    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 2 Days Ago Has been a member for 9-10 years. Has a total post count of 1,605. Received thanks 110 times, giving thanks to others 69 times.
    So I would like to get a larger mill that is designed mainly for cutting Aluminium. This means high speed spindle and fairly quick feed rates.
    Heavily inspired by this design (http://uk.dmgmori.com/blob/172034/d7...0-pdf-data.pdf), see pages 4 to 7, I came up with the following design. This is also very similar to the Ultimaker 3D printer design where you have a 'box' and you keep all the movement on top and place everything centrally over the table.
    The design is drawn using 1605 Leadscrews (C5 grade) and 400W Servo Motors (4, 5 or 6) - Cant decide if Z and Y need 2nd screws or not. Rails are Hiwin 20 (for Z) and 25 for X and Y.
    The spindle will be a 4KW Chinese Watercooled spindle.
    Cutting size based on the design is around X and Y - 600 mm x 600 mm x 250 mm.
    For the frame, I want to look at using something 'interesting' like Epoxy Granite or something similar. For any parts that are needed, these will be done out of either steel or aluminium.
    Thoughts / critique welcome. Thanks.
  1. Hybrid Stepper Servo
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 08-06-2015, 12:41 PM
  2. Interesting Mill Design on Hackaday
    By epninety in forum Milling Machines, Builds & Conversions
    Last Post: 01-03-2014, 05:10 PM
  3. Building a hybrid CNC mill. Need advice and recommendations
  4. Hybrid gantry
    By routercnc in forum Gantry/Router Machines & Building
    Last Post: 17-04-2012, 08:09 PM
  5. Small Mill very early design stage
    By leadinglights in forum Milling Machines, Builds & Conversions
    Last Post: 15-06-2010, 01:05 AM
