09-05-2021 #1
I tried my spindle with a different VFD which has a pot on it and the spindle starts and spins at a slow setting but when I try to speed it up I get an overcurrent/short circuit error
If it was a short it wouldn't spin at all right?
It's the same speed every time that it cuts out at, F has a maximum of 65 I can set it to 12.something before it cuts out
The CY cable is 2.5mm cross section and 5m's long, brand new
I tested continuity from the aviation plug to all 4 sockets in the vfd GND, U, V and W and they are connected, no sign of a short. Pin 1, 2 & 3 connect to U, V, W and pin 4 to earth. Each soldered pin has insulation tape covering it
This spindle is brand new and wouldn't spin up with a HuanYang VFD
Both VFD's rated 2.2kw and it is a 2.2kw water cooled spindle
This is the VFD. I get error 1
https://myosuploads3.banggood.com/pr...0AT1-2200X.pdf
ThanksLast edited by Desertboy; 09-05-2021 at 02:14 PM.
09-05-2021 #2
If both vfd's do exactly the same. I'd say the motor is a duffer internally.
The Following User Says Thank You to dazp1976 For This Useful Post:
09-05-2021 #3
Are you wiring it correctly.? Which terminal are you connecting the spindle to.?
Email: [email protected]
Web site: www.jazzcnc.co.uk
09-05-2021 #4http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
09-05-2021 #5http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
10-05-2021 #6
I did an ohms test on both spindles
Testing 1-2, 2-3 & 1-3
I get 1.7, 1.7, 1.7 for the new spindle
And 1.8, 1.8, 1.8 for the old spindle
I read it should be 1.4-1.6 so I assume both these numbers are finehttp://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
24-07-2021 #8
i had the same problem over the last couple of days and spend a lot of time reading the VFD manual an testing different settings
I bought a new 1.5kW Spindle and a used Toshiba VSF9S-2015PL-WP on Ebay. This VFD has many more options than the usually accomaning ones, so it took me a while to get it working.
The important parameters where:
- upper frequncy limit (UL) and maximum frequency (FH): set to 400Hz.
- V/Fi control mode setting (Pt): set to constant. So a linear ramp up of the voltage to the max ramp up frequncy.
- torque boost (uB) to 0% for now. So no extra voltage for start-up and high loads.
- set base frequency (uL) also to 400Hz.
The last one was the most important. The default base frequency was set to 50 Hz and with that the max voltage was reached at 50Hz.
I think i will try to reduce this later on to get a bit more torque at lower RPM. But only after improving my cooling setup (which is non existant for testing) :).
I hope this helps
Xsy-at1 error 6 over current
By greg_brister in forum General ElectronicsReplies: 9Last Post: 20-02-2020, 10:09 PM -
HY VFD and spindle at low speed
By Neale in forum General ElectronicsReplies: 9Last Post: 26-09-2018, 08:47 AM -
Emco Turn 55 - CamConcept Error - 6014 No Main Spindle Speed
By Fgc in forum Emco LathesReplies: 0Last Post: 26-10-2017, 05:13 PM -
Help please - Leadshine EM806 over-current error
By Noplace in forum Motor Drivers & ControllersReplies: 3Last Post: 25-08-2015, 04:02 PM -
Spindle Speed Control
By cncJim in forum Spindles & Drive MotorsReplies: 15Last Post: 18-06-2013, 07:53 PM
