I am using the linear command but it runs in the x direction on the part and i want it to run down the y direction.
Hope im making my self clear.
Hi Kell,
I think you need to go into the Linear Sketch Pattern Property Manager, once you setup and define "Direction 1/X-Axis" it should enable "Direction 2" and this will be your Y-Axis, to specify the Y direction for the Y-Axis, you first need to add additional "instances" for Direction 2.
Let us know if that works for you :)
Forgot to say I am using solidcam,
Don't seem to be able to see a sketch pattern any where
I see. Now sorted cheers
