Meshcam to Powermill workflow
I was thinking of using Meshcam to organise my obj. files then input to powder mill so the operation at university can check before he sends to CNC machine. Reason is I am not allowed to operate the machine, the software at uni is power-mill and the operator doesn't like to work with obj. /stl.  If you get my drift?
If Meshcam cant be imported to power-mill do you know others that can do as well as liking obj.
Regards,
Zymon
		Re: Meshcam to Powermill workflow
		MeshCAM will not change the format of your .obj or .stl files, and won't give you anything to import into Powermill.
Ger21
 Can't I load the G code from MeshCam into PowerMill?
Zymon
		I don't know, never used Powermill.
