13-11-2017 #351
I wouldn't bother, unless the power on surge is a problem, as it's just something else to give potential problems.
My Hermes claimed they tried to deliver it today although I was there with the roller shutter door open so they are lying bastards, have to wait till Monday, would have been quicker to order from China lol.
Using the 50v transformer as a pattern (the 45v will be identical) so started to think about kitting out the box, anyone see any issues having the transformer under the stepper driver? I am going to fit 2 pc fans one sucking in and 1 extracting.
Going to use new capacitors as I have them and am going to need to fit everything a bit tighter.
You can just see the breakout board in the corner on a bit of ply will fit it roughly there and chop a hole with a cutting disc for the parallel port and USB to stick through.
Not sure I will fit the other BOB as I really don't need extra the input pins, good to have a spare though.
What's everyone set there AM882's microstepping up at?Last edited by Desertboy; 18-11-2017 at 06:47 PM.
Transformer came finally! didn't get round to soldering it but will have it up and running tomorrow ;)
Damn just realised I wired this up wrong lol but turned it on yet. The orange and black should be joined as well as the red &yellow.
Was tired this evening only just come home from work glad i decided to leave it till morning.Last edited by Desertboy; 20-11-2017 at 11:28 PM.
Almost there, got some connectors on a din rail for sorting out the wiring to the BOB, still need to solder the capacitors but will get that done tonight. Looking for my holesaw set at moment so I can make the fan holes in the enclosure.
The non working AM882 isn't bolted down just there for reference.
I have got a current inrush thermistor which hopefully is the right one if it cause problems I'll ditch it but it was £2 so I thought worth a punt. Hopefully with one fitted I can then use a type B mcb which I can just fit in the box ;)
I now feel it's starting to look like cnc electronics ;)Last edited by Desertboy; 22-11-2017 at 05:41 PM.
Got the capacitors soldered on a 2nd time, ready to test output voltage, need to get my mate tonight and borrow his hole saw so I can fit the fans and he's helping mount the box and the wires can be connected ;)
Now I need the new AM882 was quoted 10 working days delivery tomorrow is the 10th day :(
Ordered
one of these
http://www.ebay.co.uk/itm/230689466731
So I can fit it inside the box and take the mains in from the same feed as the transformer. Then I can wire first to a junction then on to the pc fans and BOB. This way if the toroidal transformer is one then the fans are running and less leads coming into the box.
I hope 1amp is enough, PC fan's are ~0.2amp I guess it doesn't need much to generate the control signal for the vfd.Last edited by Desertboy; 23-11-2017 at 09:24 PM.
Can I wire the stall detection output from 1 AM882 to the next then the last AM882 in the chain to the BOB?
23-11-2017 #358
Short answer - no!
Longer answer - the AM882 use an open-collector output. Think of it as being a normally-open switch that closes when there is a fault (like a stall). What you can do is wire them all in parallel and then to the BOB input. I do this with the EM806 on my machine and it works fine.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
