Long-time lurker, ready to take the plunge
Good evening one and all. Thank you for allowing me into such an informative forum.
I've been considering a CNC router for some years, and now I'm finally in the position to embark... I was going to buy a kit, but after reading nearly every discussion on this forum, I guess I might have to build one instead.
I have a design background, and some experience using CNC machines while working in schools, as well as some knowledge of Mach 3 etc, so I feel reasonably confident that I can make things work at the computer end. The Hardware is more worrying though. I know what I need the machine to do, and I have some friends who can help with any welding, electrics or precision engineering, but I would like advice from experienced CNC builders as to a plan/design and parts list, and an expected budget. I mainly make wooden jewellery but have some plans for larger items.
NEEDS
- bed size of approx 300mm x 400mm (I can be a little flexible on this)
- z axis travel of 60mm ish.
- ability to carve fine detail (in mainly hardwoods) and occasionally cut out shapes from plywood (up to 12mm)
If anyone can offer any advice or links to self-builds that they feel would fit the bill will be gratefully received. I have perused some of the build logs, but its easy to end up off-topic when following the conversations.
Oh, and I'm based in Stockport!
Re: Long-time lurker, ready to take the plunge
Hi Greg and welcome to the forum I am based about 3 miles from you and am happy if you want to pop over and have a look at my machine.
Hi Clive.
Thank you for your quick reply and such a generous offer! I'd like that very much.
Can I ask what kind of machine you are running, and what kind of things you manufacture with it?
All the best
My router is about 1600x1000 I don't manufacture anything I do it just as a hobby but I have made a few smaller machines about 900x600 . I have a Myford S7 and a Warco mill that I have converted to cnc. I am based in Marple
Fantastic. I'd absolutely love to see your set up, and I don't think I've even seen a DIY CNC build in the flesh before. And I'm always grateful getting advice and knowledge from someone who has experience.
I have a few customers in Marple for my other side line business - gardening, so we certainly are close to one another
Thanks again Clive
