Thread: 90:1 vs 180:1 gear ratio
Hey everyone,
I bought some geared rotational stages from a company on AliExpress and I'm 99% sure they sent the wrong ones but there are no markings to be able to tell. Two should have a gear ratio of 90:1 and one should have a gear ratio of 180:1. The company is refusing to take responsibility and I just want to check I'm not going mad and completely wrong here.
Correct me if I'm wrong but a 90:1 gear ratio should move at double the speed of a 180:1, correct? Meaning after one full turn the 90:1 would move double as much. I recorded a couple videos to prove this but they're saying otherwise. These are the videos:
https://squaremountain.co.uk/wp-cont...ion-Part-1.mp4
https://squaremountain.co.uk/wp-cont...ion-Part-2.mp4
Not really I'm afraid. The 180:1 and 90:1 are on the pan tilt head, which means they stall at different speeds and have different payload capacities. It would be much better if the two axis were the same. I could put both 180:1 drives on the pan tilt head but since the 180:1 are a little stronger they're supposed to be used for another purpose, plus I wanted the additional speed of the 90:1 for the pan tilt.
I wish I could switch them around, would make things a lot easier.
06-01-2021 #5
I'm talking about the speed at which the motors stall. So, as you'd expect, the 180:1 is a lot slower than the 90:1 and hence cannot reach the same speed before stalling.
I'd prefer that the faster motors be on the pan tilt head hence wanting the 90:1 versions there. Does that makes sense?
06-01-2021 #7
I'm possibly wrong due to lack of sleep, but shouldn't a 90:1 turn 4 degrees for every input revolution?
Which would mean you've got one 180:1, and two 360:1 reducers.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
06-01-2021 #8
You're totally right. Someone else pointed this out to me elsewhere and I hadn't even thought about it. I was so focused on how the company wouldn't acknowledge this obvious difference.
Servio motor Delta adas b2 Software and electronic gear ratio
By jhonansaro in forum General DiscussionReplies: 3Last Post: 16-03-2018, 08:09 PM -
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
My first gear, a deadbeat escapement gear for my clock
By clockman in forum Woodworking Project ShowcaseReplies: 9Last Post: 30-01-2011, 11:39 PM -
Gear cutting
By John S in forum CAD & CAM SoftwareReplies: 7Last Post: 03-10-2010, 07:55 PM -
Where to get gear blanks in UK...
By irving2008 in forum Machine DiscussionReplies: 4Last Post: 03-01-2010, 03:19 PM
