  1. I'm sure this must of been asked before but I can't find it.
    1/ To mill a pocket and leave the top outside edges without burs which direction should the spindle be traveling if the tool rotation is clockwise ? And when cutting an outside profile ??
    2/ What is the quickest way in cambam to send the spindle around the top outside edge of a profile to do a quick clean up ?
    I'd say cutter motion should be clockwise for the inside pocket and anticlockwise for outside profile, so the cutting edge is advancing to the oncoming work edge, as opposed to the cutting edge taking the trailing work piece by surprise. But I don't know from experience, so take it with a pinch of salt.
    Quote Originally Posted by CharlesJenkinson View Post
    That's Conventional Milling, using Climb Milling can give you very neat edges but only if your machine is rigid enough and has very little backlash.
    Either should give you neat edges if you have your feeds & speeds correct for the material & cutter, try a calculator like HSM Advisor [ Advanced CNC Speed And Feed Calculator - HSMAdvisor ] to check your current settings, the free 30 day trial should give you plenty of time to experiment,
    - Nick
  1. Axis Directions
    By ptjw7uk in forum Linear & Rotary Motion
    Last Post: 18-02-2022, 08:45 AM
  2. RFQ: CLOSED - Aluminium milling and anodising
    By AlexTsekenis in forum Projects, Jobs & Requests
    Last Post: 12-05-2014, 10:11 PM
  3. Milling Sheet Aluminium
    By p1lts in forum Metalwork Discussion
    Last Post: 08-03-2014, 12:23 AM
  4. Best Tips for Cutting 6082 Aluminium (CNC Lathe)
    By fidia in forum Metal Finishing Techniques
    Last Post: 29-12-2013, 07:09 PM
  5. 6082 Aluminium billet test
    By dudz in forum Metal Finishing Techniques
    Last Post: 22-09-2013, 10:45 AM
