized the block around the perimeter prior to this photo.
    Here is the block depth being skimmed to as close to 10mm as possible. Actual dimension is not critical as long as it is flat but 10mm is easy to remember!
    Then I soldered on a cable, and used a sleeve to finish it off. The other cable had a crocodile clip added to clip to the spindle mount to make the circuit when probing.
    Here is it in use to set the Z height from the surface. I use mach3 screenset 2010 and tell the software that the block is 10mm thick. Then in the probing function hit one button and it does the probing and sets it all automatically.
    I've also used in to set the X and Y zero on the edges of parts but it can be tricky to hold it in position whilst probing. Sometimes it will sit nicely on the vice jaw.
    I'm sure many of you have your own versions - let's see them !
    > Hi Lee, if you manage to catch this post would you be able to put it on the end of this 'inspiration' one? Only occurred to me after I'd posted that it would be better there. No worries if not:
    http://www.mycncuk.com/threads/9273-...small+projects
    Last edited by routercnc; 31-12-2015 at 10:47 PM. Reason: request to move post to another thread
  1. Mitre saw clamp
    By routercnc in forum Metalwork Project Showcase
    Last Post: 20-04-2018, 06:08 PM
  2. MSC Clamp set offer
    By mekanik in forum Workshop & Equipment
    Last Post: 12-01-2015, 07:25 PM
  3. what's the name of this clamp and where to get it in the UK
    By dsc in forum Tool & Tooling Technology
    Last Post: 27-12-2014, 02:06 AM
  4. Clamp table
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 03:03 AM
  5. Step clamp
    Last Post: 14-10-2008, 02:39 AM
