Thread: Why Ethernet instead of USB?
05-04-2018 #11You think that's too expensive? You're not a Model Engineer are you? :D
05-04-2018 #12
The point of that was to address an earlier comment that Ethernet provides error correction - which is certainly not a part of the lower comm layers. In fact, TCP/IP doesn't provide error correction - merely a retry mechanism.
TCP/IP isn't the be-all/end-all. For the last few years I've been involved in an engineering activity centred around UDP.
:DLast edited by Doddy; 05-04-2018 at 08:16 PM.
05-04-2018 #13
Funny, I never get a failed/partial file download because of missing packets ;-)
I think you're pointing out the minor shortcomings in a system which have no impact whatsoever on the application being discussed :DYou think that's too expensive? You're not a Model Engineer are you? :D
05-04-2018 #15
Smilies are wasted on some people :D
The Following User Says Thank You to m_c For This Useful Post:
05-04-2018 #16
Pci or Ethernet motion control?
By Ross77 in forum Machine Control SoftwareReplies: 27Last Post: 16-10-2019, 08:27 PM -
Any USB/Ethernet controller suggestions?
By jtar40 in forum Motor Drivers & ControllersReplies: 64Last Post: 15-05-2019, 07:58 PM -
WANTED: Ethernet Smooth Stepper
By davidimurray in forum Items WantedReplies: 3Last Post: 08-10-2017, 02:29 PM -
UC300 Ethernet
By noyloj in forum CNCdrive (UC100, UC300ETH)Replies: 12Last Post: 02-01-2017, 10:21 PM -
Help mach3 ethernet set up
By kell in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 06-12-2015, 10:26 PM
