Hi, probably a dumb question but I have a set of Ballnose mills for 3d carving.
One has R0.75 printed on it and another one has R2 what does this mean? I assume radius and how do I program this into my tool on Fusion 360?
Thankshttp://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
24-02-2020 #2http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
24-02-2020 #3
yes the R is for radius so the r2 will be diameter of 4mm etc. To set it up in fusion, got to the ,manufacture tab, and the click on manage at the top right of the screen. In the drop down menu select tool library. I personally keep all my tools under the "local" folder so click on local and then mills. in top right click on new mill tool, leftmost of the five icons there and under the cutter tab you can select the type of tool, ballnose being one of them, and input the diameter and length parameters of your tool
The Following User Says Thank You to johngoodrich For This Useful Post:
24-02-2020 #4http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
25-02-2020 #5http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
25-02-2020 #6
No probs
Carbide taper ball nose cutters
By Leadhead in forum Tool & Tooling TechnologyReplies: 2Last Post: 08-01-2020, 06:45 AM -
1mm Ball Nose Bit Advice
By dcrowder in forum Tool & Tooling TechnologyReplies: 7Last Post: 18-04-2016, 06:15 PM -
WANTED: 3mm Ball nose bit please
By Fivetide in forum Items WantedReplies: 6Last Post: 12-12-2012, 05:06 PM -
Where to buy long ball nose mill for foam cutting?
By jamezwarner in forum Marketplace DiscussionReplies: 5Last Post: 10-05-2012, 02:03 PM -
FOR SALE: End mills and Ball mills for sale......
By Jimmybristol in forum Items For SaleReplies: 2Last Post: 16-02-2011, 12:37 AM
