    Quick question, I've just built a small shed in our yard on a concrete slab. My question is do I need to insulate the floor. I'm doing the walls/roof with 25mm polystyrene, DPM then chipboard(got it dirt cheap). The shed is waterproof all round. Its only 8' x 8' but I need to save cash where I can. For the floor I was going to build a frame and use polystyrene there too but I don't want to lose anymore height so I'm thinking of putting down carpet tiles with maybe some of that thin under laminate floor stuff straight onto the slab :)
    How does it sound? I know it's not going to be super insulated but as long as I can comfortably work in there with a small heater I'll be happy.
    Cheers, Phil
    You can do if you want to it will make it a bit warmer and more comfortable to work on for long periods. Put down a layer of DPM first to keep the moisture out.
    i used cheap play mats from tesco on my floor, it certainly makes a difference not only on warmth when your doing low level stuff such as painting the bottom of a cabinet, but also it's something to kneel on and it makes standing around on there a hell of a lot more comfortable.. i could easily spend all day in there with no worries. i know they are not on offer at the moment but there are some deals to be had on ebay if you look.
    Cheers, you're not the first to recommend those tiles so I think its time to go bargain hunting :)
    Thanks guys.
    joshuaseigel's Avatar
    Location unknown. joshuaseigel Last Activity: Has a total post count of n/a. Referred 6181 members to the community.
    Not all sheds are suitable to be insulated. If you have a small plastic or metal shed then their initial construction does not really suit the process that I am about to discuss. If you have a shed like this you would be better off changing the shed for a more robust type of shed that can more easily accept the additional insulating materials. But if you have a fairly standard type of timber shed, using a minimum of 3x2 timbers there is a fair amount that you can do to help it retain the heat better in the colder months.
  1. Best type of shed.
    By Philly in forum General Discussion
    Last Post: 03-11-2018, 08:17 PM
  2. Community Shed
    By Musht in forum General Discussion
    Last Post: 06-10-2013, 12:15 PM
  3. setting the lathe up perfectly level on floor, really?
    By onecut in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 25-06-2012, 05:11 PM
  4. wall and floor fixing am I the only one ????????????
    By luke11cnc in forum General Discussion
    Last Post: 30-12-2011, 11:45 PM
  5. NEW MEMBER: from a shed in Nottinghamshire
    By Andrew Wilding in forum New Member Introductions
    Last Post: 17-09-2010, 12:34 AM
