    Hello everyone,
    I'm relatively new to CNC machining and have a question regarding surface finishes. I’ve been working on a few parts and, while the dimensions are coming out fine, I’m struggling to achieve a smooth surface finish, especially on aluminum.
    I’m using carbide end mills and have tried different feeds and speeds, but the results still seem rough. Could anyone offer some advice on optimizing toolpath strategies, speeds, feeds, or coatings to get a better finish?
    I’d appreciate any tips or resources to improve my process.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 16 Hours Ago Has been a member for 7-8 years. Has a total post count of 457. Received thanks 70 times, giving thanks to others 18 times.
    You should be using uncoated inserts or end mills for aluminium. Ideally look for the "honed", "lapped" or "polished" cutters with razor sharp edges (but be careful handling them!). Something like this https://www.cutwel.co.uk/milling-too...l-apfe3-korloy For inserts, the "G" ones with "higher tolerance" are sharp and polished eg CCGT rather CCMT, usually uncoated.
    You may find that taking a deeper cut (higher feed rare) actually gives a better finish than a "spring pass". I use coolant or WD40 for best finishes. It's also good to ensure the chips are cleared so they don't get rubbed against the workpiece, using air blast.
    What grade of aluminium? Many alloys are horrible to machine. From memory T6061 is good.
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,967. Received thanks 368 times, giving thanks to others 8 times.
    Provided you're taking a suitable cut, good finish on Aluminium is mostly about chip clearance.
    Either flood coolant, or air (with a bit mist, or even an occasional squirt of light oil such as WD40 to avoid chips sticking to the cutter) to ensure chips are washed/blown away to avoid re-cutting and marking of the cut surface.
    Muzzer's Avatar
    Quote Originally Posted by JohnHaine View Post
    I assumed most likely 6061 in the US, as he is new to CNC. Equivalent in terms of availability and popularity would be 6082 T6 in the UK - very similar properties and applications.
    This is 6082 machined on a 40 yo machine:
    https://www.instagram.com/p/ByKcPFYJ_iQ/?img_index=1
    It can be done!
    That finish looks amazing!
  1. BUILD LOG: Feedback on Improving Precision in XYZ Gantry Dispensing Machine
    By light404 in forum DIY Router Build Logs
    Last Post: 28-11-2024, 10:11 PM
  2. machining Aluminium Tips?
    By dfox1787 in forum Machine Discussion
    Last Post: 26-05-2018, 11:15 AM
  3. Improving my cheap DTI magnetic base
    By routercnc in forum Tool & Tooling Technology
    Last Post: 13-12-2016, 10:14 PM
  4. Improving your CNC3040/3020
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 22-11-2011, 01:48 PM
  5. Need advice on surface finish
    By FatFreddie in forum Machine Discussion
    Last Post: 01-05-2010, 02:51 PM
