    Which bit?
    Quote Originally Posted by 2e0poz View Post
    Which bit?
    Your right, I am being very delusional!!
    The more I know, I know, I know the less. (John Owen)
    lol......:lmao:
    Is it just me or does anyone else think Lees hot ?
    Ralph Waldo Emerson
  5. #15
    Quote Originally Posted by Fivetide View Post
    What you smoking.!!!!!!
  6. #16
    Actually I'm vaping now , quit smoking the 40 a day death tabs 3 years ago at Christmas .. same time I quit drinking :) now I'm just an old boring bastard lol
    Ralph Waldo Emerson
  7. #17
    Glad you joined the club
  8. True, chip load is very important.
    Chip load refers to the size of the chips produced during cutting. The main purpose is to get the maximum chip load possible, so you can increase productivity, reduce heats bits during work, and also prevent premature dulling. The chip load is to small means bits will become too hot and dull quicker; chip load is too high means cutters will cause a bad surface finish, and in worse situation, the bits break.
  9. #19
    Mr Lee: I am cutting composit door but every 2 or 3 door machine start chipping from top and bottom and some how tool broken advise me what type of bit do I use to get extremely fine cutting and bit last for a month at least as well
  10. #20
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Quote Originally Posted by James Anwar View Post
    I would try a compression bit/cutter, their flute's have upcut and downcut spirals all on one cutter, so down shear cutting on the top of your material and an up shear cut on the bottom of the material.
    You can also get spiral up only and spiral down only, the choice of cutters is great now days, so always select the best cutter for the job/operation.
    Of course you need to be using the right speeds and feeds or it won't matter what cutter you use.
    .Me
  1. Feed and speed equation
    By Bush Flyer in forum Spindles & Drive Motors
    Last Post: 18-03-2014, 01:32 AM
  2. stepper acceleration rate - limits?
    By dsc in forum Stepper & Servo Motors
    Last Post: 02-03-2014, 02:25 PM
  3. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
  4. Vc & feed/rpm of the these tools on steel
    By hoezap in forum Tool & Tooling Technology
    Last Post: 14-02-2013, 08:50 AM
  5. Router bit recommendation, spindle speed and feed rate?
    By FlightCaseCo in forum Spindles & Drive Motors
    Last Post: 03-04-2012, 12:53 PM
