The System that we seem to use over here is the Wests System 105 / 209 http://www.westsystem.com/ss/use-guides/
it is a very slow curing hardener about 10 hours but you have to be careful with the temperature.
https://www.ecfibreglasssupplies.co....t-system-epoxyLast edited by Clive S; 05-04-2018 at 08:32 AM.
05-04-2018 #2
That link you posted doesn't seem to have the 209 either! The only place I've seen it listed only has the 1.45kg tin and I don't want to buy a big one as it's just a waste. I may have to price up importing it. I just don't understand why the 209 is so hard to get when all the others seem readily available.
Sent from my SM-G950F using Tapatalk
05-04-2018 #3
edit try here:- https://www.boatpaint.co.uk/acatalog...eners_213.htmlLast edited by Clive S; 05-04-2018 at 06:54 PM.
05-04-2018 #5
checkout dansonmarine on ebay.
https://m.ebay.nl/itm/282845732420
They stock it sometimes.
Grtz Bert.
1.3 kg A Pack
The Following User Says Thank You to driftspin For This Useful Post:
05-04-2018 #6
Cheers Clive and Bert, Clive that was exactly what i was looking for :)
One more thing...... Can you check my calculations to make sure I'm right
2 rails 135cm x 4cm wide + 2 bridges @ 77.5cm x 4cm with depth of 6mm
(135+135+77.5+77.5)X4X0.6 = 1020cm3 = 1.02 Litres
1.02 Litres / 4 = 0.255 Litres 209 Hardener
@3:1 ratio by volume = 0.765 Litres of Resin.
Seems the weights are not quite 1 litre to 1 Kg as the manual states the ratio is 3.5:1 by weight.
Regards,
Charlie
05-04-2018 #7
05-04-2018 #8
Frame is steel, Gantry is all aluminium
http://www.mycncuk.com/threads/7733-...-router-design
I started it nearly 4 years ago!
05-04-2018 #9
The math is sound :-)
I found that my box section 1850x120x80x4 mm was + 2 mm bend in the middle by welding heat.
I had a +/- 1mm error in spirit level. over 1850 mm...
It all add up. so 6mm thickness... i am not sure.. i did not have the best of spirit levels
So on the ends i have 8 and 7 mm thickness now.. 5.5 or so in centre.
I had some leaks while pouring.
Mostly because of heat from the shop heater on the channel sides.
Wood dried and bended.
Can see through under the square rails through the epoxy now
Make sure to use packing tape on the sides ... best tip ever.
Ok hope this helps.
I have steel gantry so more pouring on there for me.
Get the A pack.. it is 50 gbp or so.
Grtz Bert.
If you like to gamble a little...
Carbonwinkel.nl is where i bought.
Google translate is your friend here.
GLS delivered from German warehouse.
w300 5 hour potlife @ 75euro for 3kg.
Has about the same spec compared to 105 209
First day you think it is never going solid
05-04-2018 #10
Self levelling epoxy resin
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 21-11-2020, 01:47 AM -
Use of epoxy for levelling
By Neale in forum Gantry/Router Machines & BuildingReplies: 102Last Post: 25-08-2019, 04:21 PM -
epoxy question
By driftspin in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 24-06-2017, 01:44 PM -
Sand and Resin Filling Box Section
By grain_r in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 16-12-2015, 08:45 PM
