Thread: Eazicnc on denford easiturn
Does anybody know if it's possible/safe for me to replace the 36v 10amp power supply in my Eazicnc2X box. I've changed my motors on my Denford Easiturn for 4.2A Nema 34's from Arc Euro but i don't think i'm getting enough juice for them.
Many Thanks,
David
24-11-2011 #2
Why did you get them from Arc, they're the most expensive place for steppers? £45 for those steppers from Arc versus about £26 on eBay (depending how many you buy).
Anyway..
10 Amps should be enough for two (must be 2 as it's a lathe?) of those motors in Bipolar parallel or series. What makes you say they're not getting enough 'juice'? Not much torque, slow, not heating up?
36 Volts is a bit low for those motors, 50-75V is much better however if your drivers can't accept that high a voltage it may not be worthwhile replacing them.
24-11-2011 #3
Hi Jonathan,
Thanks for your prompt reply. My reason for getting them through Arc was that i had a credit to use up.
I think that they aren't getting enough juice as the motors appear to not have much torque. When i take several 0.5mm cut in 304 stainless steel using the G85 turning cycle, the x axis keeps losing position by 3 or 4 thou as though the motor is stalling and losing steps compared to the DRO. It's not much of a cut really. I have checked the crosslide and it has no tightness and the ballscrew/nut are as new so it's not a binding issue. The motors are wired in bipolar parallel.
Any advice you can offer would be very gratefully received.
Regards,
David
Denford Easiturn 3 spindle alignment
By Nemo1966 in forum Denford LathesReplies: 3Last Post: 13-05-2020, 10:28 AM -
eazicnc 3 'SAFETY' message
By makman in forum General DiscussionReplies: 5Last Post: 28-01-2019, 09:14 AM -
denford easiturn
By scotty in forum General ElectronicsReplies: 8Last Post: 27-06-2016, 09:24 PM -
FOR SALE: Denford cnc
By john legge in forum Items For SaleReplies: 4Last Post: 17-03-2013, 11:18 PM -
eazicnc v mach3
By coldrain in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 01-02-2011, 03:33 PM
