Home: Linear & Rotary Motion
General discussion for lead screws, rack and pinion, synchronous drive components, belt and pulley drive mechanisms.
Page 1 of 6 123 ... LastLast
Threads 1 to 20 of 114
Sub-Forums Threads / Posts  Last Post
  1. Discussion for belt driven machines, systems, drive components and timing.
    Forum Actions:
    Forum Statistics:
    • Threads: 41
  2. General discussion for all types of linear rail/guideway, linear actuators and their bearing blocks.
    Forum Actions:
    Forum Statistics:
    • Threads: 80
  3. General discussion for rack and pinion linear systems.
    Forum Actions:
    Forum Statistics:
    • Threads: 12
  4. General discussion for Lead Screws and Drive Nuts.
    Forum Actions:
    Forum Statistics:
    • Threads: 107
  1. Thumbs up Sticky Thread Sticky: Axis Directions
    Started by ptjw7uk, 06-09-2009
    18-02-2022 Go to last post
  1. Chinese Sliding Axis
    Started by dudz, 2 Weeks Ago
    2 Weeks Ago Go to last post
  2. Hiwin rails / blocks
    Started by BriceO, 11-06-2018
    2 Pages
    1 2
    13-06-2023 Go to last post
  3. 4th axis as a "poor man's lathe"
    Started by A_Camera, 17-05-2021
    4 Pages
    1 2 3 ... 4
    28-05-2023 Go to last post
  4. What would you choose
    Started by northwest, 05-03-2023
    07-03-2023 Go to last post
  5. cnc machine stiffness calculator
    Started by routercnc, 23-08-2010
    2 Pages
    1 2
    02-09-2022 Go to last post
    27-03-2022 Go to last post
    23-02-2022 Go to last post
    27-07-2021 Go to last post
  6. Hiwin Lubrication
    Started by Cube3, 10-06-2021
    10-06-2021 Go to last post
  7. Build in Progress
    Started by erniehatt, 08-06-2021
    08-06-2021 Go to last post
  8. Build in Progress
  9. Question about couplings...
    Started by JW1977, 22-04-2021
    07-06-2021 Go to last post
    03-06-2021 Go to last post
    02-06-2021 Go to last post
  10. Micro steps
    Started by erniehatt, 31-05-2021
    2 Pages
    1 2
  11. will it work or not
    Started by erniehatt, 20-05-2021
    31-05-2021 Go to last post
  12. Driver help
    Started by johngoodrich, 03-03-2021
    3 Pages
    1 2 3
    07-03-2021 Go to last post
  13. Poll Poll: Belt drive vs direct coupling pro's and cons, Poll
    Started by Desertboy, 28-08-2017
    2 Pages
    1 2
    28-02-2021 Go to last post
  14. Question Trying to identify component
    Started by Busa Grip, 18-01-2021
    19-01-2021 Go to last post
  15. 90:1 vs 180:1 gear ratio
    Started by mbridge87, 06-01-2021
    gearboxes, gears
    06-01-2021 Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
