First time buying CNC. Advise needed!
Hi all,
I am in need of some help.
I am looking to buy CNC machine.
I am doing small crafts. Currently using laser engraver. Engraving small wood pieces of about 5cm on 5 cm maximum.
Currently looking to make engravements on metal wrist watches. Was looking at laser engravers, but they look costly currently.
So I am in need to engrave some texts or simple logos on the back of metal wristwatch. My budget is about £1200.
What would be the best solution?
Many thanks
Re: First time buying CNC. Advise needed!
Just to add, any other solution which sorts out my needs is suitable. I have recommended fibre laser, however at this moment of time it is a bit too costly and does not fit into my budget
carol
Hi all,
Many thanks
I think you are going to find it hard to source a suitable machine for that budget.
To do such fine work with a router & engraving bit requires precision beyond machines in that budget.
(Unless you are prepared to make your own machine, even then you will struggle)
Perhaps you could look for a second hand one of these?
http://hpclaser.co.uk/index.php?main...roducts_id=123
