		CNC Router BIG single phase quick change tool
		Hi ok I’m moving house so need to sell this machine soon. I have another machine as well so this has to go.
I bought it 2 or 3 years ago in original forma and converted it to Mach 3. Here are the specs:
HSD Spindle 24k rpm ISO 30 quick change 8kw 2 pole
VFD for spindle 7.5kw running on single phase.
CSMIO IP controller 6 axis
3x 1.8kw servo motors
X travel 2.9M Y travel 760mm Z travel 100mm
I have done loads of work on this machine and it is fantastic for quick roughing them fine finishing.
Rapid feed on X is 50m/min Y 25m/min Z 25m/min
There is fantastic potential with this machine I got it to where I could cut and make money. It could be taken much further with all the extra drill heads actuate and the saw head. I will include all the tooling 15 tool holders in total all ER32 as well as a load of new and used cutters. I transported it on a twin axle trailer all the way from Manchester to surrey and it was fine. Without the original control box it is much lighter.
As you can see it will fit in single garage and achieve full travel. I can offer training on the machine when collected. Would prefer not to break but If I cant sell as a whole then I will.
https://youtu.be/ruCBfP9sJng
		Re: CNC Router BIG single phase quick change tool
		Also I have 10 tool forks that could be used to easily integrate auto tool change
		how much are you looking for?
		i would like 2800
The drives are 1200-1700
The controller is 600-700
Spindle sell quite often for 1000+ used and I will include the VFD
Seems a fair price to me much less and i would be better breaking. I will also include dust extractor and all the tooling.
petesurrey
			i would like 2800
 Sent you a PM
		Hi is this still available?
