simple question from beginner
Hello to the users and I do apologise if I did not post my question in right place.
As I know nothing about cnc routers I have a couple of questions and hope somebody can advice me.
I need to use cnc router to cut plywood (thickness roughly 12-18 mm) - different irregular shapes (catted through) as an elements for furniture. I found 2 I consider to buy and it would be great if somebody could share opinion about those 2 products:
- https://www.ebay.co.uk/itm/cnc-3-axi...Condition=1000
or:
- https://ooznest.co.uk/product/ox-cnc-full-kit/
And a couple of very silly questions from beginner:
- how my work piece would be secured to the bed? would I need to clamp it somehow?
- suppliers in theory of they specification says e.g. 15 mm thickness - very seldom its true - it can be slightly more or usually less - how machine would cope with this? - does it measure actual thickness of the material to avoid over cut / damage to the bed or avoid not full depth cut?
- assuming workpiece is somehow clamped to the machine and when it makes final cut along designed shape (as far as I know it would cut in a few goes) to get through at this stage catted of piece is no longer attached to the whole piece - will it stay safe on the bed ?( without risk of fly away?)
Thanks for your help,*
Shem
Re: simple question from beginner
Shem, from your posting I think its fair to say that you'll have a few iterations of questions ad answers to get to where you need to be, no offence intended!, and on that basis I'll offer a quick and uninformed first reply...
First, decide on your realistic cutting area, and in particular if you need to handle standard sized sheets - then look at machines that support that most basic requirement. Neither machine would satisfy this. Of the two, the Ox is a weaker build - the use of v-groove extrusion/bearings for the axis motion and relatively light-weight extrusion would jeopardise the rigidity - and therefore the accuracy of the machine, which is something that you need to decide how important that is for your use-case. The ebay machine - stronger build based around supported rails (not the best option, but better than the v-groove) and welded steel construction should add rigidity, and the ball-screw (vs Ox belt system adds accuracy) though the all-up weight is surprisingly (and worryingly) light - the frame might. still be a bit flimsy for heavy cutting. The Z axis/150mm travel onto rails may introduced twist under cutting load (you can counter this by raising the workpiece to limit the Z extension).
Hopefully someone will be along shortly with recommendations for woodworking machines.
Silly answers:
- Yes you need to clamp - or otherwise secure the workpiece. Conventional clamps - though you identify the weakness with these later. Screwed/bolted to a sacrificial bed spoil board (a sheet of MDF under the work piece - T nuts are your friends here!). Or, double sided tape - can work well, depending on cutting forces - but can also be a bugger to separate.
- You'd 'zero' the Z axis to the top of the workpiece. As part of your CAM workflow you'd program the workpiece depth (or allow a cut into the spoil board).
- as above - use a retaining system to avoid this, or - as part of your CAM allow holding tabs - small sections that are not removed - hold the finished piece to the original material, and you cut these out after the main CNC operation is complete. Either way, don't assume that the final product won't just get tangled with the cutter and ruin the job - Sods Law says it will.
Another way of clamping stuff that it might be worth considering is a vacuum bed. Yes, you can spend a LOT of money on these pre-made, but equally a DIY one consisting of a grid of grooves in a piece of something impermeable would be easy to put together once you've got your machine up and running, for some ideas see here: https://www.cnccookbook.com/router-v...table-cnc-diy/. For better suction on small parts that will be isolated during cutting you can use bits of foam rubber strip stuffed into the grooves to direct the vacuum where it's needed and avoiding leaks. You will obviously need to shell out for a pump though.
