Thread: Groping my way forward
Hi - I'm slowly starting to understand some of the basics in CNC - but I'm still not quite there :
I have now gone as far as creating an image and successfully simulating the cut i want to try in Fusion - I even managed to generate G code from that
1001.nc
Unfortunately when I load this to my CNC controller (my machine came with USB CNC) - it refuses to load with a message it didn't understand line 1 -
Now - if I take the file and load it to "quick and dirty g code simulator" - this shows a number of lines in the code it doesn't understand and the simulation is rather different - see screen print
The only help I can find in Youtube - seem to use mach3 as a tool and seems to need some amendment of the code - can someone help me to get the code to load ?
I don't use USB CNC but try deleting : and ; from the lines
Hve you used the correct post processor in Fusion as the code you have shown includes : and ; that it might object to.
Just a thought..Clive
31-01-2020 #3
31-01-2020 #4
The post processor will produce G-code that suits the specific machine control software you have. The differences between machines are usually quite small but none the less significant. Remember that G-code for CNC machine control has been around since computers were made from triodes so it's inevitable that there will be some variations between different generations of machines and their software.
31-01-2020 #5
31-01-2020 #6
You need to use a post processor that is compatible with the machine you are cutting on (if I am reading what the problem is correctly)
If you are using Fusion 360 you should be able to find a PP here ;_
https://cam.autodesk.com/hsmposts
Just ignore this post if you have already done this
31-01-2020 #7
Thank you - I certainly have not done that :-)
31-01-2020 #8
Really helpful, thank you so much - I followed this up - but discovered that there is no PP on the fusion site for USBCNC, but now i knew what I was a looking for and found this - just in case anyone else is looking for this
http://hacknorway.com/wordpress/post.../#comment-3108
I really appreciate your help as it's meant that i think I'm finally getting to where i can use my new CNC machine
31-01-2020 #9
02-02-2020 #10
NEW MEMBER: Lurker stepping forward
By Ninjabika in forum New Member IntroductionsReplies: 2Last Post: 30-06-2018, 06:24 PM -
One step forward two back
By gorbo in forum Machine DiscussionReplies: 2Last Post: 12-02-2011, 12:39 PM
