I don't have the dimensions right now, but will do shortly.
This is the original part. It is non adjustable.
This is an aftermarket part to replace the one above. But it needs to have the bolts dropped from the part to be able for the length to be adjusted.
The new one needs to be able to have the "adjustable length" via the thread and nut, adjusted while the part is mounted, meaning the ends will not be turning. This one below is another aftermarket design which works as it should, but are no longer made.
This part is for myself, but If someone here is interested I can order multiples to market.Last edited by dudz; 06-11-2013 at 04:45 PM.
06-11-2013 #2
Hi Dudz
shouldn't be too difficult, but if you could give an idea of the thread size of the Rose Joint, a matching left hand tap would have to be procured, it's just a turnbuckle, some idea of the loading would be usefull,can't do this myself but others will wan't this information.Regards
Mike
06-11-2013 #3
loading weight would be around 200kgs. The thread size and dimensions I will list as soon as I can.
6082 Aluminium billet test
By dudz in forum Metal Finishing TechniquesReplies: 1Last Post: 22-09-2013, 10:45 AM -
RFQ: Billet block
By youngblood in forum Projects, Jobs & RequestsReplies: 0Last Post: 02-04-2013, 09:17 PM -
a perfect 90deg joint - 15mm Alu
By dsc in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 24-02-2013, 01:31 PM -
shaft - grinding part joint
By dsc in forum Linear & Rotary MotionReplies: 9Last Post: 21-11-2012, 09:31 AM -
7075 Aluminium supplier?
By m_c in forum Marketplace DiscussionReplies: 2Last Post: 30-12-2010, 12:27 PM
