    So, I'm making a 3d printer.
    and I've bought most of the parts from around the world but I can't find this part.
    so m6 thread on the outside, 3mm internal hole, about 50mm long and in Aluminium.
    it's so I can pop one of these on the end.
    I'm using 3mm filament so I'm hoping a 3mm aperture will be fine.
    thanks.
    I think you will find that 3mm filament is more often than not oval in shape and can be 3.2 x 2.8 etc here is a link HydraRaptor to a guy that has been around a long time and has a lot of good knowledge. The tubes are quite often made out of brass. a link here to a typical nozzle http://reprap.org/wiki/J_Head_Nozzle I have built a few of these printers in the past and the extruder is a very important part to get right for success. Good luck with your build. ...Clive
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    If you can get a drawing of what you'd like, I should be able to knock a few out with minimal hassle.
    One thing I wonder is if a reamed finish would be better than a drilled?
  5. #4
Name:	Fullscreen capture 20062013 235027.bmp.jpg
    A reamed finish would be great, I think brass may be a better material as it may hold the heat a bit more then Aluminium.
    I don't want the heat to travel up into the cold end too quickly.
  6. #5
    Have you seen the reprappro hot ends - I have the older version and it has been very reliable (the only problem was with a section of oversize filament - 2mm instead of 1.75 - can't really blame them for that) - I've put well over a kilometre of filament through with no other problems.
    New
    http://reprap.org/wiki/RepRapPro_Men...t_end_assembly
    Old
    http://emakershop.com/RepRapPro_Mend...-2013-0205.pdf
    The principle seems to be to create an abrupt transition between hot and cold zones by force cooling above the heater - this minimises the time the filament is semi molten and therefore the bulging which can cause jams.
    The new version looks like it uses a PTFE liner which would remove the necessity for a smooth barrel as well as insulating the filament until it got to the melt zone.
  1. Help with some tube please
    By Fivetide in forum Marketplace Discussion
    Last Post: 24-05-2014, 12:54 PM
  2. NEW MEMBER: CNC Tube Bender guy, here!
    By Tinine in forum New Member Introductions
    Last Post: 10-02-2013, 04:46 PM
  3. Tapping Delrin for M10 threaded rod - doable?
    Last Post: 02-02-2013, 12:31 AM
  4. threaded rod/lead screws
    By deannos in forum Gantry/Router Machines & Building
    Last Post: 23-05-2011, 09:40 AM
