Hello from someone who has never used a lathe before
		i have always wanted to learn how to use a lathe. I studied electronic engineering but through life's many turns have found myself working as a technical writer in central Italy for a manufacturing company. I have been very impressed by Italian engineering and I wish they had the same high levels when it comes to service. I have recently learnt to weld but seeing the engineers in the shop has spurred me on to get a lathe
Through research I have found this site and a member has helped me narrow down my choice. I look forward to learning from all of you in the very near future
		Re: Hello from someone who has never used a lathe before
		Rule number one with a lathe. Keep the chuck key out of the chuck when not in use! Rule number two is don't wear long sleeves or articles that can be wrapped around the work! Following those you should have no problem learning, welcome!
RobC
 As an apprentice and a 12 week machinist  appreciation stint (I was a spark) for an engineering firm - remove all rings. And check the chuck is secure.
Of course, advice is one thing...
		Hi Steven,
The other bit of advice is to rotate the chuck at least 1 rotation by hand before starting.  99.9% of the time it will be fine, but it is always possible that the chuck jaws can hit the cross slide, especially when holding larger parts (they protrude further from the chuck).
The WM250V model I have also has a powered cross slide.  After using the lathe for many years I think it is not a vital feature, and face machining by hand is usually fine.
If you want to see mine in action have a look on my channel here as an example (skip past the rambling if you like to 10:27).
https://www.youtube.com/watch?v=RRcvbDO1FgE
And here in the CNC build at 08:30
https://www.youtube.com/watch?v=tijVFCKuLPc
