    Howdy,
    I use an early version 1 of Mach cnc. I mostly mill complex low relief forms in polystyrene using Aspire to write the gcode. I have started recently to use the profile cut mode in Aspire. It has highlighted an issue which I need to address.
    In profile mode, infact all modes the program has a tendency to not cut into corners preferring the shortest distance. I therefor must need to instruct Mach and or Aspire to slow/ recognise certain angles.
    My question is how do I do this? Do I need a different version of Mach 3, and which page allows me to make the alterations to stop it cutting corners.
    Are you using bits that are a greater dia than corners you are cutting? ..Clive
    Hi Clive,
    Thanks for reply. The bits are less dia than the corner radius.
    Quote Originally Posted by marbles View Post
    Hi Clive,
    You might be better posting some Gcode Have a read through this http://www.cnczone.com/forums/mach-m...are-posts.html ..Clive
    i think the issue I have is related to Constant Velocity versus Absolute Stop on the Config page of Mach.
    I think there is a setting for this in Mach on the settings page. Clive
    It's not that simple really. Chances are you have the acceleration to low for the commanded speed and radius your asking the machine to do.
    Try turning acceleration up and Velocity down then try again and you may find it works.?
    What is your acceleration set at and what feed rates are you trying to cut with what radius etc. Posting the Gcode would be best.
    Here are the g-code and three screen grabs from Mach and one from Aspire. I've enlarged part of the screen to show how the toolpath shows it cutting corners on both the N and M on the text being cut out. I can post more/ or less if helps. Apologies for the large amount of gcode, I can post less in future if its suggested where I cut and paste.
    Gcode
    ( myname3-Quick Engrave 2 )
    ( File created: Thursday, April 23, 2015 - 03:09 PM)
    ( for Mach2/3 from Vectric )
    ( Material Size)
    ( X= 150.000, Y= 150.000, Z= 6.000)
    (Toolpaths used in this file:)
    (Quick Engrave 2)
    (Tools used in this file: )
    (1 = End Mill {2 mm} xta slow)
    N100G00G21G17G90G40G49G80
    N110G71G91.1
    N120T1M06
    N130 (End Mill {2 mm} xta slow)
    N140G00G43Z20.000H1
    N150S50M03
    N160(Toolpath:- Quick Engrave 2)
    N170()
    N180G94
    N190X0.000Y0.000F3600.0
    N200G00X5.231Y-11.135Z5.999
    N210G1Z-1.000F1200.0
    N220G1X7.377F3600.0
    N230G1Y-13.121
    N240G1X7.551Y-12.868
    N250G1X7.738Y-12.627
    N260G1X7.939Y-12.399
    N270G1X8.154Y-12.183
    N280G1X8.382Y-11.981
    N290G1X8.624Y-11.791
    N300G1X8.880Y-11.613
    N310G1X9.150Y-11.449
    N320G1X9.431Y-11.300
    N330G1X9.722Y-11.172
    N340G1X10.023Y-11.063
    N350G1X10.333Y-10.974
    N360G1X10.653Y-10.905
    N370G1X10.982Y-10.855
    N380G1X11.321Y-10.825
    N390G1X11.669Y-10.816
    N400G1X12.054Y-10.826
    N410G1X12.420Y-10.856
    N420G1X12.769Y-10.907
    N430G1X13.100Y-10.979
    N440G1X13.414Y-11.071
    N450G1X13.710Y-11.183
    N460G1X13.988Y-11.316
    N470G1X14.248Y-11.469
    N480G1X14.491Y-11.640
    N490G1X14.714Y-11.828
    N500G1X14.920Y-12.032
    N510G1X15.106Y-12.252
    N520G1X15.275Y-12.488
    N530G1X15.424Y-12.741
    N540G1X15.555Y-13.010
    N550G1X15.668Y-13.295
    N560G1X15.882Y-12.994
    N570G1X16.104Y-12.714
    N580G1X16.333Y-12.452
    N590G1X16.571Y-12.210
    N600G1X16.816Y-11.987
    N610G1X17.070Y-11.784
    N620G1X17.331Y-11.600
    N630G1X17.601Y-11.435
    N640G1X17.878Y-11.290
    N650G1X18.163Y-11.164
    N660G1X18.456Y-11.058
    N670G1X18.757Y-10.970
    N680G1X19.066Y-10.903
    N690G1X19.382Y-10.854
    N700G1X19.707Y-10.825
    N710G1X20.040Y-10.816
    N720G1X20.551Y-10.834
    N730G1X21.032Y-10.888
    N740G1X21.482Y-10.980
    N750G1X21.902Y-11.107
    N760G1X22.292Y-11.271
    N770G1X22.651Y-11.472
    N780G1X22.980Y-11.708
    N790G1X23.279Y-11.982
    N800G1X23.544Y-12.293
    N810G1X23.774Y-12.644
    N820G1X23.969Y-13.034
    N830G1X24.128Y-13.463
    N840G1X24.252Y-13.932
    N850G1X24.341Y-14.440
    N860G1X24.394Y-14.987
    N870G1X24.412Y-15.574
    N880G1Y-25.291
    N890G1X22.026
    N900G1Y-16.374
    N910G1X22.011Y-15.704
    N920G1X21.967Y-15.136
    N930G1X21.894Y-14.668
    N940G1X21.792Y-14.301
    N950G1X21.652Y-14.000
    N960G1X21.464Y-13.730
    N970G1X21.229Y-13.490
    N980G1X20.946Y-13.281
    N990G1X20.626Y-13.112
    N1000G1X20.280Y-12.991
    N1010G1X19.906Y-12.919
    N1020G1X19.507Y-12.895
    N1030G1X19.141Y-12.910
    N1040G1X18.792Y-12.957
    N1050G1X18.458Y-13.034
    N1060G1X18.140Y-13.143
    N1070G1X17.838Y-13.283
    N1080G1X17.552Y-13.453
    N1090G1X17.282Y-13.655
    N1100G1X17.027Y-13.888
    N1110G1X16.796Y-14.155
    N1120G1X16.596Y-14.459
    N1130G1X16.426Y-14.800
    N1140G1X16.288Y-15.179
    N1150G1X16.180Y-15.595
    N1160G1X16.103Y-16.048
    N1170G1X16.056Y-16.539
    N1180G1X16.041Y-17.067
    N1190G1Y-25.291
    N1200G1X13.642
    N1210G1Y-16.094
    N1220G1X13.633Y-15.706
    N1230G1X13.605Y-15.344
    N1240G1X13.559Y-15.007
    N1250G1X13.495Y-14.694
    N1260G1X13.413Y-14.407
    N1270G1X13.312Y-14.144
    N1280G1X13.193Y-13.907
    N1290G1X13.055Y-13.695
    N1300G1X12.897Y-13.507
    N1310G1X12.716Y-13.345
    N1320G1X12.511Y-13.207
    N1330G1X12.282Y-13.095
    N1340G1X12.031Y-13.007
    N1350G1X11.756Y-12.945
    N1360G1X11.458Y-12.907
    N1370G1X11.136Y-12.895
    N1380G1X10.885Y-12.903
    N1390G1X10.639Y-12.928
    N1400G1X10.398Y-12.970
    N1410G1X10.161Y-13.028
    N1420G1X9.930Y-13.103
    N1430G1X9.703Y-13.195
    N1440G1X9.481Y-13.303
    N1450G1X9.263Y-13.428
    N1460G1X9.056Y-13.569
    N1470G1X8.863Y-13.725
    N1480G1X8.685Y-13.897
    N1490G1X8.522Y-14.084
    N1500G1X8.374Y-14.287
    N1510G1X8.240Y-14.505
    N1520G1X8.121Y-14.739
    N1530G1X8.017Y-14.987
    N1540G1X7.927Y-15.258
    N1550G1X7.848Y-15.557
    N1560G1X7.782Y-15.885
    N1570G1X7.727Y-16.240
    N1580G1X7.655Y-17.037
    N1590G1X7.631Y-17.946
    N1600G1Y-25.291
    N1610G1X5.231
    N1620G1Y-11.135
    N1630G00Z5.999
    N1640G00X26.611
    N1650G1Z-1.000F1200.0
    N1660G1X29.197F3600.0
    N1670G1X32.142Y-19.333
    N1680G1X32.421Y-20.122
    N1690G1X32.685Y-20.932
    N1700G1X32.934Y-21.762
    N1710G1X33.169Y-22.612
    N1720G1X33.385Y-21.790
    N1730G1X33.622Y-20.979
    N1740G1X33.878Y-20.177
    N1750G1X34.155Y-19.386
    N1760G1X37.181Y-11.135
    N1770G1X39.580
    N1780G1X34.195Y-25.531
    N1790G1X33.786Y-26.606
    N1800G1X33.425Y-27.500
    N1810G1X33.113Y-28.212
    N1820G1X32.849Y-28.743
    N1830G1X32.686Y-29.029
    N1840G1X32.517Y-29.296
    N1850G1X32.343Y-29.543
    N1860G1X32.162Y-29.771
    N1870G1X31.976Y-29.978
    N1880G1X31.784Y-30.166
    N1890G1X31.586Y-30.334
    N1900G1X31.382Y-30.482
    N1910G1X31.171Y-30.612
    N1920G1X30.949Y-30.724
    N1930G1X30.718Y-30.819
    N1940G1X30.476Y-30.897
    N1950G1X30.225Y-30.958
    N1960G1X29.963Y-31.001
    N1970G1X29.691Y-31.027
    N1980G1X29.410Y-31.035
    N1990G1X29.053Y-31.017
    N2000G1X28.677Y-30.962
    N2010G1X28.280Y-30.870
    N2020G1X27.864Y-30.742
    N2030G1X27.597Y-28.490
    N2040G1X27.978Y-28.583
    N2050G1X28.334Y-28.649
    N2060G1X28.664Y-28.689
    N2070G1X28.970Y-28.703
    N2080G1X29.350Y-28.686
    N2090G1X29.690Y-28.636
    N2100G1X29.990Y-28.553
    N2110G1X30.250Y-28.436
    N2120G1X30.479Y-28.290
    N2130G1X30.686Y-28.116
    N2140G1X30.872Y-27.916
    N2150G1X31.036Y-27.690
    N2160G1X31.167Y-27.443
    N2170G1X31.333Y-27.063
    N2180G1X31.769Y-25.904
    N2190G1X31.982Y-25.317
    N2200G1X26.611Y-11.135
    N2210G00Z5.999
    N2220G00X39.673Y-35.327
    N2230G1Z-1.000F1200.0
    N2240G1X49.390F3600.0
    N2250G1Y-37.620
    N2260G1X41.592
    N2270G1X40.539Y-42.871
    N2280G1X40.982Y-42.584
    N2290G1X41.430Y-42.335
    N2300G1X41.883Y-42.124
    N2310G1X42.342Y-41.952
    N2320G1X42.806Y-41.817
    N2330G1X43.276Y-41.722
    N2340G1X43.751Y-41.664
    N2350G1X44.231Y-41.645
    N2360G1X44.859Y-41.673
    N2370G1X45.461Y-41.756
    N2380G1X46.038Y-41.894
    N2390G1X46.318Y-41.984
    N2400G1X46.591Y-42.088
    N2410G1X46.857Y-42.206
    N2420G1X47.118Y-42.337
    N2430G1X47.372Y-42.483
    N2440G1X47.620Y-42.642
    N2450G1X48.098Y-43.002
    N2460G1X48.550Y-43.418
    N2470G1X48.763Y-43.643
    N2480G1X48.962Y-43.877
    N2490G1X49.148Y-44.118
    N2500G1X49.320Y-44.367
    N2510G1X49.478Y-44.625
    N2520G1X49.622Y-44.890
    N2530G1X49.753Y-45.163
    N2540G1X49.870Y-45.444
    N2550G1X49.973Y-45.733
    N2560G1X50.062Y-46.029
    N2570G1X50.138Y-46.334
    N2580G1X50.199Y-46.647
    N2590G1X50.282Y-47.296
    N2600G1X50.309Y-47.976
    N2610G1X50.285Y-48.628
    N2620G1X50.213Y-49.257
    N2630G1X50.092Y-49.864
    N2640G1X49.923Y-50.449
    N2650G1X49.705Y-51.011
    N2660G1X49.440Y-51.550
    N2670G1X49.126Y-52.067
    N2680G1X48.763Y-52.561
    N2690G1X48.523Y-52.849
    N2700G1X48.272Y-53.117
    N2710G1X48.010Y-53.368
    N2720G1X47.738Y-53.599
    N2730G1X47.455Y-53.812
    N2740G1X47.161Y-54.007
    N2750G1X46.856Y-54.183
    N2760G1X46.541Y-54.341
    N2770G1X46.215Y-54.480
    N2780G1X45.878Y-54.600
    N2790G1X45.530Y-54.702
    N2800G1X45.172Y-54.786
    N2810G1X44.803Y-54.850
    N2820G1X44.423Y-54.897
    N2830G1X44.033Y-54.925
    N2840G1X43.632Y-54.934
    N2850G1X42.981Y-54.910
    N2860G1X42.360Y-54.841
    N2870G1X41.770Y-54.724
    N2880G1X41.211Y-54.561
    N2890G1X40.682Y-54.351
    N2900G1X40.184Y-54.094
    N2910G1X39.717Y-53.791
    N2920G1X39.280Y-53.441
    N2930G1X38.881Y-53.053
    N2940G1X38.527Y-52.634
    N2950G1X38.219Y-52.185
    N2960G1X37.955Y-51.705
    N2970G1X37.737Y-51.195
    N2980G1X37.564Y-50.654
    N2990G1X37.436Y-50.084
    N3000G1X37.354Y-49.482
    N3010G1X39.873Y-49.269
    N3020G1X39.954Y-49.715
    N3030G1X40.059Y-50.132
    N3040G1X40.187Y-50.520
    N3050G1X40.338Y-50.880
    N3060G1X40.512Y-51.212
    N3070G1X40.709Y-51.515
    N3080G1X40.929Y-51.789
    N3090G1X41.172Y-52.035
    N3100G1X41.434Y-52.252
    N3110G1X41.709Y-52.440
    N3120G1X41.996Y-52.599
    N3130G1X42.297Y-52.730
    N3140G1X42.611Y-52.831
    N3150G1X42.938Y-52.903
    N3160G1X43.278Y-52.947
    N3170G1X43.632Y-52.961
    N3180G1X44.056Y-52.941
    N3190G1X44.465Y-52.880
    N3200G1X44.856Y-52.777
    N3210G1X45.231Y-52.635
    N3220G1X45.589Y-52.451
    N3230G1X45.931Y-52.226
    N3240G1X46.256Y-51.961
    N3250G1X46.564Y-51.655
    N3260G1X46.845Y-51.315
    N3270G1X47.089Y-50.949
    N3280G1X47.295Y-50.555
    N3290G1X47.464Y-50.135
    N3300G1X47.595Y-49.689
    N3310G1X47.689Y-49.216
    N3320G1X47.745Y-48.716
    N3330G1X47.764Y-48.189
    N3340G1X47.746Y-47.690
    N3350G1X47.692Y-47.217
    N3360G1X47.601Y-46.772
    N3370G1X47.475Y-46.353
    N3380G1X47.313Y-45.962
    N3390G1X47.115Y-45.598
    N3400G1X46.881Y-45.261
    N3410G1X46.611Y-44.951
    N3420G1X46.311Y-44.673
    N3430G1X45.990Y-44.432
    N3440G1X45.646Y-44.228
    N3450G1X45.279Y-44.061
    N3460G1X44.891Y-43.931
    N3470G1X44.480Y-43.838
    N3480G1X44.047Y-43.783
    N3490G1X43.592Y-43.764
    N3500G1X43.305Y-43.773
    N3510G1X43.026Y-43.797
    N3520G1X42.754Y-43.838
    N3530G1X42.489Y-43.896
    N3540G1X42.231Y-43.970
    N3550G1X41.980Y-44.060
    N3560G1X41.736Y-44.167
    N3570G1X41.499Y-44.291
    N3580G1X41.058Y-44.574
    N3590G1X40.856Y-44.730
    N3600G1X40.666Y-44.896
    N3610G1X40.489Y-45.071
    N3620G1X40.324Y-45.257
    N3630G1X40.172Y-45.452
    N3640G1X40.033Y-45.657
    N3650G1X37.780Y-45.364
    N3660G1X39.673Y-35.327
    N3670G00Z5.999
    N3680G00X34.114Y-37.815
    N3690G1Z-1.000F1200.0
    N3700G1X34.345Y-38.286F3600.0
    N3710G1X34.524Y-38.781
    N3720G1X34.652Y-39.299
    N3730G1X34.729Y-39.841
    N3740G1X34.755Y-40.405
    N3750G1X34.747Y-40.698
    N3760G1X34.725Y-40.989
    N3770G1X34.635Y-41.568
    N3780G1X34.485Y-42.142
    N3790G1X34.275Y-42.711
    N3800G1X34.145Y-42.996
    N3810G1X33.995Y-43.285
    N3820G1X33.637Y-43.874
    N3830G1X33.199Y-44.478
    N3840G1X32.682Y-45.097
    N3850G1X32.034Y-45.782
    N3860G1X31.201Y-46.583
    N3870G1X30.184Y-47.501
    N3880G1X28.983Y-48.536
    N3890G1X28.000Y-49.369
    N3900G1X27.211Y-50.057
    N3910G1X26.614Y-50.599
    N3920G1X26.211Y-50.995
    N3930G1X25.918Y-51.319
    N3940G1X25.651Y-51.643
    N3950G1X25.411Y-51.969
    N3960G1X25.198Y-52.295
    N3970G1X34.781
    N3980G1Y-54.601
    N3990G1X21.866
    N4000G1X21.873Y-54.172
    N4010G1X21.922Y-53.751
    N4020G1X22.013Y-53.339
    N4030G1X22.146Y-52.934
    N4040G1X22.278Y-52.605
    N4050G1X22.429Y-52.277
    N4060G1X22.599Y-51.950
    N4070G1X22.787Y-51.625
    N4080G1X22.994Y-51.301
    N4090G1X23.219Y-50.978
    N4100G1X23.463Y-50.656
    N4110G1X23.725Y-50.335
    N4120G1X24.329Y-49.671
    N4130G1X25.053Y-48.956
    N4140G1X25.898Y-48.191
    N4150G1X26.864Y-47.376
    N4160G1X27.628Y-46.740
    N4170G1X28.328Y-46.138
    N4180G1X28.963Y-45.570
    N4190G1X29.533Y-45.036
    N4200G1X30.039Y-44.535
    N4210G1X30.480Y-44.069
    N4220G1X30.857Y-43.636
    N4230G1X31.169Y-43.238
    N4240G1X31.432Y-42.859
    N4250G1X31.659Y-42.485
    N4260G1X31.851Y-42.117
    N4270G1X32.009Y-41.753
    N4280G1X32.131Y-41.395
    N4290G1X32.219Y-41.042
    N4300G1X32.271Y-40.695
    N4310G1X32.289Y-40.352
    N4320G1X32.273Y-40.003
    N4330G1X32.225Y-39.667
    N4340G1X32.145Y-39.345
    N4350G1X32.034Y-39.038
    N4360G1X31.891Y-38.744
    N4370G1X31.715Y-38.464
    N4380G1X31.508Y-38.198
    N4390G1X31.269Y-37.946
    N4400G1X31.005Y-37.717
    N4410G1X30.721Y-37.518
    N4420G1X30.417Y-37.349
    N4430G1X30.095Y-37.212
    N4440G1X29.753Y-37.104
    N4450G1X29.391Y-37.028
    N4460G1X29.010Y-36.982
    N4470G1X28.610Y-36.967
    N4480G1X28.188Y-36.983
    N4490G1X27.787Y-37.032
    N4500G1X27.408Y-37.113
    N4510G1X27.051Y-37.227
    N4520G1X26.715Y-37.373
    N4530G1X26.401Y-37.551
    N4540G1X26.108Y-37.763
    N4550G1X25.838Y-38.006
    N4560G1X25.594Y-38.279
    N4570G1X25.382Y-38.576
    N4580G1X25.202Y-38.898
    N4590G1X25.055Y-39.246
    N4600G1X24.939Y-39.618
    N4610G1X24.856Y-40.016
    N4620G1X24.804Y-40.438
    N4630G1X24.785Y-40.885
    N4640G1X22.319Y-40.632
    N4650G1X22.404Y-39.963
    N4660G1X22.533Y-39.335
    N4670G1X22.706Y-38.747
    N4680G1X22.922Y-38.201
    N4690G1X23.182Y-37.696
    N4700G1X23.486Y-37.232
    N4710G1X23.834Y-36.809
    N4720G1X24.225Y-36.427
    N4730G1X24.656Y-36.088
    N4740G1X25.122Y-35.794
    N4750G1X25.624Y-35.546
    N4760G1X26.161Y-35.342
    N4770G1X26.733Y-35.184
    N4780G1X27.341Y-35.071
    N4790G1X27.985Y-35.003
    N4800G1X28.663Y-34.981
    N4810G1X29.348Y-35.005
    N4820G1X29.996Y-35.078
    N4830G1X30.608Y-35.200
    N4840G1X31.183Y-35.370
    N4850G1X31.721Y-35.590
    N4860G1X31.976Y-35.718
    N4870G1X32.222Y-35.858
    N4880G1X32.459Y-36.010
    N4890G1X32.687Y-36.175
    N4900G1X32.906Y-36.351
    N4910G1X33.115Y-36.540
    N4920G1X33.499Y-36.942
    N4930G1X33.832Y-37.366
    N4940G1X34.114Y-37.815
    N4950G00Z5.999
    N4960G00X53.202Y-40.445
    N4970G1Z-1.000F1200.0
    N4980G1X55.348F3600.0
    N4990G1Y-42.431
    N5000G1X55.521Y-42.178
    N5010G1X55.708Y-41.937
    N5020G1X55.909Y-41.709
    N5030G1X56.124Y-41.493
    N5040G1X56.353Y-41.291
    N5050G1X56.595Y-41.101
    N5060G1X56.851Y-40.923
    N5070G1X57.120Y-40.759
    N5080G1X57.402Y-40.610
    N5090G1X57.693Y-40.482
    N5100G1X57.993Y-40.373
    N5110G1X58.303Y-40.284
    N5120G1X58.623Y-40.215
    N5130G1X58.952Y-40.165
    N5140G1X59.291Y-40.135
    N5150G1X59.640Y-40.126
    N5160G1X60.024Y-40.136
    N5170G1X60.391Y-40.166
    N5180G1X60.739Y-40.217
    N5190G1X61.071Y-40.289
    N5200G1X61.384Y-40.381
    N5210G1X61.680Y-40.493
    N5220G1X61.958Y-40.626
    N5230G1X62.219Y-40.779
    N5240G1X62.461Y-40.950
    N5250G1X62.685Y-41.138
    N5260G1X62.890Y-41.342
    N5270G1X63.077Y-41.562
    N5280G1X63.245Y-41.798
    N5290G1X63.394Y-42.051
    N5300G1X63.526Y-42.320
    N5310G1X63.638Y-42.605
    N5320G1X63.852Y-42.304
    N5330G1X64.074Y-42.024
    N5340G1X64.304Y-41.762
    N5350G1X64.541Y-41.520
    N5360G1X64.787Y-41.297
    N5370G1X65.040Y-41.094
    N5380G1X65.302Y-40.910
    N5390G1X65.571Y-40.745
    N5400G1X65.848Y-40.600
    N5410G1X66.133Y-40.474
    N5420G1X66.426Y-40.368
    N5430G1X66.727Y-40.280
    N5440G1X67.036Y-40.213
    N5450G1X67.353Y-40.164
    N5460G1X67.677Y-40.135
    N5470G1X68.010Y-40.126
    N5480G1X68.521Y-40.144
    N5490G1X69.002Y-40.198
    N5500G1X69.453Y-40.290
    N5510G1X69.873Y-40.417
    N5520G1X70.262Y-40.581
    N5530G1X70.622Y-40.782
    N5540G1X70.950Y-41.018
    N5550G1X71.249Y-41.292
    N5560G1X71.514Y-41.603
    N5570G1X71.745Y-41.954
    N5580G1X71.939Y-42.344
    N5590G1X72.099Y-42.773
    N5600G1X72.223Y-43.242
    N5610G1X72.311Y-43.750
    N5620G1X72.364Y-44.297
    N5630G1X72.382Y-44.884
    N5640G1Y-54.601
    N5650G1X69.996
    N5660G1Y-45.684
    N5670G1X69.981Y-45.014
    N5680G1X69.938Y-44.446
    N5690G1X69.865Y-43.978
    N5700G1X69.763Y-43.611
    N5710G1X69.622Y-43.310
    N5720G1X69.435Y-43.040
    N5730G1X69.199Y-42.800
    N5740G1X68.916Y-42.591
    N5750G1X68.596Y-42.422
    N5760G1X68.250Y-42.301
    N5770G1X67.877Y-42.229
    N5780G1X67.477Y-42.205
    N5790G1X67.112Y-42.220
    N5800G1X66.762Y-42.267
    N5810G1X66.428Y-42.344
    N5820G1X66.111Y-42.453
    N5830G1X65.809Y-42.593
    N5840G1X65.523Y-42.763
    N5850G1X65.252Y-42.965
    N5860G1X64.998Y-43.198
    N5870G1X64.767Y-43.465
    N5880G1X64.566Y-43.769
    N5890G1X64.397Y-44.110
    N5900G1X64.258Y-44.489
    N5910G1X64.150Y-44.905
    N5920G1X64.073Y-45.358
    N5930G1X64.027Y-45.849
    N5940G1X64.011Y-46.377
    N5950G1Y-54.601
    N5960G1X61.612
    N5970G1Y-45.404
    N5980G1X61.603Y-45.016
    N5990G1X61.576Y-44.654
    N6000G1X61.530Y-44.317
    N6010G1X61.466Y-44.004
    N6020G1X61.383Y-43.717
    N6030G1X61.282Y-43.454
    N6040G1X61.163Y-43.217
    N6050G1X61.026Y-43.005
    N6060G1X60.867Y-42.817
    N6070G1X60.686Y-42.655
    N6080G1X60.481Y-42.517
    N6090G1X60.253Y-42.405
    N6100G1X60.001Y-42.317
    N6110G1X59.726Y-42.255
    N6120G1X59.428Y-42.217
    N6130G1X59.106Y-42.205
    N6140G1X58.856Y-42.213
    N6150G1X58.609Y-42.238
    N6160G1X58.368Y-42.280
    N6170G1X58.132Y-42.338
    N6180G1X57.900Y-42.413
    N6190G1X57.673Y-42.505
    N6200G1X57.451Y-42.613
    N6210G1X57.234Y-42.738
    N6220G1X57.026Y-42.879
    N6230G1X56.833Y-43.035
    N6240G1X56.655Y-43.207
    N6250G1X56.492Y-43.394
    N6260G1X56.344Y-43.597
    N6270G1X56.210Y-43.815
    N6280G1X56.091Y-44.049
    N6290G1X55.987Y-44.297
    N6300G1X55.897Y-44.568
    N6310G1X55.818Y-44.867
    N6320G1X55.752Y-45.195
    N6330G1X55.698Y-45.550
    N6340G1X55.625Y-46.347
    N6350G1X55.601Y-47.256
    N6360G1Y-54.601
    N6370G1X53.202
    N6380G1Y-40.445
    N6390G00Z5.999
    N6400G00X75.941
    N6410G1Z-1.000F1200.0
    N6420G1X78.087F3600.0
    N6430G1Y-42.431
    N6440G1X78.260Y-42.178
    N6450G1X78.447Y-41.937
    N6460G1X78.648Y-41.709
    N6470G1X78.863Y-41.493
    N6480G1X79.091Y-41.291
    N6490G1X79.334Y-41.101
    N6500G1X79.590Y-40.923
    N6510G1X79.859Y-40.759
    N6520G1X80.141Y-40.610
    N6530G1X80.432Y-40.482
    N6540G1X80.732Y-40.373
    N6550G1X81.042Y-40.284
    N6560G1X81.362Y-40.215
    N6570G1X81.691Y-40.165
    N6580G1X82.030Y-40.135
    N6590G1X82.378Y-40.126
    N6600G1X82.763Y-40.136
    N6610G1X83.129Y-40.166
    N6620G1X83.478Y-40.217
    N6630G1X83.810Y-40.289
    N6640G1X84.123Y-40.381
    N6650G1X84.419Y-40.493
    N6660G1X84.697Y-40.626
    N6670G1X84.958Y-40.779
    N6680G1X85.200Y-40.950
    N6690G1X85.424Y-41.138
    N6700G1X85.629Y-41.342
    N6710G1X85.816Y-41.562
    N6720G1X85.984Y-41.798
    N6730G1X86.133Y-42.051
    N6740G1X86.264Y-42.320
    N6750G1X86.377Y-42.605
    N6760G1X86.591Y-42.304
    N6770G1X86.813Y-42.024
    N6780G1X87.042Y-41.762
    N6790G1X87.280Y-41.520
    N6800G1X87.526Y-41.297
    N6810G1X87.779Y-41.094
    N6820G1X88.040Y-40.910
    N6830G1X88.310Y-40.745
    N6840G1X88.587Y-40.600
    N6850G1X88.872Y-40.474
    N6860G1X89.165Y-40.368
    N6870G1X89.466Y-40.280
    N6880G1X89.775Y-40.213
    N6890G1X90.092Y-40.164
    N6900G1X90.416Y-40.135
    N6910G1X90.749Y-40.126
    N6920G1X91.260Y-40.144
    N6930G1X91.741Y-40.198
    N6940G1X92.192Y-40.290
    N6950G1X92.612Y-40.417
    N6960G1X93.001Y-40.581
    N6970G1X93.361Y-40.782
    N6980G1X93.689Y-41.018
    N6990G1X93.988Y-41.292
    N7000G1X94.253Y-41.603
    N7010G1X94.483Y-41.954
    N7020G1X94.678Y-42.344
    N7030G1X94.838Y-42.773
    N7040G1X94.961Y-43.242
    N7050G1X95.050Y-43.750
    N7060G1X95.103Y-44.297
    N7070G1X95.121Y-44.884
    N7080G1Y-54.601
    N7090G1X92.735
    N7100G1Y-45.684
    N7110G1X92.720Y-45.014
    N7120G1X92.677Y-44.446
    N7130G1X92.604Y-43.978
    N7140G1X92.502Y-43.611
    N7150G1X92.361Y-43.310
    N7160G1X92.173Y-43.040
    N7170G1X91.938Y-42.800
    N7180G1X91.655Y-42.591
    N7190G1X91.335Y-42.422
    N7200G1X90.989Y-42.301
    N7210G1X90.616Y-42.229
    N7220G1X90.216Y-42.205
    N7230G1X89.850Y-42.220
    N7240G1X89.501Y-42.267
    N7250G1X89.167Y-42.344
    N7260G1X88.850Y-42.453
    N7270G1X88.548Y-42.593
    N7280G1X88.261Y-42.763
    N7290G1X87.991Y-42.965
    N7300G1X87.737Y-43.198
    N7310G1X87.505Y-43.465
    N7320G1X87.305Y-43.769
    N7330G1X87.136Y-44.110
    N7340G1X86.997Y-44.489
    N7350G1X86.889Y-44.905
    N7360G1X86.812Y-45.358
    N7370G1X86.766Y-45.849
    N7380G1X86.750Y-46.377
    N7390G1Y-54.601
    N7400G1X84.351
    N7410G1Y-45.404
    N7420G1X84.342Y-45.016
    N7430G1X84.314Y-44.654
    N7440G1X84.269Y-44.317
    N7450G1X84.204Y-44.004
    N7460G1X84.122Y-43.717
    N7470G1X84.021Y-43.454
    N7480G1X83.902Y-43.217
    N7490G1X83.765Y-43.005
    N7500G1X83.606Y-42.817
    N7510G1X83.425Y-42.655
    N7520G1X83.220Y-42.517
    N7530G1X82.992Y-42.405
    N7540G1X82.740Y-42.317
    N7550G1X82.465Y-42.255
    N7560G1X82.167Y-42.217
    N7570G1X81.845Y-42.205
    N7580G1X81.594Y-42.213
    N7590G1X81.348Y-42.238
    N7600G1X81.107Y-42.280
    N7610G1X80.871Y-42.338
    N7620G1X80.639Y-42.413
    N7630G1X80.412Y-42.505
    N7640G1X80.190Y-42.613
    N7650G1X79.973Y-42.738
    N7660G1X79.765Y-42.879
    N7670G1X79.572Y-43.035
    N7680G1X79.394Y-43.207
    N7690G1X79.231Y-43.394
    N7700G1X79.083Y-43.597
    N7710G1X78.949Y-43.815
    N7720G1X78.830Y-44.049
    N7730G1X78.726Y-44.297
    N7740G1X78.636Y-44.568
    N7750G1X78.557Y-44.867
    N7760G1X78.491Y-45.195
    N7770G1X78.436Y-45.550
    N7780G1X78.364Y-46.347
    N7790G1X78.340Y-47.256
    N7800G1Y-54.601
    N7810G1X75.941
    N7820G1Y-40.445
    N7830G00Z5.999
    N7840G00X73.538Y-76.435
    N7850G1Z-1.000F1200.0
    N7860G1X73.191Y-76.615F3600.0
    N7870G1X72.803Y-76.789
    N7880G1X72.375Y-76.955
    N7890G1X71.905Y-77.115
    N7900G1X71.395Y-77.267
    N7910G1X70.844Y-77.413
    N7920G1X70.252Y-77.552
    N7930G1X69.620Y-77.684
    N7940G1X68.934Y-77.836
    N7950G1X68.357Y-77.996
    N7960G1X67.888Y-78.166
    N7970G1X67.527Y-78.345
    N7980G1X67.238Y-78.550
    N7990G1X66.984Y-78.797
    N8000G1X66.765Y-79.087
    N8010G1X66.581Y-79.420
    N8020G1X66.435Y-79.783
    N8030G1X66.331Y-80.166
    N8040G1X66.268Y-80.568
    N8050G1X66.247Y-80.990
    N8060G1X66.259Y-81.313
    N8070G1X66.293Y-81.623
    N8080G1X66.349Y-81.919
    N8090G1X66.429Y-82.202
    N8100G1X66.531Y-82.470
    N8110G1X66.656Y-82.725
    N8120G1X66.803Y-82.966
    N8130G1X66.974Y-83.194
    N8140G1X67.166Y-83.400
    N8150G1X67.379Y-83.579
    N8160G1X67.613Y-83.731
    N8170G1X67.868Y-83.855
    N8180G1X68.145Y-83.951
    N8190G1X68.442Y-84.020
    N8200G1X68.760Y-84.061
    N8210G1X69.100Y-84.075
    N8220G1X69.441Y-84.062
    N8230G1X69.774Y-84.023
    N8240G1X70.096Y-83.958
    N8250G1X70.409Y-83.866
    N8260G1X70.713Y-83.749
    N8270G1X71.007Y-83.605
    N8280G1X71.291Y-83.435
    N8290G1X71.566Y-83.239
    N8300G1X71.826Y-83.021
    N8310G1X72.070Y-82.783
    N8320G1X72.295Y-82.526
    N8330G1X72.502Y-82.250
    N8340G1X72.691Y-81.955
    N8350G1X72.863Y-81.640
    N8360G1X73.016Y-81.306
    N8370G1X73.152Y-80.953
    N8380G1X73.242Y-80.656
    N8390G1X73.321Y-80.326
    N8400G1X73.387Y-79.963
    N8410G1X73.442Y-79.566
    N8420G1X73.514Y-78.673
    N8430G1X73.538Y-77.647
    N8440G1Y-76.435
    N8450G00Z5.999
    N8460G00X72.756Y-74.165
    N8470G1Z-1.000F1200.0
    N8480G1X73.171Y-74.008F3600.0
    N8490G1X73.538Y-73.846
    N8500G1X73.552Y-72.983
    N8510G1X73.541Y-72.496
    N8520G1X73.509Y-72.047
    N8530G1X73.456Y-71.635
    N8540G1X73.382Y-71.261
    N8550G1X73.286Y-70.924
    N8560G1X73.169Y-70.624
    N8570G1X73.031Y-70.361
    N8580G1X72.872Y-70.136
    N8590G1X72.628Y-69.873
    N8600G1X72.356Y-69.646
    N8610G1X72.056Y-69.453
    N8620G1X71.729Y-69.296
    N8630G1X71.373Y-69.173
    N8640G1X70.990Y-69.086
    N8650G1X70.579Y-69.033
    N8660G1X70.139Y-69.016
    N8670G1X69.730Y-69.028
    N8680G1X69.348Y-69.067
    N8690G1X68.994Y-69.131
    N8700G1X68.668Y-69.220
    N8710G1X68.370Y-69.335
    N8720G1X68.099Y-69.475
    N8730G1X67.856Y-69.641
    N8740G1X67.640Y-69.833
    N8750G1X67.445Y-70.057
    N8760G1X67.263Y-70.320
    N8770G1X67.094Y-70.623
    N8780G1X66.939Y-70.965
    N8790G1X66.796Y-71.346
    N8800G1X66.667Y-71.766
    N8810G1X66.550Y-72.226
    N8820G1X66.447Y-72.725
    N8830G1X64.101Y-72.285
    N8840G1X64.188Y-71.778
    N8850G1X64.287Y-71.297
    N8860G1X64.399Y-70.841
    N8870G1X64.525Y-70.409
    N8880G1X64.663Y-70.003
    N8890G1X64.814Y-69.621
    N8900G1X64.978Y-69.265
    N8910G1X65.154Y-68.933
    N8920G1X65.348Y-68.623
    N8930G1X65.562Y-68.332
    N8940G1X65.796Y-68.058
    N8950G1X66.051Y-67.804
    N8960G1X66.326Y-67.567
    N8970G1X66.621Y-67.349
    N8980G1X66.937Y-67.149
    N8990G1X67.274Y-66.968
    N9000G1X67.627Y-66.807
    N9010G1X67.994Y-66.667
    N9020G1X68.375Y-66.548
    N9030G1X68.770Y-66.451
    N9040G1X69.178Y-66.376
    N9050G1X69.600Y-66.322
    N9060G1X70.036Y-66.290
    N9070G1X70.486Y-66.279
    N9080G1X70.928Y-66.288
    N9090G1X71.350Y-66.316
    N9100G1X71.750Y-66.362
    N9110G1X72.129Y-66.426
    N9120G1X72.486Y-66.509
    N9130G1X72.823Y-66.610
    N9140G1X73.138Y-66.729
    N9150G1X73.432Y-66.867
    N9160G1X73.705Y-67.019
    N9170G1X73.961Y-67.180
    N9180G1X74.197Y-67.350
    N9190G1X74.415Y-67.530
    N9200G1X74.613Y-67.720
    N9210G1X74.794Y-67.919
    N9220G1X74.955Y-68.127
    N9230G1X75.098Y-68.345
    N9240G1X75.226Y-68.575
    N9250G1X75.344Y-68.820
    N9260G1X75.551Y-69.353
    N9270G1X75.717Y-69.945
    N9280G1X75.844Y-70.595
    N9290G1X75.897Y-71.102
    N9300G1X75.934Y-71.780
    N9310G1X75.957Y-72.627
    N9320G1X75.964Y-73.644
    N9330G1Y-78.051
    N9340G1X75.974Y-80.144
    N9350G1X76.002Y-81.814
    N9360G1X76.050Y-83.060
    N9370G1X76.117Y-83.882
    N9380G1X76.213Y-84.487
    N9390G1X76.346Y-85.078
    N9400G1X76.516Y-85.657
    N9410G1X76.724Y-86.224
    N9420G1X74.218
    N9430G1X74.048Y-85.688
    N9440G1X73.911Y-85.108
    N9450G1X73.808Y-84.485
    N9460G1X73.738Y-83.818
    N9470G1X73.406Y-84.194
    N9480G1X73.078Y-84.541
    N9490G1X72.753Y-84.860
    N9500G1X72.430Y-85.149
    N9510G1X72.111Y-85.411
    N9520G1X71.795Y-85.643
    N9530G1X71.482Y-85.847
    N9540G1X71.172Y-86.022
    N9550G1X70.861Y-86.172
    N9560G1X70.545Y-86.303
    N9570G1X70.222Y-86.413
    N9580G1X69.894Y-86.504
    N9590G1X69.561Y-86.574
    N9600G1X69.222Y-86.624
    N9610G1X68.877Y-86.654
    N9620G1X68.527Y-86.665
    N9630G1X67.960Y-86.640
    N9640G1X67.428Y-86.566
    N9650G1X66.929Y-86.444
    N9660G1X66.464Y-86.272
    N9670G1X66.033Y-86.051
    N9680G1X65.635Y-85.781
    N9690G1X65.271Y-85.462
    N9700G1X64.941Y-85.094
    N9710G1X64.647Y-84.688
    N9720G1X64.393Y-84.255
    N9730G1X64.178Y-83.794
    N9740G1X64.001Y-83.306
    N9750G1X63.864Y-82.791
    N9760G1X63.767Y-82.248
    N9770G1X63.708Y-81.679
    N9780G1X63.688Y-81.082
    N9790G1X63.696Y-80.727
    N9800G1X63.718Y-80.381
    N9810G1X63.755Y-80.042
    N9820G1X63.806Y-79.711
    N9830G1X63.873Y-79.388
    N9840G1X63.954Y-79.072
    N9850G1X64.050Y-78.765
    N9860G1X64.161Y-78.465
    N9870G1X64.416Y-77.902
    N9880G1X64.557Y-77.642
    N9890G1X64.708Y-77.397
    N9900G1X64.867Y-77.167
    N9910G1X65.036Y-76.951
    N9920G1X65.214Y-76.750
    N9930G1X65.401Y-76.564
    N9940G1X65.796Y-76.227
    N9950G1X66.216Y-75.935
    N9960G1X66.659Y-75.686
    N9970G1X67.127Y-75.480
    N9980G1X67.525Y-75.353
    N9990G1X68.013Y-75.228
    N10000G1X68.592Y-75.105
    N10010G1X69.260Y-74.984
    N10020G1X70.617Y-74.734
    N10030G1X71.223Y-74.600
    N10040G1X71.782Y-74.461
    N10050G1X72.293Y-74.316
    N10060G1X72.756Y-74.165
    N10070G00Z5.999
    N10080G00X82.106Y-74.851
    N10090G1Z-1.000F1200.0
    N10100G1X82.082Y-76.105F3600.0
    N10110G1Y-86.224
    N10120G1X79.683
    N10130G1Y-66.720
    N10140G1X81.829
    N10150G1Y-69.456
    N10160G1X82.002Y-69.107
    N10170G1X82.189Y-68.775
    N10180G1X82.390Y-68.461
    N10190G1X82.605Y-68.164
    N10200G1X82.834Y-67.885
    N10210G1X83.076Y-67.623
    N10220G1X83.332Y-67.378
    N10230G1X83.601Y-67.152
    N10240G1X83.883Y-66.947
    N10250G1X84.174Y-66.770
    N10260G1X84.474Y-66.620
    N10270G1X84.784Y-66.497
    N10280G1X85.104Y-66.402
    N10290G1X85.433Y-66.334
    N10300G1X85.772Y-66.293
    N10310G1X86.121Y-66.279
    N10320G1X86.505Y-66.293
    N10330G1X86.872Y-66.336
    N10340G1X87.220Y-66.406
    N10350G1X87.552Y-66.504
    N10360G1X87.865Y-66.631
    N10370G1X88.161Y-66.786
    N10380G1X88.439Y-66.968
    N10390G1X88.700Y-67.179
    N10400G1X88.942Y-67.415
    N10410G1X89.166Y-67.674
    N10420G1X89.371Y-67.955
    N10430G1X89.558Y-68.258
    N10440G1X89.726Y-68.584
    N10450G1X89.876Y-68.932
    N10460G1X90.007Y-69.302
    N10470G1X90.119Y-69.695
    N10480G1X90.333Y-69.282
    N10490G1X90.555Y-68.895
    N10500G1X90.785Y-68.534
    N10510G1X91.022Y-68.201
    N10520G1X91.268Y-67.894
    N10530G1X91.521Y-67.614
    N10540G1X91.783Y-67.360
    N10550G1X92.052Y-67.133
    N10560G1X92.329Y-66.933
    N10570G1X92.614Y-66.760
    N10580G1X92.907Y-66.613
    N10590G1X93.208Y-66.493
    N10600G1X93.517Y-66.399
    N10610G1X93.834Y-66.333
    N10620G1X94.158Y-66.293
    N10630G1X94.491Y-66.279
    N10640G1X95.002Y-66.304
    N10650G1X95.483Y-66.380
    N10660G1X95.934Y-66.505
    N10670G1X96.354Y-66.681
    N10680G1X96.743Y-66.907
    N10690G1X97.103Y-67.183
    N10700G1X97.431Y-67.510
    N10710G1X97.730Y-67.886
    N10720G1X97.995Y-68.315
    N10730G1X98.226Y-68.798
    N10740G1X98.420Y-69.336
    N10750G1X98.580Y-69.927
    N10760G1X98.704Y-70.573
    N10770G1X98.792Y-71.273
    N10780G1X98.845Y-72.027
    N10790G1X98.863Y-72.836
    N10800G1Y-86.224
    N10810G1X96.477
    N10820G1Y-73.938
    N10830G1X96.462Y-73.015
    N10840G1X96.419Y-72.232
    N10850G1X96.346Y-71.587
    N10860G1X96.244Y-71.082
    N10870G1X96.103Y-70.667
    N10880G1X96.015Y-70.475
    N10890G1X95.916Y-70.294
    N10900G1X95.804Y-70.124
    N10910G1X95.680Y-69.964
    N10920G1X95.545Y-69.815
    N10930G1X95.397Y-69.677
    N10940G1X95.241Y-69.552
    N10950G1X95.077Y-69.444
    N10960G1X94.908Y-69.352
    N10970G1X94.731Y-69.277
    N10980G1X94.548Y-69.219
    N10990G1X94.358Y-69.178
    N11000G1X94.161Y-69.153
    N11010G1X93.958Y-69.144
    N11020G1X93.593Y-69.166
    N11030G1X93.243Y-69.230
    N11040G1X92.909Y-69.337
    N11050G1X92.592Y-69.486
    N11060G1X92.290Y-69.679
    N11070G1X92.004Y-69.914
    N11080G1X91.733Y-70.192
    N11090G1X91.479Y-70.512
    N11100G1X91.248Y-70.880
    N11110G1X91.047Y-71.299
    N11120G1X90.878Y-71.770
    N11130G1X90.739Y-72.292
    N11140G1X90.631Y-72.865
    N11150G1X90.554Y-73.489
    N11160G1X90.508Y-74.165
    N11170G1X90.492Y-74.893
    N11180G1Y-86.224
    N11190G1X88.093
    N11200G1Y-73.552
    N11210G1X88.084Y-73.018
    N11220G1X88.057Y-72.519
    N11230G1X88.011Y-72.054
    N11240G1X87.947Y-71.624
    N11250G1X87.864Y-71.228
    N11260G1X87.763Y-70.866
    N11270G1X87.644Y-70.539
    N11280G1X87.507Y-70.246
    N11290G1X87.348Y-69.988
    N11300G1X87.167Y-69.764
    N11310G1X86.962Y-69.575
    N11320G1X86.734Y-69.420
    N11330G1X86.482Y-69.299
    N11340G1X86.207Y-69.213
    N11350G1X85.909Y-69.161
    N11360G1X85.587Y-69.144
    N11370G1X85.337Y-69.156
    N11380G1X85.090Y-69.190
    N11390G1X84.849Y-69.248
    N11400G1X84.613Y-69.328
    N11410G1X84.381Y-69.431
    N11420G1X84.154Y-69.557
    N11430G1X83.932Y-69.707
    N11440G1X83.715Y-69.879
    N11450G1X83.507Y-70.073
    N11460G1X83.314Y-70.289
    N11470G1X83.136Y-70.525
    N11480G1X82.973Y-70.783
    N11490G1X82.825Y-71.063
    N11500G1X82.691Y-71.363
    N11510G1X82.572Y-71.685
    N11520G1X82.468Y-72.028
    N11530G1X82.378Y-72.401
    N11540G1X82.299Y-72.813
    N11550G1X82.233Y-73.264
    N11560G1X82.179Y-73.754
    N11570G1X82.106Y-74.851
    N11580G00Z5.999
    N11590G00X60.823Y-74.231
    N11600G1Z-1.000F1200.0
    N11610G1Y-86.224F3600.0
    N11620G1X58.423
    N11630G1Y-74.360
    N11640G1X58.406Y-73.414
    N11650G1X58.353Y-72.595
    N11660G1X58.266Y-71.903
    N11670G1X58.209Y-71.605
    N11680G1X58.143Y-71.339
    N11690G1X58.067Y-71.095
    N11700G1X57.976Y-70.864
    N11710G1X57.873Y-70.645
    N11720G1X57.755Y-70.439
    N11730G1X57.624Y-70.246
    N11740G1X57.480Y-70.065
    N11750G1X57.322Y-69.897
    N11760G1X57.150Y-69.741
    N11770G1X56.968Y-69.601
    N11780G1X56.778Y-69.480
    N11790G1X56.581Y-69.377
    N11800G1X56.376Y-69.293
    N11810G1X56.163Y-69.228
    N11820G1X55.942Y-69.182
    N11830G1X55.714Y-69.154
    N11840G1X55.478Y-69.144
    N11850G1X55.101Y-69.165
    N11860G1X54.738Y-69.228
    N11870G1X54.387Y-69.333
    N11880G1X54.050Y-69.479
    N11890G1X53.726Y-69.668
    N11900G1X53.415Y-69.898
    N11910G1X53.117Y-70.171
    N11920G1X52.832Y-70.485
    N11930G1X52.697Y-70.662
    N11940G1X52.571Y-70.858
    N11950G1X52.454Y-71.072
    N11960G1X52.345Y-71.306
    N11970G1X52.154Y-71.829
    N11980G1X51.997Y-72.427
    N11990G1X51.875Y-73.101
    N12000G1X51.789Y-73.849
    N12010G1X51.736Y-74.673
    N12020G1X51.719Y-75.572
    N12030G1Y-86.224
    N12040G1X49.320
    N12050G1Y-66.720
    N12060G1X51.479
    N12070G1Y-69.493
    N12080G1X51.679Y-69.104
    N12090G1X51.891Y-68.740
    N12100G1X52.113Y-68.401
    N12110G1X52.345Y-68.087
    N12120G1X52.589Y-67.798
    N12130G1X52.844Y-67.535
    N12140G1X53.109Y-67.296
    N12150G1X53.385Y-67.083
    N12160G1X53.672Y-66.894
    N12170G1X53.970Y-66.731
    N12180G1X54.278Y-66.593
    N12190G1X54.598Y-66.480
    N12200G1X54.928Y-66.392
    N12210G1X55.269Y-66.330
    N12220G1X55.621Y-66.292
    N12230G1X55.984Y-66.279
    N12240G1X56.301Y-66.289
    N12250G1X56.611Y-66.319
    N12260G1X56.915Y-66.368
    N12270G1X57.212Y-66.438
    N12280G1X57.503Y-66.527
    N12290G1X57.787Y-66.636
    N12300G1X58.065Y-66.764
    N12310G1X58.337Y-66.913
    N12320G1X58.597Y-67.077
    N12330G1X58.839Y-67.254
    N12340G1X59.066Y-67.444
    N12350G1X59.275Y-67.645
    N12360G1X59.467Y-67.859
    N12370G1X59.642Y-68.085
    N12380G1X59.801Y-68.324
    N12390G1X59.943Y-68.575
    N12400G1X60.189Y-69.113
    N12410G1X60.396Y-69.700
    N12420G1X60.563Y-70.335
    N12430G1X60.689Y-71.018
    N12440G1X60.748Y-71.563
    N12450G1X60.789Y-72.280
    N12460G1X60.814Y-73.170
    N12470G1X60.823Y-74.231
    N12480G00Z5.999
    N12490G00X39.696Y-66.720
    N12500G1Z-1.000F1200.0
    N12510G1X34.312Y-86.554F3600.0
    N12520G1X33.903Y-88.036
    N12530G1X33.542Y-89.268
    N12540G1X33.229Y-90.249
    N12550G1X32.965Y-90.980
    N12560G1X32.802Y-91.375
    N12570G1X32.634Y-91.743
    N12580G1X32.459Y-92.084
    N12590G1X32.279Y-92.397
    N12600G1X32.093Y-92.683
    N12610G1X31.901Y-92.941
    N12620G1X31.703Y-93.173
    N12630G1X31.499Y-93.377
    N12640G1X31.288Y-93.556
    N12650G1X31.066Y-93.710
    N12660G1X30.834Y-93.841
    N12670G1X30.593Y-93.949
    N12680G1X30.341Y-94.032
    N12690G1X30.080Y-94.091
    N12700G1X29.808Y-94.127
    N12710G1X29.527Y-94.139
    N12720G1X29.170Y-94.114
    N12730G1X28.793Y-94.038
    N12740G1X28.397Y-93.912
    N12750G1X27.980Y-93.735
    N12760G1X27.714Y-90.631
    N12770G1X28.095Y-90.760
    N12780G1X28.450Y-90.852
    N12790G1X28.781Y-90.907
    N12800G1X29.087Y-90.925
    N12810G1X29.467Y-90.902
    N12820G1X29.806Y-90.833
    N12830G1X30.106Y-90.719
    N12840G1X30.241Y-90.644
    N12850G1X30.366Y-90.558
    N12860G1X30.595Y-90.356
    N12870G1X30.803Y-90.117
    N12880G1X30.989Y-89.842
    N12890G1X31.153Y-89.529
    N12900G1X31.283Y-89.190
    N12910G1X31.449Y-88.666
    N12920G1X31.886Y-87.069
    N12930G1X32.099Y-86.260
    N12940G1X26.727Y-66.720
    N12950G1X29.313
    N12960G1X32.259Y-78.015
    N12970G1X32.538Y-79.103
    N12980G1X32.802Y-80.218
    N12990G1X33.051Y-81.362
    N13000G1X33.285Y-82.532
    N13010G1X33.502Y-81.401
    N13020G1X33.738Y-80.283
    N13030G1X33.995Y-79.178
    N13040G1X34.272Y-78.088
    N13050G1X37.297Y-66.720
    N13060G1X39.696
    N13070G00Z5.999
    N13080G00X24.245Y-69.927
    N13090G1Z-1.000F1200.0
    N13100G1X24.369Y-70.573F3600.0
    N13110G1X24.457Y-71.273
    N13120G1X24.511Y-72.027
    N13130G1X24.528Y-72.836
    N13140G1Y-86.224
    N13150G1X22.142
    N13160G1Y-73.938
    N13170G1X22.128Y-73.015
    N13180G1X22.084Y-72.232
    N13190G1X22.011Y-71.587
    N13200G1X21.909Y-71.082
    N13210G1X21.769Y-70.667
    N13220G1X21.681Y-70.475
    N13230G1X21.581Y-70.294
    N13240G1X21.469Y-70.124
    N13250G1X21.346Y-69.964
    N13260G1X21.210Y-69.815
    N13270G1X21.063Y-69.677
    N13280G1X20.906Y-69.552
    N13290G1X20.743Y-69.444
    N13300G1X20.573Y-69.352
    N13310G1X20.396Y-69.277
    N13320G1X20.213Y-69.219
    N13330G1X20.023Y-69.178
    N13340G1X19.826Y-69.153
    N13350G1X19.623Y-69.144
    N13360G1X19.258Y-69.166
    N13370G1X18.908Y-69.230
    N13380G1X18.575Y-69.337
    N13390G1X18.257Y-69.486
    N13400G1X17.955Y-69.679
    N13410G1X17.669Y-69.914
    N13420G1X17.399Y-70.192
    N13430G1X17.144Y-70.512
    N13440G1X16.913Y-70.880
    N13450G1X16.713Y-71.299
    N13460G1X16.543Y-71.770
    N13470G1X16.404Y-72.292
    N13480G1X16.296Y-72.865
    N13490G1X16.219Y-73.489
    N13500G1X16.173Y-74.165
    N13510G1X16.158Y-74.893
    N13520G1Y-86.224
    N13530G1X13.759
    N13540G1Y-73.552
    N13550G1X13.749Y-73.018
    N13560G1X13.722Y-72.519
    N13570G1X13.676Y-72.054
    N13580G1X13.612Y-71.624
    N13590G1X13.529Y-71.228
    N13600G1X13.429Y-70.866
    N13610G1X13.310Y-70.539
    N13620G1X13.172Y-70.246
    N13630G1X13.014Y-69.988
    N13640G1X12.832Y-69.764
    N13650G1X12.627Y-69.575
    N13660G1X12.399Y-69.420
    N13670G1X12.147Y-69.299
    N13680G1X11.873Y-69.213
    N13690G1X11.574Y-69.161
    N13700G1X11.253Y-69.144
    N13710G1X11.002Y-69.156
    N13720G1X10.756Y-69.190
    N13730G1X10.515Y-69.248
    N13740G1X10.278Y-69.328
    N13750G1X10.046Y-69.431
    N13760G1X9.819Y-69.557
    N13770G1X9.597Y-69.707
    N13780G1X9.380Y-69.879
    N13790G1X9.173Y-70.073
    N13800G1X8.980Y-70.289
    N13810G1X8.802Y-70.525
    N13820G1X8.639Y-70.783
    N13830G1X8.490Y-71.063
    N13840G1X8.357Y-71.363
    N13850G1X8.238Y-71.685
    N13860G1X8.134Y-72.028
    N13870G1X8.043Y-72.401
    N13880G1X7.965Y-72.813
    N13890G1X7.898Y-73.264
    N13900G1X7.844Y-73.754
    N13910G1X7.771Y-74.851
    N13920G1X7.747Y-76.105
    N13930G1Y-86.224
    N13940G1X5.348
    N13950G1Y-66.720
    N13960G1X7.494
    N13970G1Y-69.456
    N13980G1X7.668Y-69.107
    N13990G1X7.855Y-68.775
    N14000G1X8.056Y-68.461
    N14010G1X8.270Y-68.164
    N14020G1X8.499Y-67.885
    N14030G1X8.741Y-67.623
    N14040G1X8.997Y-67.378
    N14050G1X9.267Y-67.152
    N14060G1X9.548Y-66.947
    N14070G1X9.839Y-66.770
    N14080G1X10.140Y-66.620
    N14090G1X10.450Y-66.497
    N14100G1X10.769Y-66.402
    N14110G1X11.099Y-66.334
    N14120G1X11.437Y-66.293
    N14130G1X11.786Y-66.279
    N14140G1X12.170Y-66.293
    N14150G1X12.537Y-66.336
    N14160G1X12.886Y-66.406
    N14170G1X13.217Y-66.504
    N14180G1X13.531Y-66.631
    N14190G1X13.826Y-66.786
    N14200G1X14.105Y-66.968
    N14210G1X14.365Y-67.179
    N14220G1X14.607Y-67.415
    N14230G1X14.831Y-67.674
    N14240G1X15.036Y-67.955
    N14250G1X15.223Y-68.258
    N14260G1X15.391Y-68.584
    N14270G1X15.541Y-68.932
    N14280G1X15.672Y-69.302
    N14290G1X15.785Y-69.695
    N14300G1X15.998Y-69.282
    N14310G1X16.220Y-68.895
    N14320G1X16.450Y-68.534
    N14330G1X16.688Y-68.201
    N14340G1X16.933Y-67.894
    N14350G1X17.187Y-67.614
    N14360G1X17.448Y-67.360
    N14370G1X17.717Y-67.133
    N14380G1X17.994Y-66.933
    N14390G1X18.280Y-66.760
    N14400G1X18.573Y-66.613
    N14410G1X18.873Y-66.493
    N14420G1X19.182Y-66.399
    N14430G1X19.499Y-66.333
    N14440G1X19.824Y-66.293
    N14450G1X20.156Y-66.279
    N14460G1X20.668Y-66.304
    N14470G1X21.149Y-66.380
    N14480G1X21.599Y-66.505
    N14490G1X22.019Y-66.681
    N14500G1X22.409Y-66.907
    N14510G1X22.768Y-67.183
    N14520G1X23.097Y-67.510
    N14530G1X23.395Y-67.886
    N14540G1X23.661Y-68.315
    N14550G1X23.891Y-68.798
    N14560G1X24.086Y-69.336
    N14570G1X24.245Y-69.927
    N14580G00Z5.999
    N14590G00X12.719Y-115.204
    N14600G1Z-1.000F1200.0
    N14610G1Y-118.528F3600.0
    N14620G1X5.348
    N14630G1Y-115.204
    N14640G1X12.719
    N14650G00Z5.999
    N14660G00X23.579Y-121.173
    N14670G1Z-1.000F1200.0
    N14680G1X23.842Y-120.732F3600.0
    N14690G1X24.128Y-120.282
    N14700G1X24.445Y-119.816
    N14710G1X25.170Y-118.831
    N14720G1X26.015Y-117.777
    N14730G1X26.981Y-116.655
    N14740G1X27.745Y-115.778
    N14750G1X28.444Y-114.948
    N14760G1X29.079Y-114.165
    N14770G1X29.650Y-113.429
    N14780G1X30.156Y-112.740
    N14790G1X30.597Y-112.097
    N14800G1X30.974Y-111.501
    N14810G1X31.286Y-110.952
    N14820G1X31.548Y-110.430
    N14830G1X31.776Y-109.915
    N14840G1X31.968Y-109.407
    N14850G1X32.126Y-108.907
    N14860G1X32.248Y-108.413
    N14870G1X32.336Y-107.927
    N14880G1X32.388Y-107.448
    N14890G1X32.406Y-106.976
    N14900G1X32.390Y-106.495
    N14910G1X32.342Y-106.032
    N14920G1X32.262Y-105.589
    N14930G1X32.151Y-105.165
    N14940G1X32.007Y-104.760
    N14950G1X31.832Y-104.375
    N14960G1X31.625Y-104.008
    N14970G1X31.386Y-103.661
    N14980G1X31.121Y-103.345
    N14990G1X30.837Y-103.071
    N15000G1X30.534Y-102.839
    N15010G1X30.211Y-102.649
    N15020G1X29.869Y-102.501
    N15030G1X29.508Y-102.396
    N15040G1X29.127Y-102.333
    N15050G1X28.727Y-102.312
    N15060G1X28.304Y-102.334
    N15070G1X27.904Y-102.401
    N15080G1X27.525Y-102.513
    N15090G1X27.167Y-102.670
    N15100G1X26.832Y-102.871
    N15110G1X26.518Y-103.117
    N15120G1X26.225Y-103.408
    N15130G1X25.954Y-103.744
    N15140G1X25.711Y-104.119
    N15150G1X25.499Y-104.529
    N15160G1X25.319Y-104.973
    N15170G1X25.171Y-105.452
    N15180G1X25.056Y-105.965
    N15190G1X24.972Y-106.513
    N15200G1X24.921Y-107.095
    N15210G1X24.901Y-107.711
    N15220G1X22.436Y-107.362
    N15230G1X22.521Y-106.440
    N15240G1X22.650Y-105.574
    N15250G1X22.822Y-104.765
    N15260G1X23.039Y-104.013
    N15270G1X23.163Y-103.658
    N15280G1X23.299Y-103.317
    N15290G1X23.445Y-102.990
    N15300G1X23.603Y-102.677
    N15310G1X23.771Y-102.379
    N15320G1X23.950Y-102.094
    N15330G1X24.140Y-101.824
    N15340G1X24.342Y-101.568
    N15350G1X24.553Y-101.326
    N15360G1X24.773Y-101.101
    N15370G1X25.001Y-100.891
    N15380G1X25.239Y-100.696
    N15390G1X25.485Y-100.517
    N15400G1X25.741Y-100.354
    N15410G1X26.005Y-100.206
    N15420G1X26.278Y-100.073
    N15430G1X26.559Y-99.957
    N15440G1X26.850Y-99.855
    N15450G1X27.150Y-99.770
    N15460G1X27.458Y-99.700
    N15470G1X27.775Y-99.645
    N15480G1X28.101Y-99.606
    N15490G1X28.436Y-99.583
    N15500G1X28.780Y-99.575
    N15510G1X29.127Y-99.584
    N15520G1X29.465Y-99.609
    N15530G1X29.794Y-99.651
    N15540G1X30.113Y-99.709
    N15550G1X30.423Y-99.785
    N15560G1X30.724Y-99.877
    N15570G1X31.016Y-99.986
    N15580G1X31.299Y-100.112
    N15590G1X31.573Y-100.255
    N15600G1X31.837Y-100.415
    N15610G1X32.093Y-100.591
    N15620G1X32.339Y-100.784
    N15630G1X32.576Y-100.994
    N15640G1X32.804Y-101.220
    N15650G1X33.022Y-101.464
    N15660G1X33.232Y-101.724
    N15670G1X33.430Y-101.996
    N15680G1X33.616Y-102.277
    N15690G1X33.789Y-102.566
    N15700G1X33.949Y-102.863
    N15710G1X34.231Y-103.480
    N15720G1X34.462Y-104.130
    N15730G1X34.641Y-104.812
    N15740G1X34.769Y-105.525
    N15750G1X34.846Y-106.272
    N15760G1X34.871Y-107.050
    N15770G1X34.864Y-107.453
    N15780G1X34.841Y-107.854
    N15790G1X34.804Y-108.254
    N15800G1X34.751Y-108.652
    N15810G1X34.684Y-109.048
    N15820G1X34.601Y-109.443
    N15830G1X34.392Y-110.227
    N15840G1X34.262Y-110.620
    N15850G1X34.112Y-111.018
    N15860G1X33.943Y-111.421
    N15870G1X33.753Y-111.829
    N15880G1X33.544Y-112.243
    N15890G1X33.316Y-112.661
    N15900G1X32.799Y-113.514
    N15910G1X32.497Y-113.966
    N15920G1X32.150Y-114.458
    N15930G1X31.318Y-115.562
    N15940G1X30.301Y-116.827
    N15950G1X29.100Y-118.252
    N15960G1X28.117Y-119.401
    N15970G1X27.327Y-120.348
    N15980G1X26.731Y-121.095
    N15990G1X26.328Y-121.641
    N16000G1X26.034Y-122.087
    N16010G1X25.768Y-122.534
    N16020G1X25.528Y-122.982
    N16030G1X25.315Y-123.431
    N16040G1X34.898
    N16050G1Y-126.609
    N16060G1X21.982
    N16070G1X21.990Y-126.017
    N16080G1X22.039Y-125.438
    N16090G1X22.130Y-124.870
    N16100G1X22.262Y-124.313
    N16110G1X22.395Y-123.859
    N16120G1X22.546Y-123.407
    N16130G1X22.716Y-122.957
    N16140G1X22.904Y-122.509
    N16150G1X23.110Y-122.062
    N16160G1X23.336Y-121.617
    N16170G1X23.579Y-121.173
    N16180G00Z5.999
    N16190G00X37.470Y-119.556
    N16200G1Z-1.000F1200.0
    N16210G1X39.990Y-119.262F3600.0
    N16220G1X40.071Y-119.876
    N16230G1X40.176Y-120.451
    N16240G1X40.304Y-120.986
    N16250G1X40.454Y-121.482
    N16260G1X40.628Y-121.939
    N16270G1X40.826Y-122.356
    N16280G1X41.046Y-122.734
    N16290G1X41.289Y-123.073
    N16300G1X41.551Y-123.372
    N16310G1X41.825Y-123.632
    N16320G1X42.113Y-123.851
    N16330G1X42.414Y-124.031
    N16340G1X42.728Y-124.170
    N16350G1X43.055Y-124.270
    N16360G1X43.395Y-124.330
    N16370G1X43.748Y-124.350
    N16380G1X44.173Y-124.321
    N16390G1X44.581Y-124.237
    N16400G1X44.973Y-124.097
    N16410G1X45.348Y-123.900
    N16420G1X45.706Y-123.647
    N16430G1X46.048Y-123.337
    N16440G1X46.372Y-122.972
    N16450G1X46.681Y-122.550
    N16460G1X46.962Y-122.082
    N16470G1X47.205Y-121.576
    N16480G1X47.412Y-121.035
    N16490G1X47.580Y-120.456
    N16500G1X47.712Y-119.841
    N16510G1X47.805Y-119.189
    N16520G1X47.862Y-118.500
    N16530G1X47.880Y-117.775
    N16540G1X47.862Y-117.087
    N16550G1X47.808Y-116.435
    N16560G1X47.718Y-115.822
    N16570G1X47.592Y-115.245
    N16580G1X47.430Y-114.706
    N16590G1X47.232Y-114.204
    N16600G1X46.998Y-113.739
    N16610G1X46.727Y-113.312
    N16620G1X46.428Y-112.929
    N16630G1X46.106Y-112.597
    N16640G1X45.762Y-112.316
    N16650G1X45.396Y-112.086
    N16660G1X45.008Y-111.908
    N16670G1X44.597Y-111.780
    N16680G1X44.164Y-111.703
    N16690G1X43.708Y-111.678
    N16700G1X43.422Y-111.689
    N16710G1X43.143Y-111.723
    N16720G1X42.871Y-111.780
    N16730G1X42.605Y-111.859
    N16740G1X42.347Y-111.961
    N16750G1X42.096Y-112.086
    N16760G1X41.853Y-112.233
    N16770G1X41.616Y-112.403
    N16780G1X41.389Y-112.591
    N16790G1X41.174Y-112.793
    N16800G1X40.972Y-113.008
    N16810G1X40.783Y-113.236
    N16820G1X40.606Y-113.479
    N16830G1X40.441Y-113.734
    N16840G1X40.289Y-114.003
    N16850G1X40.150Y-114.286
    N16860G1X37.897Y-113.882
    N16870G1X39.790Y-100.053
    N16880G1X49.506
    N16890G1Y-103.211
    N16900G1X41.709
    N16910G1X40.656Y-110.447
    N16920G1X41.099Y-110.051
    N16930G1X41.547Y-109.708
    N16940G1X42.000Y-109.418
    N16950G1X42.459Y-109.180
    N16960G1X42.923Y-108.995
    N16970G1X43.393Y-108.863
    N16980G1X43.868Y-108.784
    N16990G1X44.348Y-108.758
    N17000G1X44.665Y-108.767
    N17010G1X44.975Y-108.796
    N17020G1X45.280Y-108.844
    N17030G1X45.578Y-108.910
    N17040G1X45.869Y-108.996
    N17050G1X46.155Y-109.101
    N17060G1X46.434Y-109.225
    N17070G1X46.707Y-109.368
    N17080G1X46.974Y-109.531
    N17090G1X47.235Y-109.712
    N17100G1X47.489Y-109.912
    N17110G1X47.737Y-110.132
    N17120G1X47.979Y-110.370
    N17130G1X48.214Y-110.628
    N17140G1X48.444Y-110.904
    N17150G1X48.667Y-111.200
    N17160G1X48.880Y-111.511
    N17170G1X49.079Y-111.833
    N17180G1X49.265Y-112.165
    N17190G1X49.436Y-112.509
    N17200G1X49.594Y-112.863
    N17210G1X49.739Y-113.228
    N17220G1X49.869Y-113.605
    N17230G1X49.986Y-113.992
    N17240G1X50.089Y-114.390
    N17250G1X50.179Y-114.799
    N17260G1X50.254Y-115.218
    N17270G1X50.316Y-115.649
    N17280G1X50.399Y-116.543
    N17290G1X50.426Y-117.481
    N17300G1X50.402Y-118.379
    N17310G1X50.329Y-119.246
    N17320G1X50.209Y-120.083
    N17330G1X50.040Y-120.888
    N17340G1X49.822Y-121.662
    N17350G1X49.556Y-122.405
    N17360G1X49.242Y-123.117
    N17370G1X48.880Y-123.799
    N17380G1X48.640Y-124.195
    N17390G1X48.389Y-124.565
    N17400G1X48.127Y-124.910
    N17410G1X47.854Y-125.229
    N17420G1X47.571Y-125.523
    N17430G1X47.277Y-125.791
    N17440G1X46.973Y-126.033
    N17450G1X46.657Y-126.250
    N17460G1X46.331Y-126.442
    N17470G1X45.994Y-126.608
    N17480G1X45.647Y-126.748
    N17490G1X45.289Y-126.863
    N17500G1X44.920Y-126.953
    N17510G1X44.540Y-127.017
    N17520G1X44.150Y-127.055
    N17530G1X43.748Y-127.068
    N17540G1X43.419Y-127.060
    N17550G1X43.097Y-127.036
    N17560G1X42.783Y-126.995
    N17570G1X42.477Y-126.939
    N17580G1X42.178Y-126.867
    N17590G1X41.887Y-126.778
    N17600G1X41.603Y-126.674
    N17610G1X41.327Y-126.553
    N17620G1X41.059Y-126.417
    N17630G1X40.799Y-126.264
    N17640G1X40.546Y-126.095
    N17650G1X40.301Y-125.911
    N17660G1X40.063Y-125.710
    N17670G1X39.833Y-125.493
    N17680G1X39.611Y-125.260
    N17690G1X39.396Y-125.011
    N17700G1X39.191Y-124.748
    N17710G1X38.998Y-124.476
    N17720G1X38.815Y-124.192
    N17730G1X38.644Y-123.899
    N17740G1X38.335Y-123.280
    N17750G1X38.072Y-122.619
    N17760G1X37.854Y-121.916
    N17770G1X37.681Y-121.171
    N17780G1X37.553Y-120.385
    N17790G1X37.470Y-119.556
    N17800G00Z5.999
    N17810G00X53.318Y-126.609
    N17820G1Z-1.000F1200.0
    N17830G1Y-107.105F3600.0
    N17840G1X55.464
    N17850G1Y-109.841
    N17860G1X55.638Y-109.492
    N17870G1X55.825Y-109.160
    N17880G1X56.026Y-108.846
    N17890G1X56.241Y-108.549
    N17900G1X56.469Y-108.269
    N17910G1X56.711Y-108.008
    N17920G1X56.967Y-107.763
    N17930G1X57.237Y-107.536
    N17940G1X57.518Y-107.332
    N17950G1X57.809Y-107.155
    N17960G1X58.110Y-107.005
    N17970G1X58.420Y-106.882
    N17980G1X58.740Y-106.787
    N17990G1X59.069Y-106.719
    N18000G1X59.408Y-106.678
    N18010G1X59.756Y-106.664
    N18020G1X60.141Y-106.678
    N18030G1X60.507Y-106.720
    N18040G1X60.856Y-106.791
    N18050G1X61.187Y-106.889
    N18060G1X61.501Y-107.016
    N18070G1X61.797Y-107.170
    N18080G1X62.075Y-107.353
    N18090G1X62.335Y-107.564
    N18100G1X62.578Y-107.800
    N18110G1X62.801Y-108.059
    N18120G1X63.007Y-108.340
    N18130G1X63.193Y-108.643
    N18140G1X63.362Y-108.969
    N18150G1X63.511Y-109.317
    N18160G1X63.642Y-109.687
    N18170G1X63.755Y-110.080
    N18180G1X63.969Y-109.666
    N18190G1X64.191Y-109.279
    N18200G1X64.420Y-108.919
    N18210G1X64.658Y-108.586
    N18220G1X64.903Y-108.279
    N18230G1X65.157Y-107.998
    N18240G1X65.418Y-107.745
    N18250G1X65.688Y-107.518
    N18260G1X65.965Y-107.318
    N18270G1X66.250Y-107.144
    N18280G1X66.543Y-106.998
    N18290G1X66.844Y-106.878
    N18300G1X67.153Y-106.784
    N18310G1X67.469Y-106.717
    N18320G1X67.794Y-106.677
    N18330G1X68.127Y-106.664
    N18340G1X68.638Y-106.689
    N18350G1X69.119Y-106.765
    N18360G1X69.569Y-106.890
    N18370G1X69.989Y-107.066
    N18380G1X70.379Y-107.292
    N18390G1X70.738Y-107.568
    N18400G1X71.067Y-107.894
    N18410G1X71.366Y-108.271
    N18420G1X71.631Y-108.700
    N18430G1X71.861Y-109.183
    N18440G1X72.056Y-109.720
    N18450G1X72.215Y-110.312
    N18460G1X72.339Y-110.958
    N18470G1X72.428Y-111.658
    N18480G1X72.481Y-112.412
    N18490G1X72.499Y-113.220
    N18500G1Y-126.609
    N18510G1X70.113
    N18520G1Y-114.322
    N18530G1X70.098Y-113.400
    N18540G1X70.054Y-112.617
    N18550G1X69.981Y-111.972
    N18560G1X69.879Y-111.467
    N18570G1X69.739Y-111.052
    N18580G1X69.651Y-110.860
    N18590G1X69.551Y-110.679
    N18600G1X69.439Y-110.509
    N18610G1X69.316Y-110.349
    N18620G1X69.180Y-110.200
    N18630G1X69.033Y-110.062
    N18640G1X68.876Y-109.937
    N18650G1X68.713Y-109.829
    N18660G1X68.543Y-109.737
    N18670G1X68.367Y-109.662
    N18680G1X68.183Y-109.604
    N18690G1X67.993Y-109.562
    N18700G1X67.797Y-109.537
    N18710G1X67.594Y-109.529
    N18720G1X67.228Y-109.550
    N18730G1X66.879Y-109.615
    N18740G1X66.545Y-109.721
    N18750G1X66.227Y-109.871
    N18760G1X65.925Y-110.063
    N18770G1X65.639Y-110.299
    N18780G1X65.369Y-110.577
    N18790G1X65.114Y-110.897
    N18800G1X64.883Y-111.265
    N18810G1X64.683Y-111.684
    N18820G1X64.513Y-112.155
    N18830G1X64.375Y-112.676
    N18840G1X64.267Y-113.250
    N18850G1X64.190Y-113.874
    N18860G1X64.143Y-114.550
    N18870G1X64.128Y-115.277
    N18880G1Y-126.609
    N18890G1X61.729
    N18900G1Y-113.937
    N18910G1X61.720Y-113.403
    N18920G1X61.692Y-112.904
    N18930G1X61.646Y-112.439
    N18940G1X61.582Y-112.008
    N18950G1X61.500Y-111.612
    N18960G1X61.399Y-111.251
    N18970G1X61.280Y-110.924
    N18980G1X61.142Y-110.631
    N18990G1X60.984Y-110.373
    N19000G1X60.803Y-110.149
    N19010G1X60.598Y-109.959
    N19020G1X60.369Y-109.804
    N19030G1X60.118Y-109.684
    N19040G1X59.843Y-109.598
    N19050G1X59.545Y-109.546
    N19060G1X59.223Y-109.529
    N19070G1X58.972Y-109.540
    N19080G1X58.726Y-109.575
    N19090G1X58.485Y-109.632
    N19100G1X58.248Y-109.713
    N19110G1X58.017Y-109.816
    N19120G1X57.790Y-109.942
    N19130G1X57.568Y-110.091
    N19140G1X57.350Y-110.264
    N19150G1X57.143Y-110.458
    N19160G1X56.950Y-110.673
    N19170G1X56.772Y-110.910
    N19180G1X56.609Y-111.168
    N19190G1X56.461Y-111.447
    N19200G1X56.327Y-111.748
    N19210G1X56.208Y-112.069
    N19220G1X56.104Y-112.412
    N19230G1X56.014Y-112.785
    N19240G1X55.935Y-113.197
    N19250G1X55.869Y-113.649
    N19260G1X55.814Y-114.139
    N19270G1X55.742Y-115.236
    N19280G1X55.718Y-116.489
    N19290G1Y-126.609
    N19300G1X53.318
    N19310G00Z5.999
    N19320G00X76.057
    N19330G1Z-1.000F1200.0
    N19340G1Y-107.105F3600.0
    N19350G1X78.203
    N19360G1Y-109.841
    N19370G1X78.377Y-109.492
    N19380G1X78.564Y-109.160
    N19390G1X78.765Y-108.846
    N19400G1X78.980Y-108.549
    N19410G1X79.208Y-108.269
    N19420G1X79.450Y-108.008
    N19430G1X79.706Y-107.763
    N19440G1X79.976Y-107.536
    N19450G1X80.257Y-107.332
    N19460G1X80.548Y-107.155
    N19470G1X80.849Y-107.005
    N19480G1X81.159Y-106.882
    N19490G1X81.479Y-106.787
    N19500G1X81.808Y-106.719
    N19510G1X82.147Y-106.678
    N19520G1X82.495Y-106.664
    N19530G1X82.879Y-106.678
    N19540G1X83.246Y-106.720
    N19550G1X83.595Y-106.791
    N19560G1X83.926Y-106.889
    N19570G1X84.240Y-107.016
    N19580G1X84.536Y-107.170
    N19590G1X84.814Y-107.353
    N19600G1X85.074Y-107.564
    N19610G1X85.317Y-107.800
    N19620G1X85.540Y-108.059
    N19630G1X85.746Y-108.340
    N19640G1X85.932Y-108.643
    N19650G1X86.100Y-108.969
    N19660G1X86.250Y-109.317
    N19670G1X86.381Y-109.687
    N19680G1X86.494Y-110.080
    N19690G1X86.708Y-109.666
    N19700G1X86.929Y-109.279
    N19710G1X87.159Y-108.919
    N19720G1X87.397Y-108.586
    N19730G1X87.642Y-108.279
    N19740G1X87.896Y-107.998
    N19750G1X88.157Y-107.745
    N19760G1X88.426Y-107.518
    N19770G1X88.704Y-107.318
    N19780G1X88.989Y-107.144
    N19790G1X89.282Y-106.998
    N19800G1X89.583Y-106.878
    N19810G1X89.892Y-106.784
    N19820G1X90.208Y-106.717
    N19830G1X90.533Y-106.677
    N19840G1X90.866Y-106.664
    N19850G1X91.377Y-106.689
    N19860G1X91.858Y-106.765
    N19870G1X92.308Y-106.890
    N19880G1X92.728Y-107.066
    N19890G1X93.118Y-107.292
    N19900G1X93.477Y-107.568
    N19910G1X93.806Y-107.894
    N19920G1X94.104Y-108.271
    N19930G1X94.370Y-108.700
    N19940G1X94.600Y-109.183
    N19950G1X94.795Y-109.720
    N19960G1X94.954Y-110.312
    N19970G1X95.078Y-110.958
    N19980G1X95.167Y-111.658
    N19990G1X95.220Y-112.412
    N20000G1X95.237Y-113.220
    N20010G1Y-126.609
    N20020G1X92.852
    N20030G1Y-114.322
    N20040G1X92.837Y-113.400
    N20050G1X92.793Y-112.617
    N20060G1X92.720Y-111.972
    N20070G1X92.618Y-111.467
    N20080G1X92.478Y-111.052
    N20090G1X92.390Y-110.860
    N20100G1X92.290Y-110.679
    N20110G1X92.178Y-110.509
    N20120G1X92.055Y-110.349
    N20130G1X91.919Y-110.200
    N20140G1X91.772Y-110.062
    N20150G1X91.615Y-109.937
    N20160G1X91.452Y-109.829
    N20170G1X91.282Y-109.737
    N20180G1X91.106Y-109.662
    N20190G1X90.922Y-109.604
    N20200G1X90.732Y-109.562
    N20210G1X90.536Y-109.537
    N20220G1X90.332Y-109.529
    N20230G1X89.967Y-109.550
    N20240G1X89.618Y-109.615
    N20250G1X89.284Y-109.721
    N20260G1X88.966Y-109.871
    N20270G1X88.664Y-110.063
    N20280G1X88.378Y-110.299
    N20290G1X88.108Y-110.577
    N20300G1X87.853Y-110.897
    N20310G1X87.622Y-111.265
    N20320G1X87.422Y-111.684
    N20330G1X87.252Y-112.155
    N20340G1X87.114Y-112.676
    N20350G1X87.006Y-113.250
    N20360G1X86.929Y-113.874
    N20370G1X86.882Y-114.550
    N20380G1X86.867Y-115.277
    N20390G1Y-126.609
    N20400G1X84.468
    N20410G1Y-113.937
    N20420G1X84.459Y-113.403
    N20430G1X84.431Y-112.904
    N20440G1X84.385Y-112.439
    N20450G1X84.321Y-112.008
    N20460G1X84.239Y-111.612
    N20470G1X84.138Y-111.251
    N20480G1X84.019Y-110.924
    N20490G1X83.881Y-110.631
    N20500G1X83.723Y-110.373
    N20510G1X83.541Y-110.149
    N20520G1X83.337Y-109.959
    N20530G1X83.108Y-109.804
    N20540G1X82.857Y-109.684
    N20550G1X82.582Y-109.598
    N20560G1X82.284Y-109.546
    N20570G1X81.962Y-109.529
    N20580G1X81.711Y-109.540
    N20590G1X81.465Y-109.575
    N20600G1X81.224Y-109.632
    N20610G1X80.987Y-109.713
    N20620G1X80.756Y-109.816
    N20630G1X80.529Y-109.942
    N20640G1X80.307Y-110.091
    N20650G1X80.089Y-110.264
    N20660G1X79.882Y-110.458
    N20670G1X79.689Y-110.673
    N20680G1X79.511Y-110.910
    N20690G1X79.348Y-111.168
    N20700G1X79.199Y-111.447
    N20710G1X79.066Y-111.748
    N20720G1X78.947Y-112.069
    N20730G1X78.843Y-112.412
    N20740G1X78.752Y-112.785
    N20750G1X78.674Y-113.197
    N20760G1X78.607Y-113.649
    N20770G1X78.553Y-114.139
    N20780G1X78.481Y-115.236
    N20790G1X78.456Y-116.489
    N20800G1Y-126.609
    N20810G1X76.057
    N20820G00Z5.999
    N20830G00X104.234Y-74.599
    N20840G1Z-1.000F1200.0
    N20850G1X112.138F3600.0
    N20860G1X112.089Y-74.003
    N20870G1X112.022Y-73.445
    N20880G1X111.936Y-72.926
    N20890G1X111.832Y-72.445
    N20900G1X111.709Y-72.003
    N20910G1X111.569Y-71.599
    N20920G1X111.409Y-71.234
    N20930G1X111.232Y-70.907
    N20940G1X110.935Y-70.460
    N20950G1X110.616Y-70.072
    N20960G1X110.277Y-69.743
    N20970G1X110.099Y-69.602
    N20980G1X109.916Y-69.475
    N20990G1X109.727Y-69.363
    N21000G1X109.534Y-69.266
    N21010G1X109.335Y-69.184
    N21020G1X109.130Y-69.117
    N21030G1X108.921Y-69.064
    N21040G1X108.706Y-69.027
    N21050G1X108.485Y-69.005
    N21060G1X108.260Y-68.997
    N21070G1X107.855Y-69.021
    N21080G1X107.466Y-69.093
    N21090G1X107.094Y-69.212
    N21100G1X106.739Y-69.378
    N21110G1X106.399Y-69.593
    N21120G1X106.077Y-69.855
    N21130G1X105.770Y-70.164
    N21140G1X105.481Y-70.522
    N21150G1X105.215Y-70.919
    N21160G1X104.980Y-71.348
    N21170G1X104.777Y-71.809
    N21180G1X104.606Y-72.303
    N21190G1X104.466Y-72.829
    N21200G1X104.357Y-73.387
    N21210G1X104.280Y-73.977
    N21220G1X104.234Y-74.599
    N21230G00Z5.999
    N21240G00X101.737Y-74.314
    N21250G1Z-1.000F1200.0
    N21260G1X101.802Y-73.776F3600.0
    N21270G1X101.881Y-73.256
    N21280G1X101.974Y-72.752
    N21290G1X102.082Y-72.266
    N21300G1X102.204Y-71.797
    N21310G1X102.340Y-71.346
    N21320G1X102.491Y-70.911
    N21330G1X102.657Y-70.494
    N21340G1X102.836Y-70.094
    N21350G1X103.030Y-69.711
    N21360G1X103.239Y-69.346
    N21370G1X103.461Y-68.997
    N21380G1X103.695Y-68.668
    N21390G1X103.938Y-68.360
    N21400G1X104.189Y-68.074
    N21410G1X104.449Y-67.808
    N21420G1X104.718Y-67.564
    N21430G1X104.995Y-67.341
    N21440G1X105.280Y-67.139
    N21450G1X105.574Y-66.959
    N21460G1X105.876Y-66.800
    N21470G1X106.187Y-66.662
    N21480G1X106.507Y-66.545
    N21490G1X106.835Y-66.449
    N21500G1X107.172Y-66.375
    N21510G1X107.517Y-66.322
    N21520G1X107.871Y-66.290
    N21530G1X108.233Y-66.279
    N21540G1X108.584Y-66.290
    N21550G1X108.927Y-66.321
    N21560G1X109.261Y-66.373
    N21570G1X109.588Y-66.446
    N21580G1X109.906Y-66.539
    N21590G1X110.216Y-66.654
    N21600G1X110.518Y-66.789
    N21610G1X110.812Y-66.945
    N21620G1X111.098Y-67.122
    N21630G1X111.376Y-67.320
    N21640G1X111.645Y-67.538
    N21650G1X111.907Y-67.777
    N21660G1X112.160Y-68.037
    N21670G1X112.405Y-68.318
    N21680G1X112.642Y-68.620
    N21690G1X112.871Y-68.942
    N21700G1X113.089Y-69.284
    N21710G1X113.293Y-69.642
    N21720G1X113.483Y-70.017
    N21730G1X113.659Y-70.409
    N21740G1X113.820Y-70.818
    N21750G1X113.968Y-71.244
    N21760G1X114.101Y-71.687
    N21770G1X114.221Y-72.147
    N21780G1X114.326Y-72.624
    N21790G1X114.418Y-73.117
    N21800G1X114.495Y-73.628
    N21810G1X114.558Y-74.156
    N21820G1X114.608Y-74.700
    N21830G1X114.643Y-75.262
    N21840G1X114.671Y-76.435
    N21850G1X114.657Y-77.317
    N21860G1X104.101
    N21870G1X104.151Y-78.097
    N21880G1X104.234Y-78.830
    N21890G1X104.349Y-79.515
    N21900G1X104.498Y-80.154
    N21910G1X104.679Y-80.746
    N21920G1X104.893Y-81.290
    N21930G1X105.141Y-81.788
    N21940G1X105.421Y-82.239
    N21950G1X105.726Y-82.639
    N21960G1X106.050Y-82.986
    N21970G1X106.393Y-83.279
    N21980G1X106.754Y-83.520
    N21990G1X107.133Y-83.706
    N22000G1X107.530Y-83.840
    N22010G1X107.946Y-83.920
    N22020G1X108.380Y-83.947
    N22030G1X108.703Y-83.932
    N22040G1X109.015Y-83.887
    N22050G1X109.315Y-83.812
    N22060G1X109.603Y-83.708
    N22070G1X109.878Y-83.573
    N22080G1X110.142Y-83.409
    N22090G1X110.393Y-83.215
    N22100G1X110.632Y-82.992
    N22110G1X110.859Y-82.735
    N22120G1X111.075Y-82.443
    N22130G1X111.278Y-82.115
    N22140G1X111.469Y-81.752
    N22150G1X111.647Y-81.353
    N22160G1X111.814Y-80.919
    N22170G1X111.969Y-80.449
    N22180G1X112.112Y-79.943
    N22190G1X114.591Y-80.365
    N22200G1X114.429Y-81.093
    N22210G1X114.235Y-81.778
    N22220G1X114.010Y-82.422
    N22230G1X113.754Y-83.024
    N22240G1X113.467Y-83.584
    N22250G1X113.149Y-84.101
    N22260G1X112.799Y-84.578
    N22270G1X112.418Y-85.012
    N22280G1X112.008Y-85.399
    N22290G1X111.570Y-85.735
    N22300G1X111.105Y-86.019
    N22310G1X110.612Y-86.251
    N22320G1X110.092Y-86.432
    N22330G1X109.544Y-86.561
    N22340G1X108.969Y-86.639
    N22350G1X108.366Y-86.665
    N22360G1X107.983Y-86.654
    N22370G1X107.610Y-86.623
    N22380G1X107.247Y-86.572
    N22390G1X106.894Y-86.500
    N22400G1X106.551Y-86.407
    N22410G1X106.218Y-86.294
    N22420G1X105.895Y-86.160
    N22430G1X105.582Y-86.006
    N22440G1X105.279Y-85.831
    N22450G1X104.987Y-85.635
    N22460G1X104.704Y-85.419
    N22470G1X104.431Y-85.182
    N22480G1X104.169Y-84.925
    N22490G1X103.916Y-84.647
    N22500G1X103.674Y-84.348
    N22510G1X103.441Y-84.029
    N22520G1X103.221Y-83.691
    N22530G1X103.015Y-83.337
    N22540G1X102.823Y-82.966
    N22550G1X102.645Y-82.579
    N22560G1X102.482Y-82.175
    N22570G1X102.333Y-81.754
    N22580G1X102.198Y-81.317
    N22590G1X102.077Y-80.863
    N22600G1X101.970Y-80.393
    N22610G1X101.878Y-79.906
    N22620G1X101.800Y-79.403
    N22630G1X101.736Y-78.883
    N22640G1X101.686Y-78.346
    N22650G1X101.650Y-77.793
    N22660G1X101.622Y-76.637
    N22670G1X101.651Y-75.441
    N22680G1X101.687Y-74.869
    N22690G1X101.737Y-74.314
    N22700G00Z5.999
    N22710G00X125.201Y-66.720
    N22720G1Z-1.000F1200.0
    N22730G1X127.600F3600.0
    N22740G1Y-86.224
    N22750G1X125.201
    N22760G1Y-66.720
    N22770G00Z5.999
    N22780G00X131.125Y-69.484
    N22790G1Z-1.000F1200.0
    N22800G1X131.361Y-68.952F3600.0
    N22810G1X131.637Y-68.467
    N22820G1X131.951Y-68.029
    N22830G1X132.123Y-67.828
    N22840G1X132.305Y-67.638
    N22850G1X132.610Y-67.365
    N22860G1X132.966Y-67.113
    N22870G1X133.373Y-66.882
    N22880G1X133.831Y-66.674
    N22890G1X134.323Y-66.501
    N22900G1X134.832Y-66.378
    N22910G1X135.359Y-66.304
    N22920G1X135.904Y-66.279
    N22930G1X136.314Y-66.290
    N22940G1X136.711Y-66.321
    N22950G1X137.096Y-66.372
    N22960G1X137.468Y-66.445
    N22970G1X137.827Y-66.538
    N22980G1X138.174Y-66.651
    N22990G1X138.508Y-66.786
    N23000G1X138.829Y-66.940
    N23010G1X139.134Y-67.113
    N23020G1X139.418Y-67.300
    N23030G1X139.681Y-67.502
    N23040G1X139.924Y-67.719
    N23050G1X140.146Y-67.950
    N23060G1X140.347Y-68.196
    N23070G1X140.528Y-68.456
    N23080G1X140.689Y-68.731
    N23090G1X140.833Y-69.025
    N23100G1X140.965Y-69.343
    N23110G1X141.086Y-69.685
    N23120G1X141.195Y-70.051
    N23130G1X141.293Y-70.441
    N23140G1X141.378Y-70.854
    N23150G1X141.452Y-71.291
    N23160G1X141.515Y-71.752
    N23170G1X139.169Y-72.193
    N23180G1X139.120Y-71.827
    N23190G1X139.051Y-71.481
    N23200G1X138.964Y-71.156
    N23210G1X138.858Y-70.852
    N23220G1X138.732Y-70.569
    N23230G1X138.588Y-70.306
    N23240G1X138.425Y-70.064
    N23250G1X138.243Y-69.842
    N23260G1X138.041Y-69.644
    N23270G1X137.820Y-69.473
    N23280G1X137.579Y-69.327
    N23290G1X137.318Y-69.209
    N23300G1X137.037Y-69.116
    N23310G1X136.737Y-69.050
    N23320G1X136.417Y-69.011
    N23330G1X136.077Y-68.997
    N23340G1X135.678Y-69.009
    N23350G1X135.310Y-69.044
    N23360G1X134.970Y-69.103
    N23370G1X134.661Y-69.186
    N23380G1X134.381Y-69.291
    N23390G1X134.130Y-69.421
    N23400G1X133.909Y-69.574
    N23410G1X133.718Y-69.750
    N23420G1X133.552Y-69.943
    N23430G1X133.409Y-70.143
    N23440G1X133.287Y-70.351
    N23450G1X133.188Y-70.568
    N23460G1X133.111Y-70.792
    N23470G1X133.055Y-71.024
    N23480G1X133.022Y-71.265
    N23490G1X133.011Y-71.513
    N23500G1X133.030Y-71.827
    N23510G1X133.085Y-72.124
    N23520G1X133.176Y-72.405
    N23530G1X133.304Y-72.670
    N23540G1X133.472Y-72.925
    N23550G1X133.681Y-73.157
    N23560G1X133.932Y-73.366
    N23570G1X134.224Y-73.552
    N23580G1X134.934Y-73.855
    N23590G1X136.343Y-74.397
    N23600G1X137.520Y-74.844
    N23610G1X138.504Y-75.248
    N23620G1X139.296Y-75.610
    N23630G1X139.896Y-75.930
    N23640G1X140.140Y-76.088
    N23650G1X140.372Y-76.262
    N23660G1X140.589Y-76.454
    N23670G1X140.794Y-76.662
    N23680G1X140.984Y-76.888
    N23690G1X141.161Y-77.130
    N23700G1X141.325Y-77.389
    N23710G1X141.475Y-77.666
    N23720G1X141.609Y-77.959
    N23730G1X141.726Y-78.269
    N23740G1X141.824Y-78.597
    N23750G1X141.905Y-78.942
    N23760G1X141.968Y-79.304
    N23770G1X142.012Y-79.684
    N23780G1X142.039Y-80.080
    N23790G1X142.048Y-80.494
    N23800G1X142.037Y-80.904
    N23810G1X142.004Y-81.308
    N23820G1X141.950Y-81.706
    N23830G1X141.873Y-82.099
    N23840G1X141.775Y-82.485
    N23850G1X141.655Y-82.865
    N23860G1X141.512Y-83.239
    N23870G1X141.348Y-83.607
    N23880G1X141.164Y-83.961
    N23890G1X140.960Y-84.295
    N23900G1X140.736Y-84.609
    N23910G1X140.494Y-84.901
    N23920G1X140.232Y-85.174
    N23930G1X139.950Y-85.425
    N23940G1X139.649Y-85.656
    N23950G1X139.329Y-85.866
    N23960G1X138.994Y-86.053
    N23970G1X138.648Y-86.215
    N23980G1X138.291Y-86.352
    N23990G1X137.923Y-86.465
    N24000G1X137.544Y-86.552
    N24010G1X137.155Y-86.615
    N24020G1X136.755Y-86.652
    N24030G1X136.343Y-86.665
    N24040G1X135.674Y-86.640
    N24050G1X135.046Y-86.566
    N24060G1X134.459Y-86.442
    N24070G1X133.913Y-86.270
    N24080G1X133.655Y-86.165
    N24090G1X133.407Y-86.048
    N24100G1X133.170Y-85.918
    N24110G1X132.943Y-85.776
    N24120G1X132.727Y-85.622
    N24130G1X132.520Y-85.455
    N24140G1X132.324Y-85.276
    N24150G1X132.138Y-85.085
    N24160G1X131.793Y-84.666
    N24170G1X131.480Y-84.200
    N24180G1X131.201Y-83.686
    N24190G1X130.954Y-83.125
    N24200G1X130.739Y-82.515
    N24210G1X130.557Y-81.859
    N24220G1X130.408Y-81.154
    N24230G1X130.292Y-80.402
    N24240G1X132.665Y-79.888
    N24250G1X132.726Y-80.365
    N24260G1X132.809Y-80.813
    N24270G1X132.915Y-81.232
    N24280G1X133.043Y-81.623
    N24290G1X133.193Y-81.985
    N24300G1X133.366Y-82.319
    N24310G1X133.561Y-82.624
    N24320G1X133.778Y-82.900
    N24330G1X134.017Y-83.145
    N24340G1X134.280Y-83.358
    N24350G1X134.565Y-83.538
    N24360G1X134.872Y-83.685
    N24370G1X135.203Y-83.799
    N24380G1X135.556Y-83.881
    N24390G1X135.932Y-83.930
    N24400G1X136.330Y-83.947
    N24410G1X136.730Y-83.932
    N24420G1X137.103Y-83.889
    N24430G1X137.450Y-83.816
    N24440G1X137.770Y-83.715
    N24450G1X138.063Y-83.584
    N24460G1X138.329Y-83.425
    N24470G1X138.569Y-83.236
    N24480G1X138.783Y-83.019
    N24490G1X138.970Y-82.782
    N24500G1X139.132Y-82.535
    N24510G1X139.270Y-82.278
    N24520G1X139.382Y-82.011
    N24530G1X139.470Y-81.734
    N24540G1X139.532Y-81.447
    N24550G1X139.570Y-81.150
    N24560G1X139.582Y-80.843
    N24570G1X139.571Y-80.570
    N24580G1X139.538Y-80.313
    N24590G1X139.483Y-80.070
    N24600G1X139.406Y-79.842
    N24610G1X139.306Y-79.629
    N24620G1X139.185Y-79.431
    N24630G1X139.041Y-79.248
    N24640G1X138.876Y-79.080
    N24650G1X138.730Y-78.966
    N24660G1X138.538Y-78.844
    N24670G1X138.016Y-78.579
    N24680G1X137.311Y-78.284
    N24690G1X136.423Y-77.959
    N24700G1X135.205Y-77.516
    N24710G1X134.189Y-77.103
    N24720G1X133.376Y-76.722
    N24730G1X133.045Y-76.542
    N24740G1X132.765Y-76.371
    N24750G1X132.517Y-76.195
    N24760G1X132.286Y-76.004
    N24770G1X132.069Y-75.796
    N24780G1X131.868Y-75.572
    N24790G1X131.683Y-75.332
    N24800G1X131.513Y-75.076
    N24810G1X131.358Y-74.804
    N24820G1X131.218Y-74.516
    N24830G1X131.095Y-74.216
    N24840G1X130.988Y-73.908
    N24850G1X130.898Y-73.593
    N24860G1X130.824Y-73.270
    N24870G1X130.766Y-72.939
    N24880G1X130.725Y-72.600
    N24890G1X130.700Y-72.253
    N24900G1X130.692Y-71.899
    N24910G1X130.719Y-71.259
    N24920G1X130.800Y-70.643
    N24930G1X130.936Y-70.052
    N24940G1X131.125Y-69.484
    N24950G00Z5.999
    N24960G00X127.600Y-63.102
    N24970G1Z-1.000F1200.0
    N24980G1X125.201F3600.0
    N24990G1Y-59.301
    N25000G1X127.600
    N25010G1Y-63.102
    N25020G00Z5.999
    N25030G00X127.483Y-25.291
    N25040G1Z-1.000F1200.0
    N25050G1X125.084F3600.0
    N25060G1Y-11.135
    N25070G1X127.483
    N25080G1Y-25.291
    N25090G00Z5.999
    N25100G00X130.837Y-23.041
    N25110G1Z-1.000F1200.0
    N25120G1X130.622Y-22.599F3600.0
    N25130G1X130.441Y-22.123
    N25140G1X130.292Y-21.611
    N25150G1X130.175Y-21.065
    N25160G1X132.548Y-20.692
    N25170G1X132.609Y-21.038
    N25180G1X132.693Y-21.364
    N25190G1X132.798Y-21.668
    N25200G1X132.926Y-21.952
    N25210G1X133.076Y-22.215
    N25220G1X133.249Y-22.457
    N25230G1X133.444Y-22.678
    N25240G1X133.661Y-22.878
    N25250G1X133.901Y-23.056
    N25260G1X134.163Y-23.210
    N25270G1X134.448Y-23.341
    N25280G1X134.756Y-23.448
    N25290G1X135.086Y-23.531
    N25300G1X135.439Y-23.590
    N25310G1X135.815Y-23.626
    N25320G1X136.213Y-23.638
    N25330G1X136.613Y-23.627
    N25340G1X136.986Y-23.596
    N25350G1X137.333Y-23.543
    N25360G1X137.653Y-23.470
    N25370G1X137.946Y-23.375
    N25380G1X138.213Y-23.259
    N25390G1X138.453Y-23.122
    N25400G1X138.666Y-22.965
    N25410G1X138.853Y-22.793
    N25420G1X139.016Y-22.614
    N25430G1X139.153Y-22.427
    N25440G1X139.266Y-22.233
    N25450G1X139.353Y-22.032
    N25460G1X139.416Y-21.824
    N25470G1X139.453Y-21.608
    N25480G1X139.466Y-21.385
    N25490G1X139.455Y-21.187
    N25500G1X139.421Y-21.000
    N25510G1X139.366Y-20.824
    N25520G1X139.289Y-20.659
    N25530G1X139.190Y-20.504
    N25540G1X139.068Y-20.361
    N25550G1X138.925Y-20.228
    N25560G1X138.759Y-20.106
    N25570G1X138.613Y-20.023
    N25580G1X138.421Y-19.935
    N25590G1X137.899Y-19.742
    N25600G1X137.195Y-19.528
    N25610G1X136.307Y-19.293
    N25620G1X135.088Y-18.971
    N25630G1X134.072Y-18.671
    N25640G1X133.259Y-18.394
    N25650G1X132.648Y-18.140
    N25660G1X132.401Y-18.012
    N25670G1X132.169Y-17.873
    N25680G1X131.953Y-17.722
    N25690G1X131.752Y-17.560
    N25700G1X131.566Y-17.386
    N25710G1X131.396Y-17.200
    N25720G1X131.241Y-17.003
    N25730G1X131.102Y-16.793
    N25740G1X130.978Y-16.576
    N25750G1X130.871Y-16.352
    N25760G1X130.781Y-16.123
    N25770G1X130.707Y-15.889
    N25780G1X130.649Y-15.649
    N25790G1X130.608Y-15.403
    N25800G1X130.584Y-15.151
    N25810G1X130.575Y-14.894
    N25820G1X130.602Y-14.430
    N25830G1X130.684Y-13.983
    N25840G1X130.819Y-13.553
    N25850G1X131.008Y-13.141
    N25860G1X131.245Y-12.755
    N25870G1X131.520Y-12.403
    N25880G1X131.834Y-12.086
    N25890G1X132.188Y-11.802
    N25900G1X132.493Y-11.603
    N25910G1X132.850Y-11.420
    N25920G1X133.256Y-11.253
    N25930G1X133.714Y-11.102
    N25940G1X134.206Y-10.977
    N25950G1X134.716Y-10.887
    N25960G1X135.242Y-10.833
    N25970G1X135.787Y-10.816
    N25980G1X136.197Y-10.823
    N25990G1X136.594Y-10.846
    N26000G1X136.979Y-10.883
    N26010G1X137.351Y-10.935
    N26020G1X137.711Y-11.003
    N26030G1X138.057Y-11.085
    N26040G1X138.391Y-11.183
    N26050G1X138.713Y-11.295
    N26060G1X139.017Y-11.421
    N26070G1X139.301Y-11.557
    N26080G1X139.564Y-11.703
    N26090G1X139.807Y-11.860
    N26100G1X140.029Y-12.028
    N26110G1X140.231Y-12.206
    N26120G1X140.412Y-12.395
    N26130G1X140.572Y-12.595
    N26140G1X140.716Y-12.809
    N26150G1X140.848Y-13.039
    N26160G1X140.969Y-13.288
    N26170G1X141.078Y-13.553
    N26180G1X141.176Y-13.836
    N26190G1X141.262Y-14.136
    N26200G1X141.398Y-14.788
    N26210G1X139.052Y-15.107
    N26220G1X139.003Y-14.842
    N26230G1X138.935Y-14.591
    N26240G1X138.847Y-14.355
    N26250G1X138.741Y-14.134
    N26260G1X138.616Y-13.929
    N26270G1X138.471Y-13.738
    N26280G1X138.308Y-13.562
    N26290G1X138.126Y-13.401
    N26300G1X137.925Y-13.258
    N26310G1X137.703Y-13.133
    N26320G1X137.462Y-13.028
    N26330G1X137.201Y-12.941
    N26340G1X136.921Y-12.874
    N26350G1X136.620Y-12.827
    N26360G1X136.300Y-12.798
    N26370G1X135.960Y-12.788
    N26380G1X135.562Y-12.797
    N26390G1X135.193Y-12.822
    N26400G1X134.854Y-12.865
    N26410G1X134.544Y-12.925
    N26420G1X134.264Y-13.002
    N26430G1X134.013Y-13.096
    N26440G1X133.792Y-13.207
    N26450G1X133.601Y-13.335
    N26460G1X133.435Y-13.474
    N26470G1X133.292Y-13.620
    N26480G1X133.170Y-13.771
    N26490G1X133.071Y-13.928
    N26500G1X132.994Y-14.091
    N26510G1X132.939Y-14.259
    N26520G1X132.906Y-14.434
    N26530G1X132.895Y-14.614
    N26540G1X132.913Y-14.842
    N26550G1X132.968Y-15.057
    N26560G1X133.059Y-15.262
    N26570G1X133.188Y-15.454
    N26580G1X133.355Y-15.639
    N26590G1X133.564Y-15.807
    N26600G1X133.815Y-15.959
    N26610G1X134.107Y-16.094
    N26620G1X134.817Y-16.314
    N26630G1X136.227Y-16.707
    N26640G1X137.403Y-17.031
    N26650G1X138.388Y-17.325
    N26660G1X139.179Y-17.588
    N26670G1X139.779Y-17.820
    N26680G1X140.024Y-17.934
    N26690G1X140.255Y-18.061
    N26700G1X140.473Y-18.200
    N26710G1X140.677Y-18.351
    N26720G1X140.868Y-18.515
    N26730G1X141.045Y-18.691
    N26740G1X141.208Y-18.879
    N26750G1X141.358Y-19.079
    N26760G1X141.493Y-19.292
    N26770G1X141.609Y-19.518
    N26780G1X141.708Y-19.755
    N26790G1X141.788Y-20.006
    N26800G1X141.851Y-20.269
    N26810G1X141.896Y-20.544
    N26820G1X141.922Y-20.832
    N26830G1X141.931Y-21.132
    N26840G1X141.921Y-21.430
    N26850G1X141.888Y-21.723
    N26860G1X141.833Y-22.012
    N26870G1X141.757Y-22.297
    N26880G1X141.658Y-22.577
    N26890G1X141.538Y-22.853
    N26900G1X141.396Y-23.124
    N26910G1X141.232Y-23.391
    N26920G1X141.047Y-23.649
    N26930G1X140.843Y-23.891
    N26940G1X140.620Y-24.118
    N26950G1X140.377Y-24.331
    N26960G1X140.115Y-24.528
    N26970G1X139.833Y-24.711
    N26980G1X139.533Y-24.878
    N26990G1X139.212Y-25.031
    N27000G1X138.877Y-25.167
    N27010G1X138.531Y-25.284
    N27020G1X138.174Y-25.384
    N27030G1X137.806Y-25.466
    N27040G1X137.428Y-25.529
    N27050G1X137.038Y-25.574
    N27060G1X136.638Y-25.601
    N27070G1X136.227Y-25.610
    N27080G1X135.557Y-25.593
    N27090G1X134.929Y-25.539
    N27100G1X134.342Y-25.449
    N27110G1X133.796Y-25.324
    N27120G1X133.291Y-25.163
    N27130G1X132.827Y-24.966
    N27140G1X132.404Y-24.733
    N27150G1X132.021Y-24.464
    N27160G1X131.676Y-24.160
    N27170G1X131.364Y-23.822
    N27180G1X131.084Y-23.449
    N27190G1X130.837Y-23.041
    N27200G00Z5.999
    N27210G00X127.483Y-8.510
    N27220G1Z-1.000F1200.0
    N27230G1X125.084F3600.0
    N27240G1Y-5.751
    N27250G1X127.483
    N27260G1Y-8.510
    N27270G00Z5.999
    N27280G00X111.593Y-14.970
    N27290G1Z-1.000F1200.0
    N27300G1X111.452Y-14.677F3600.0
    N27310G1X111.293Y-14.412
    N27320G1X111.115Y-14.174
    N27330G1X110.818Y-13.850
    N27340G1X110.500Y-13.568
    N27350G1X110.160Y-13.330
    N27360G1X109.799Y-13.135
    N27370G1X109.417Y-12.983
    N27380G1X109.013Y-12.875
    N27390G1X108.589Y-12.810
    N27400G1X108.143Y-12.788
    N27410G1X107.738Y-12.805
    N27420G1X107.349Y-12.857
    N27430G1X106.977Y-12.944
    N27440G1X106.622Y-13.065
    N27450G1X106.283Y-13.220
    N27460G1X105.960Y-13.410
    N27470G1X105.654Y-13.635
    N27480G1X105.364Y-13.894
    N27490G1X105.098Y-14.183
    N27500G1X104.864Y-14.494
    N27510G1X104.661Y-14.829
    N27520G1X104.489Y-15.187
    N27530G1X104.349Y-15.569
    N27540G1X104.241Y-15.974
    N27550G1X104.163Y-16.402
    N27560G1X104.118Y-16.853
    N27570G1X112.022
    N27580G1X111.972Y-16.421
    N27590G1X111.905Y-16.016
    N27600G1X111.819Y-15.640
    N27610G1X111.715Y-15.291
    N27620G1X111.593Y-14.970
    N27630G00Z5.999
    N27640G00X113.542Y-13.813
    N27650G1Z-1.000F1200.0
    N27660G1X113.704Y-14.110F3600.0
    N27670G1X113.851Y-14.419
    N27680G1X113.985Y-14.740
    N27690G1X114.104Y-15.074
    N27700G1X114.210Y-15.420
    N27710G1X114.301Y-15.778
    N27720G1X114.378Y-16.149
    N27730G1X114.442Y-16.532
    N27740G1X114.491Y-16.927
    N27750G1X114.526Y-17.335
    N27760G1X114.554Y-18.186
    N27770G1X114.541Y-18.826
    N27780G1X103.984
    N27790G1X104.034Y-19.392
    N27800G1X104.117Y-19.924
    N27810G1X104.232Y-20.422
    N27820G1X104.381Y-20.885
    N27830G1X104.562Y-21.315
    N27840G1X104.777Y-21.710
    N27850G1X105.024Y-22.071
    N27860G1X105.304Y-22.398
    N27870G1X105.610Y-22.689
    N27880G1X105.934Y-22.941
    N27890G1X106.276Y-23.154
    N27900G1X106.637Y-23.328
    N27910G1X107.016Y-23.464
    N27920G1X107.413Y-23.560
    N27930G1X107.829Y-23.618
    N27940G1X108.263Y-23.638
    N27950G1X108.587Y-23.627
    N27960G1X108.899Y-23.595
    N27970G1X109.198Y-23.540
    N27980G1X109.486Y-23.465
    N27990G1X109.761Y-23.367
    N28000G1X110.025Y-23.248
    N28010G1X110.276Y-23.107
    N28020G1X110.515Y-22.945
    N28030G1X110.743Y-22.759
    N28040G1X110.958Y-22.547
    N28050G1X111.161Y-22.309
    N28060G1X111.352Y-22.045
    N28070G1X111.531Y-21.756
    N28080G1X111.698Y-21.440
    N28090G1X111.852Y-21.099
    N28100G1X111.995Y-20.732
    N28110G1X114.474Y-21.039
    N28120G1X114.312Y-21.567
    N28130G1X114.118Y-22.064
    N28140G1X113.894Y-22.531
    N28150G1X113.638Y-22.968
    N28160G1X113.351Y-23.374
    N28170G1X113.032Y-23.750
    N28180G1X112.682Y-24.096
    N28190G1X112.302Y-24.411
    N28200G1X111.891Y-24.692
    N28210G1X111.453Y-24.936
    N28220G1X110.988Y-25.142
    N28230G1X110.495Y-25.311
    N28240G1X109.975Y-25.442
    N28250G1X109.428Y-25.536
    N28260G1X108.852Y-25.592
    N28270G1X108.250Y-25.610
    N28280G1X107.866Y-25.603
    N28290G1X107.493Y-25.581
    N28300G1X107.130Y-25.543
    N28310G1X106.777Y-25.491
    N28320G1X106.434Y-25.424
    N28330G1X106.101Y-25.342
    N28340G1X105.778Y-25.244
    N28350G1X105.466Y-25.132
    N28360G1X105.163Y-25.005
    N28370G1X104.870Y-24.863
    N28380G1X104.587Y-24.706
    N28390G1X104.315Y-24.535
    N28400G1X104.052Y-24.348
    N28410G1X103.800Y-24.146
    N28420G1X103.557Y-23.929
    N28430G1X103.325Y-23.698
    N28440G1X103.104Y-23.453
    N28450G1X102.898Y-23.196
    N28460G1X102.706Y-22.926
    N28470G1X102.529Y-22.645
    N28480G1X102.365Y-22.352
    N28490G1X102.216Y-22.047
    N28500G1X102.081Y-21.730
    N28510G1X101.960Y-21.400
    N28520G1X101.853Y-21.059
    N28530G1X101.761Y-20.706
    N28540G1X101.683Y-20.340
    N28550G1X101.619Y-19.963
    N28560G1X101.569Y-19.573
    N28570G1X101.534Y-19.172
    N28580G1X101.505Y-18.333
    N28590G1X101.534Y-17.465
    N28600G1X101.570Y-17.050
    N28610G1X101.620Y-16.647
    N28620G1X101.685Y-16.257
    N28630G1X101.764Y-15.879
    N28640G1X101.857Y-15.514
    N28650G1X101.965Y-15.161
    N28660G1X102.087Y-14.820
    N28670G1X102.224Y-14.493
    N28680G1X102.375Y-14.177
    N28690G1X102.540Y-13.874
    N28700G1X102.719Y-13.584
    N28710G1X102.913Y-13.306
    N28720G1X103.122Y-13.041
    N28730G1X103.345Y-12.788
    N28740G1X103.579Y-12.549
    N28750G1X103.822Y-12.326
    N28760G1X104.073Y-12.118
    N28770G1X104.333Y-11.925
    N28780G1X104.601Y-11.748
    N28790G1X104.878Y-11.586
    N28800G1X105.163Y-11.440
    N28810G1X105.457Y-11.309
    N28820G1X105.760Y-11.193
    N28830G1X106.071Y-11.093
    N28840G1X106.390Y-11.008
    N28850G1X106.718Y-10.939
    N28860G1X107.055Y-10.885
    N28870G1X107.400Y-10.846
    N28880G1X107.754Y-10.823
    N28890G1X108.116Y-10.816
    N28900G1X108.467Y-10.823
    N28910G1X108.810Y-10.846
    N28920G1X109.144Y-10.883
    N28930G1X109.471Y-10.936
    N28940G1X109.789Y-11.004
    N28950G1X110.099Y-11.087
    N28960G1X110.401Y-11.185
    N28970G1X110.695Y-11.299
    N28980G1X110.981Y-11.427
    N28990G1X111.259Y-11.570
    N29000G1X111.529Y-11.729
    N29010G1X111.790Y-11.903
    N29020G1X112.043Y-12.091
    N29030G1X112.289Y-12.295
    N29040G1X112.526Y-12.514
    N29050G1X112.755Y-12.748
    N29060G1X112.973Y-12.996
    N29070G1X113.176Y-13.256
    N29080G1X113.366Y-13.528
    N29090G1X113.542Y-13.813
    N29100G00Z5.999
    N29110G00X98.728Y-14.987
    N29120G1Z-1.000F1200.0
    N29130G1X98.746Y-15.574F3600.0
    N29140G1Y-25.291
    N29150G1X96.360
    N29160G1Y-16.374
    N29170G1X96.346Y-15.704
    N29180G1X96.302Y-15.136
    N29190G1X96.229Y-14.668
    N29200G1X96.127Y-14.301
    N29210G1X95.987Y-14.000
    N29220G1X95.799Y-13.730
    N29230G1X95.564Y-13.490
    N29240G1X95.281Y-13.281
    N29250G1X94.961Y-13.112
    N29260G1X94.614Y-12.991
    N29270G1X94.241Y-12.919
    N29280G1X93.841Y-12.895
    N29290G1X93.476Y-12.910
    N29300G1X93.126Y-12.957
    N29310G1X92.793Y-13.034
    N29320G1X92.475Y-13.143
    N29330G1X92.173Y-13.283
    N29340G1X91.887Y-13.453
    N29350G1X91.617Y-13.655
    N29360G1X91.362Y-13.888
    N29370G1X91.131Y-14.155
    N29380G1X90.931Y-14.459
    N29390G1X90.761Y-14.800
    N29400G1X90.622Y-15.179
    N29410G1X90.514Y-15.595
    N29420G1X90.437Y-16.048
    N29430G1X90.391Y-16.539
    N29440G1X90.376Y-17.067
    N29450G1Y-25.291
    N29460G1X87.977
    N29470G1Y-16.094
    N29480G1X87.967Y-15.706
    N29490G1X87.940Y-15.344
    N29500G1X87.894Y-15.007
    N29510G1X87.830Y-14.694
    N29520G1X87.747Y-14.407
    N29530G1X87.647Y-14.144
    N29540G1X87.527Y-13.907
    N29550G1X87.390Y-13.695
    N29560G1X87.232Y-13.507
    N29570G1X87.050Y-13.345
    N29580G1X86.845Y-13.207
    N29590G1X86.617Y-13.095
    N29600G1X86.365Y-13.007
    N29610G1X86.090Y-12.945
    N29620G1X85.792Y-12.907
    N29630G1X85.471Y-12.895
    N29640G1X85.220Y-12.903
    N29650G1X84.974Y-12.928
    N29660G1X84.733Y-12.970
    N29670G1X84.496Y-13.028
    N29680G1X84.264Y-13.103
    N29690G1X84.037Y-13.195
    N29700G1X83.815Y-13.303
    N29710G1X83.598Y-13.428
    N29720G1X83.390Y-13.569
    N29730G1X83.198Y-13.725
    N29740G1X83.020Y-13.897
    N29750G1X82.857Y-14.084
    N29760G1X82.708Y-14.287
    N29770G1X82.575Y-14.505
    N29780G1X82.456Y-14.739
    N29790G1X82.352Y-14.987
    N29800G1X82.261Y-15.258
    N29810G1X82.183Y-15.557
    N29820G1X82.116Y-15.885
    N29830G1X82.062Y-16.240
    N29840G1X81.989Y-17.037
    N29850G1X81.965Y-17.946
    N29860G1Y-25.291
    N29870G1X79.566
    N29880G1Y-11.135
    N29890G1X81.712
    N29900G1Y-13.121
    N29910G1X81.885Y-12.868
    N29920G1X82.073Y-12.627
    N29930G1X82.274Y-12.399
    N29940G1X82.488Y-12.183
    N29950G1X82.717Y-11.981
    N29960G1X82.959Y-11.791
    N29970G1X83.215Y-11.613
    N29980G1X83.485Y-11.449
    N29990G1X83.766Y-11.300
    N30000G1X84.057Y-11.172
    N30010G1X84.358Y-11.063
    N30020G1X84.668Y-10.974
    N30030G1X84.987Y-10.905
    N30040G1X85.317Y-10.855
    N30050G1X85.655Y-10.825
    N30060G1X86.004Y-10.816
    N30070G1X86.388Y-10.826
    N30080G1X86.755Y-10.856
    N30090G1X87.104Y-10.907
    N30100G1X87.435Y-10.979
    N30110G1X87.749Y-11.071
    N30120G1X88.044Y-11.183
    N30130G1X88.323Y-11.316
    N30140G1X88.583Y-11.469
    N30150G1X88.825Y-11.640
    N30160G1X89.049Y-11.828
    N30170G1X89.254Y-12.032
    N30180G1X89.441Y-12.252
    N30190G1X89.609Y-12.488
    N30200G1X89.759Y-12.741
    N30210G1X89.890Y-13.010
    N30220G1X90.002Y-13.295
    N30230G1X90.216Y-12.994
    N30240G1X90.438Y-12.714
    N30250G1X90.668Y-12.452
    N30260G1X90.906Y-12.210
    N30270G1X91.151Y-11.987
    N30280G1X91.405Y-11.784
    N30290G1X91.666Y-11.600
    N30300G1X91.935Y-11.435
    N30310G1X92.212Y-11.290
    N30320G1X92.497Y-11.164
    N30330G1X92.790Y-11.058
    N30340G1X93.091Y-10.970
    N30350G1X93.400Y-10.903
    N30360G1X93.717Y-10.854
    N30370G1X94.042Y-10.825
    N30380G1X94.374Y-10.816
    N30390G1X94.886Y-10.834
    N30400G1X95.366Y-10.888
    N30410G1X95.817Y-10.980
    N30420G1X96.237Y-11.107
    N30430G1X96.627Y-11.271
    N30440G1X96.986Y-11.472
    N30450G1X97.315Y-11.708
    N30460G1X97.613Y-11.982
    N30470G1X97.879Y-12.293
    N30480G1X98.109Y-12.644
    N30490G1X98.304Y-13.034
    N30500G1X98.463Y-13.463
    N30510G1X98.587Y-13.932
    N30520G1X98.675Y-14.440
    N30530G1X98.728Y-14.987
    N30540G00Z5.999
    N30550G00X73.421Y-18.186
    N30560G1Z-1.000F1200.0
    N30570G1X73.075Y-18.317F3600.0
    N30580G1X72.687Y-18.443
    N30590G1X72.258Y-18.564
    N30600G1X71.789Y-18.680
    N30610G1X70.727Y-18.896
    N30620G1X69.503Y-19.093
    N30630G1X68.817Y-19.203
    N30640G1X68.240Y-19.319
    N30650G1X67.771Y-19.443
    N30660G1X67.410Y-19.573
    N30670G1X67.121Y-19.721
    N30680G1X66.867Y-19.901
    N30690G1X66.648Y-20.111
    N30700G1X66.464Y-20.352
    N30710G1X66.318Y-20.616
    N30720G1X66.214Y-20.894
    N30730G1X66.151Y-21.186
    N30740G1X66.131Y-21.492
    N30750G1X66.142Y-21.727
    N30760G1X66.176Y-21.952
    N30770G1X66.233Y-22.167
    N30780G1X66.312Y-22.372
    N30790G1X66.414Y-22.567
    N30800G1X66.539Y-22.751
    N30810G1X66.687Y-22.926
    N30820G1X66.857Y-23.091
    N30830G1X67.049Y-23.241
    N30840G1X67.262Y-23.371
    N30850G1X67.497Y-23.481
    N30860G1X67.752Y-23.571
    N30870G1X68.028Y-23.641
    N30880G1X68.325Y-23.691
    N30890G1X68.644Y-23.721
    N30900G1X68.983Y-23.731
    N30910G1X69.325Y-23.722
    N30920G1X69.657Y-23.693
    N30930G1X69.980Y-23.646
    N30940G1X70.293Y-23.580
    N30950G1X70.596Y-23.494
    N30960G1X70.890Y-23.390
    N30970G1X71.174Y-23.267
    N30980G1X71.449Y-23.125
    N30990G1X71.710Y-22.966
    N31000G1X71.953Y-22.794
    N31010G1X72.178Y-22.607
    N31020G1X72.385Y-22.407
    N31030G1X72.574Y-22.192
    N31040G1X72.746Y-21.964
    N31050G1X72.899Y-21.722
    N31060G1X73.035Y-21.465
    N31070G1X73.126Y-21.250
    N31080G1X73.204Y-21.010
    N31090G1X73.270Y-20.747
    N31100G1X73.325Y-20.459
    N31110G1X73.397Y-19.811
    N31120G1X73.421Y-19.066
    N31130G1Y-18.186
    N31140G00Z5.999
    N31150G00X73.054Y-16.425
    N31160G1Z-1.000F1200.0
    N31170G1X73.421Y-16.307F3600.0
    N31180G1X73.435Y-15.681
    N31190G1X73.424Y-15.328
    N31200G1X73.392Y-15.002
    N31210G1X73.339Y-14.703
    N31220G1X73.265Y-14.431
    N31230G1X73.169Y-14.186
    N31240G1X73.052Y-13.969
    N31250G1X72.914Y-13.778
    N31260G1X72.755Y-13.615
    N31270G1X72.511Y-13.424
    N31280G1X72.239Y-13.259
    N31290G1X71.940Y-13.119
    N31300G1X71.612Y-13.005
    N31310G1X71.257Y-12.916
    N31320G1X70.873Y-12.852
    N31330G1X70.462Y-12.814
    N31340G1X70.023Y-12.802
    N31350G1X69.613Y-12.811
    N31360G1X69.232Y-12.839
    N31370G1X68.878Y-12.885
    N31380G1X68.551Y-12.950
    N31390G1X68.253Y-13.033
    N31400G1X67.982Y-13.135
    N31410G1X67.739Y-13.256
    N31420G1X67.523Y-13.395
    N31430G1X67.328Y-13.557
    N31440G1X67.147Y-13.748
    N31450G1X66.978Y-13.968
    N31460G1X66.822Y-14.216
    N31470G1X66.680Y-14.493
    N31480G1X66.550Y-14.798
    N31490G1X66.434Y-15.132
    N31500G1X66.331Y-15.494
    N31510G1X63.985Y-15.174
    N31520G1X64.071Y-14.807
    N31530G1X64.170Y-14.457
    N31540G1X64.283Y-14.126
    N31550G1X64.408Y-13.813
    N31560G1X64.546Y-13.518
    N31570G1X64.697Y-13.241
    N31580G1X64.861Y-12.982
    N31590G1X65.038Y-12.742
    N31600G1X65.231Y-12.517
    N31610G1X65.445Y-12.305
    N31620G1X65.679Y-12.107
    N31630G1X65.934Y-11.922
    N31640G1X66.209Y-11.750
    N31650G1X66.505Y-11.592
    N31660G1X66.821Y-11.447
    N31670G1X67.157Y-11.315
    N31680G1X67.510Y-11.198
    N31690G1X67.878Y-11.097
    N31700G1X68.258Y-11.011
    N31710G1X68.653Y-10.940
    N31720G1X69.062Y-10.886
    N31730G1X69.484Y-10.847
    N31740G1X69.920Y-10.823
    N31750G1X70.369Y-10.816
    N31760G1X71.233Y-10.842
    N31770G1X71.633Y-10.876
    N31780G1X72.012Y-10.922
    N31790G1X72.370Y-10.982
    N31800G1X72.706Y-11.055
    N31810G1X73.021Y-11.142
    N31820G1X73.315Y-11.242
    N31830G1X73.844Y-11.469
    N31840G1X74.080Y-11.593
    N31850G1X74.298Y-11.724
    N31860G1X74.497Y-11.861
    N31870G1X74.677Y-12.006
    N31880G1X74.838Y-12.157
    N31890G1X74.981Y-12.315
    N31900G1X75.228Y-12.659
    N31910G1X75.434Y-13.046
    N31920G1X75.601Y-13.476
    N31930G1X75.727Y-13.948
    N31940G1X75.780Y-14.316
    N31950G1X75.817Y-14.808
    N31960G1X75.840Y-15.422
    N31970G1X75.847Y-16.160
    N31980G1Y-19.359
    N31990G1X75.857Y-20.878
    N32000G1X75.886Y-22.090
    N32010G1X75.934Y-22.994
    N32020G1X76.001Y-23.591
    N32030G1X76.096Y-24.030
    N32040G1X76.229Y-24.459
    N32050G1X76.399Y-24.879
    N32060G1X76.607Y-25.291
    N32070G1X74.101
    N32080G1X73.931Y-24.902
    N32090G1X73.795Y-24.481
    N32100G1X73.691Y-24.029
    N32110G1X73.621Y-23.545
    N32120G1X72.961Y-24.069
    N32130G1X72.636Y-24.301
    N32140G1X72.314Y-24.511
    N32150G1X71.994Y-24.700
    N32160G1X71.678Y-24.869
    N32170G1X71.365Y-25.017
    N32180G1X71.056Y-25.144
    N32190G1X70.745Y-25.253
    N32200G1X70.428Y-25.348
    N32210G1X70.106Y-25.428
    N32220G1X69.778Y-25.494
    N32230G1X69.444Y-25.545
    N32240G1X69.105Y-25.581
    N32250G1X68.410Y-25.610
    N32260G1X67.844Y-25.593
    N32270G1X67.311Y-25.539
    N32280G1X66.812Y-25.450
    N32290G1X66.347Y-25.326
    N32300G1X65.916Y-25.165
    N32310G1X65.518Y-24.969
    N32320G1X65.155Y-24.738
    N32330G1X64.824Y-24.471
    N32340G1X64.531Y-24.176
    N32350G1X64.276Y-23.862
    N32360G1X64.061Y-23.527
    N32370G1X63.885Y-23.173
    N32380G1X63.748Y-22.799
    N32390G1X63.650Y-22.405
    N32400G1X63.591Y-21.992
    N32410G1X63.572Y-21.559
    N32420G1X63.579Y-21.301
    N32430G1X63.601Y-21.050
    N32440G1X63.638Y-20.804
    N32450G1X63.690Y-20.564
    N32460G1X63.756Y-20.329
    N32470G1X63.838Y-20.100
    N32480G1X63.934Y-19.877
    N32490G1X64.045Y-19.659
    N32500G1X64.300Y-19.251
    N32510G1X64.591Y-18.884
    N32520G1X64.919Y-18.561
    N32530G1X65.284Y-18.280
    N32540G1X65.680Y-18.036
    N32550G1X66.099Y-17.823
    N32560G1X66.543Y-17.642
    N32570G1X67.010Y-17.493
    N32580G1X67.409Y-17.401
    N32590G1X67.897Y-17.310
    N32600G1X69.143Y-17.133
    N32610G1X70.500Y-16.952
    N32620G1X71.665Y-16.754
    N32630G1X72.639Y-16.539
    N32640G1X73.054Y-16.425
    N32650G00Z5.999
    N32660G00X60.706Y-16.587
    N32670G1Z-1.000F1200.0
    N32680G1Y-25.291F3600.0
    N32690G1X58.307
    N32700G1Y-16.680
    N32710G1X58.289Y-15.993
    N32720G1X58.237Y-15.399
    N32730G1X58.149Y-14.897
    N32740G1X58.027Y-14.488
    N32750G1X57.950Y-14.311
    N32760G1X57.860Y-14.143
    N32770G1X57.756Y-13.984
    N32780G1X57.639Y-13.835
    N32790G1X57.508Y-13.694
    N32800G1X57.363Y-13.563
    N32810G1X57.205Y-13.441
    N32820G1X57.034Y-13.328
    N32830G1X56.852Y-13.226
    N32840G1X56.662Y-13.138
    N32850G1X56.464Y-13.064
    N32860G1X56.259Y-13.003
    N32870G1X55.825Y-12.922
    N32880G1X55.361Y-12.895
    N32890G1X54.984Y-12.910
    N32900G1X54.621Y-12.956
    N32910G1X54.270Y-13.032
    N32920G1X53.933Y-13.138
    N32930G1X53.609Y-13.275
    N32940G1X53.298Y-13.442
    N32950G1X53.000Y-13.640
    N32960G1X52.715Y-13.868
    N32970G1X52.580Y-13.996
    N32980G1X52.454Y-14.138
    N32990G1X52.228Y-14.463
    N33000G1X52.037Y-14.843
    N33010G1X51.880Y-15.277
    N33020G1X51.759Y-15.766
    N33030G1X51.672Y-16.309
    N33040G1X51.620Y-16.907
    N33050G1X51.602Y-17.560
    N33060G1Y-25.291
    N33070G1X49.203
    N33080G1Y-11.135
    N33090G1X51.362
    N33100G1Y-13.148
    N33110G1X51.563Y-12.866
    N33120G1X51.774Y-12.601
    N33130G1X51.996Y-12.355
    N33140G1X52.229Y-12.128
    N33150G1X52.472Y-11.918
    N33160G1X52.727Y-11.727
    N33170G1X52.992Y-11.554
    N33180G1X53.268Y-11.399
    N33190G1X53.555Y-11.262
    N33200G1X53.853Y-11.144
    N33210G1X54.162Y-11.043
    N33220G1X54.481Y-10.961
    N33230G1X54.812Y-10.898
    N33240G1X55.153Y-10.852
    N33250G1X55.505Y-10.825
    N33260G1X55.867Y-10.816
    N33270G1X56.494Y-10.844
    N33280G1X56.798Y-10.880
    N33290G1X57.095Y-10.930
    N33300G1X57.386Y-10.995
    N33310G1X57.671Y-11.074
    N33320G1X57.949Y-11.168
    N33330G1X58.220Y-11.275
    N33340G1X58.480Y-11.395
    N33350G1X58.723Y-11.523
    N33360G1X58.949Y-11.661
    N33370G1X59.158Y-11.807
    N33380G1X59.350Y-11.962
    N33390G1X59.526Y-12.126
    N33400G1X59.684Y-12.300
    N33410G1X59.826Y-12.482
    N33420G1X60.073Y-12.872
    N33430G1X60.279Y-13.298
    N33440G1X60.446Y-13.759
    N33450G1X60.573Y-14.254
    N33460G1X60.631Y-14.650
    N33470G1X60.672Y-15.171
    N33480G1X60.697Y-15.816
    N33490G1X60.706Y-16.587
    N33500G00Z5.999
    N33510G00X12.602Y-46.323
    N33520G1Z-1.000F1200.0
    N33530G1Y-48.736F3600.0
    N33540G1X5.231
    N33550G1Y-46.323
    N33560G1X12.602
    N33570G00Z5.999
    N33580G00Z20.000
    N33590G00X0.000Y0.000
    N33600M09
    N33610M30
Name:	aspire feeds and speeds.JPG
ID:	15212   Click image for larger version.
ID:	15209   Click image for larger version.
ID:	15210   Click image for larger version.
Name:	screen grab detail.jpg
    Your simply trying to go too fast for such small text with CV mode. 3600mm/min is way too fast for this size txt.
    No way can a constant velocity be maintained at this feedrate on such small radius. You could try exact stop mode by typing G61 in the MDI before running code but it will shake the machine around.
    You can play with the CV settings and increasing look ahead to get better but you won't get it to maintain travel at these feedrates in CV mode without rounding it's just not possible.!!
    Unfortunately you will have to slow things down. I'd also increase accelleration in motor tuning as 100 is quite low.
    Often with moves that are short like engraving etc your better lowering velocity and increasing accelleration in motor tuning. Often this lowers cycle times on small move work.?
    Reason for this becomes obvious when you think about how each move or direction change works.?
    Every move as to accelerate to commanded feedrate, travel at this feedrate then de-accelerate all before the next direction change happens.
    Now on long moves it's no problem hitting the commanded feedrate even if high has we have plenty of time before the next move happens.
    On short moves the time interval between moves comes very quickly and no way can high commanded feedrate be reached before having to slow down for next move so some speed clipping occurs. On large jobs like 3D work this clipping can amount to large time increase in cycle times.
    Think of it like a race traffic light to traffic light between a F1 car tuned for speed and Bus tuned for stop to stop. When lights are streets apart then no problem F1 car wins every time but put the lights every kerb stone apart and Bus will smoke it.!!
    Same thing happening here.!! No matter what you command the feed to be in G-code the machine can only go so fast before having to slow down again.
    The feedrate reached will depend on the motor tuning but in general with higher acceleration the machine will produce shorter cycle times as it can reach a higher feed before slowing down again for next move or direction change.
    CV is like trying to go around corners without slowing down. This is impossible in tight corners so rounding occurs, how much depends on the CV setting. With high feedrates then even when CV settings are dialed in good for best balance rounding will occur if feeds are set too high.
    Edit: Oh and your G-code doesn't help matters by creating arcs with tiny lines. Try using a post processor that uses (i) (j) Arc moves instead of breaking each arc into tiny straight lines. Could also be a setting in the Cam software.?
  10. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  11. #10
    Dean. You took the words right out of my mouth I was just about to say all that. ..Clive
  1. the mystery of the wonky corners
    By kingcreaky in forum Machine Discussion
    Last Post: 06-05-2014, 03:58 PM
  2. pulley center distance vs. belt tension
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 13-01-2014, 10:48 PM
  3. RFQ: Mdf Cuts for CNC frame.
    By mZeles in forum Projects, Jobs & Requests
    Last Post: 12-03-2013, 04:41 PM
  4. Adding a 'Park Mode' to a cnc router?
    By routercnc in forum Computer Software
    Last Post: 18-06-2010, 06:10 PM
