eccentric aluminium spacer
Hello folks,
I'm selling on ebay a few 1/3" eccentric aluminium spacers.
They are ideal for cnc machines or 3d printers as well.
Price is only £1.18 per each.
For more information please visit the link below or cantact with me via pm.
Thank you.
http://www.ebay.co.uk/itm/Eccentric-...UAAOSwLsBZOu57
Re: eccentric aluminium spacer
Hi thanks for sharing but what would they be used for? On a cnc machine i mean?
Lee Roberts
Hello Lee Roberts,
Thank you for your question.
This is a spacer that has an off center (Eccentric) 5mm hole drilled through it. It is used to tension V wheels against MakerSlide material.
You mount this in a 7.14mm (0.281 dia.) hole. When you rotate it, it will move a V wheel mounted to it, allowing you to adjust the tension against the Makerslide rail, V slot or T slot aluminium extrusions.
Hope you find this short answer helpful.
Let me know if I can give you more information.
