Page 23 of 23 FirstFirst ... 13212223
  1. #221
    Spindle: 1 Me: 0
    It's a pita because you must fabricate your tools, and even they easily breaks (only 2.5mm pins...). You must heat at least 3 minutes in full power with your heater before trying unscrew this "#&@% full of holes". I enlarged them to 5mm,. But after this first victory, there's another flange. End of the story for me.
ID:	27402Click image for larger version.
    The 6002 bearing must have the large side pointed to the top. It's not a radial bearing.
  2. #222
    Hi Jonathan,
    I have just put together WorkBee 1000 x 1000 mm CNC machine. I am totally intimidated by the electronics. I purchased this machine from a firm in China and the directions for electronics are either nonexistent or (for me) undecipherable. Can you put me in touch with anyone who can walk me through this electronic challenge?
    I have a Huanyang GDZ-80-1.5 11V 1.5Kw 5A 400Hz spindle, an HY01D511B , an LRS-350-24, a UNO cardstepper card.
    Thank you for your time.
  3. #223
    I'm using a 400Hz 220V 24,000RPM Spindle motor from Vevor
    Can anyone remind me of the Mitsubishi FR-D720 parameter settings for this motor please.
    Last edited by Len-Tikular; 16-03-2023 at 05:41 PM. Reason: Changed the spindle motor
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
