Help please on DM542T Stepper Drivers
		Please can someone assist on how to properly set my switches on the drivers correctly or to explain how I figure them out.
I am looking at the currant table and Pulse/Rev table and this is just not sinking in with me, I have (AnChuan motor 57HD5401-14S 1.8  3.0A N1709)
I think I have to select the slightly lower Amp setting on the currant table so 2.84A for the 3A motor but I want to check this is right?
the Pulse/rev table I just cant figure out in my head what to set it as?
I have my DM542T drivers wired up to a 48v psu.
Many Thanks in advance
		Re: Help please on DM542T Stepper Drivers
Palletlad
 Looks sensible to me.
Palletlad
 This is just setting the microstepping factor - it doesn't really matter which you select, they'll all fundamentally work, but the higher the setting the smoother your motors will be, and they'll be able to position more accurately - but this comes at the cost of reduced torque. Usually 1/8th is a good starting point (1600 pulse/rev).
		Many thanks for explaining this is the one part that is not explained well via the internet and just confused me.
I did read a post that I set switch 4 off to set to half currant so when idle it does not heat up as much. Is this right?
Palletlad
 Yes that is correct
		Thank you both for the help, will trial out the settings tonight
