wanted few bits - long list
65mm 1.5kw water cooled 4 bearing spindle with 4 connection pins , or with earth
one vfd
one 3foot or 900 ish mm wide bosch Rexroth 20-145mm linear gantry
one 20 145 Rexroth linear doofer that gives me 50mm
one plate to bolt the z to the y
one pair of Rexroth rails and 4 bearings about 1200 - wide ones
one 16 or 20 - 5mm pitched screw nut and bearings
motor mounts Rexroth 145 to Panasonic minas / Rexroth ' yaskawa motors
65mm spindle mount to mount to the z
90 by 90 legged bosch Rexroth 45/90 table about 900mm high
will buy back all that I had and sold a few years ago if you havn't used it........
thanks
oh and someone to mill me some gantry ends to take a Rexroth 20-145, I want them to look realy cool though
i.e. they aren't going to be super tall - I want to build a sheet cutting cnc - or a plotter if you will, need not have to cut more than an inch - so want the ends milled from 40mm stock, and real pleasing to the eye - recessed, really worked
