    Hello! I'm a 15 year old student from North Wales and I'm looking to have a prototype made of an aluminium case I designed. I have got quotes for production from various companies in the UK. The price is very affordable when 5 or more units are made but I simply cannot afford the £1000+ I have been quoted for prototypes. I am hoping someone would be able to help me out with getting one made or someone could suggest a place where I could get it made. Please know that I'm not looking for some free service. I just can't afford £1000.
    The case is aimed at enthusiasts like myself and so it must be high quality otherwise I will not be able to get anyone interested in actually purchasing it.
    The case is made from four pieces. I'll post pictures in this thread and on PM request I can give Solidworks files that can be viewed with measurements with the free software Solidworks Viewer.
    Base piece : To be machined from aluminium, will be anodised after. I have no preference of what grade just something reasonably priced. Pictures can be seen here : http://i.imgur.com/rXFvLHf.jpg and http://i.imgur.com/BavKWHN.png
    Plate : To be machined from brass. This is to add weight and is a feature that enthusiasts love. It may seem like a pointless extra cost but understand that I wouldn't have added it if it were pointless. Picture can be seen here : http://i.imgur.com/HNMYrKk.jpg
    Top : To be machined from aluminium, will be anodised after. Pictures can be seen here : http://i.imgur.com/3s8uyRK.jpg and http://i.imgur.com/pHj78iR.jpg
    Mechanical switch plate : To be laser cut from 1.5mm thick aluminium. The cuts must be very clean otherwise it will not function properly. Because of this it needs to be cut by a high end machine. I know of someone who had a similar plate cut by a 2500w machine and it turned out awfully and couldn't function. Picture can be seen here : http://i.imgur.com/BJHbOFa.jpg
    Thank you for your time and thank you for looking!
    I could make that, but a few small changes will be required for anyone to make it for a reasonable price. You need to change all the sharp corners to rounded corners - something like 3-5mm would be fine. Similarly, adjacent to where you've put the USB connector there are some edges on the angled surface that can't easily be machined. If those could be rounded off then that feature becomes trivial.
    The brass plate and top are easy, again so long as the corner radii aren't too small. It might be possible to mill the switch plate to start with, which for a one off should be cheaper than laser cutting.
    Is that £1000 for five sets, or for one? What thickness of aluminium is required for the base?
  1. Prototype CNC Mill
    By aldepoalo in forum Milling Machines, Builds & Conversions
    Last Post: 01-09-2012, 12:15 PM
  2. Mach3 custom USB Keyboard
    By rnr107 in forum Electronic Project Building
    Last Post: 21-06-2012, 02:53 PM
  3. Cheap Monitor and Keyboard arm at CPC
    By Musht in forum Monitors
    Last Post: 12-05-2012, 12:58 AM
  4. Drivers,BOB and PSU are in a PC case, do i earth the case
    By deannos in forum Motor Drivers & Controllers
    Last Post: 27-11-2011, 03:43 PM
  5. This tiny keyboard might come in handy :)
    By Smiler in forum Gantry/Router Machines & Building
    Last Post: 28-12-2009, 06:30 PM
