Thread: Isel CPM 3020 - run with mach3?
17-06-2018 #61
Ok i'm at the final point, i think..
but I am a little confused, i'm a newbie to setting up my own controller..
The BoB I has (+5V, EN, DIR, and STEP) the Drivers has (Pull + / -, DIR + /-, and ENA + / -)
I know the BoB EN = ENA on the Driver, DIR = DIR + on the driver and STEP = Pull + on the driver.. but what do I do with the extra 5V on the BoB?
Thanks for the help!
17-06-2018 #62
Hi guys,
Sorry for the lack of reply Steve. I just came on here to ask a question and saw your message.
I used the existing power supply. I didn’t need to rewire anything. I just chopped the wires (turned off of course!) and then used my multimeter to figure what voltage each of the lines were! I can’t remember what they were exactly but they were good enough for what I needed.
I have to say Steve that although I’ve taken on a few cnc projects I really am wading my way through murky waters! I can’t really help on the stepper wiring but I distinctly remember testing the wires (using s YouTube guide) to figure out which were the pairs. The motors work great for my needs!
Good luck with it, I’ll pop back on here but I’ve also just got your email so do email back if you need anything.
ChrisLast edited by craynerd; 17-06-2018 at 10:25 PM.
18-06-2018 #63
I too, used the existing power supply. It had three different voltages available. Most useful. Similarly to Chris I coupled my 4 wire steppers to the original cabling inside the aluminium stepper covers and then again to my drivers in the control box. The logic is quite simple and straightforward. I am no sparky and was more worried before than after. Just go for it. Think you will find the Isel hardware is well worth preserving.Extremely impressed with the accuracy and repeatability of my 850/1000 machine.
18-06-2018 #64
I was able to get the X and Y axis running last night.. I will hopefully have enough time tonight to finish the Z axis.. I'm still not sure on how to setup the micro stepping and the motor velocity in mach3 (cause I don't know what values to use)
Anyway, here it is moving.. https://youtu.be/iSry6ZRe8bI
21-06-2018 #65
Well I got everything wired up as far as limit switches and motors / drivers go.. everything moves and stop when a limit switch is touched..
tonight ill be installing the relay (router control) and maybe make the first chips..
22-06-2018 #66
Well I'm all done with this conversion..
https://youtu.be/sR1u89dEdgc
Thanks for helping!
24-06-2018 #67
Hello do you still have kay soft + licence?
Br.Dariosh
24-06-2018 #68
Sorry - Sold some time ago.
The Following User Says Thank You to Leadhead For This Useful Post:
25-06-2018 #69
Well I thought I was done, but it seems like the microstepping I have set aren't working right.. This is also going to be a pain since the lead screw is in metric, but we use imperial on this side of the pond..
Anywho.. I thought I had everything configured properly, but the x axis keeps skipping a step randomly..
25-06-2018 #70
Are you sure all vectors are connected/joined together?
Phill
Vevor 3020 cnc Autolevelling
By iBeta in forum Machine DiscussionReplies: 8Last Post: 22-11-2015, 07:08 PM -
DIY 3020 CNC I/O Board
By Pointy in forum Electronic Project BuildingReplies: 10Last Post: 27-07-2015, 10:48 PM -
NCStudio to Mach3 question for a chinese 3020 router
By Fivetide in forum Chinese MachinesReplies: 3Last Post: 11-04-2015, 10:37 PM -
is a cnc 3020 right for the jobs i need doing
By RsvRcarl in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 28-03-2012, 01:34 AM -
Improving your CNC3040/3020
By DanielF in forum Motor Drivers & ControllersReplies: 0Last Post: 22-11-2011, 01:48 PM
