6&8mm Downcut 2 flute carbide end mills
		Hi - Anyone found a good Chinese source for 6&8mm Downcut 2 flute carbide end mills for wood routing.  Alibaba and Bangood do not seme to recognise the term "downcut".  Or should I be using another search term?  Most grateful for your experienced  advice.
		Re: 6&8mm Downcut 2 flute carbide end mills
		May have found a possible source on Alibaba, Waiting for quotes with shipping cost. Will report back.
			Compression bit
 I thought that type was up cut at the end and down cut at the top? So only useful if cutting the wood in one pass.
		My existing one`s are constant flue angle.
		Downcut bits are very useful. Can be harder to find.
Saite_cutter store on AliExpress sells some downcut bits. Also known as left hand bits.
Store Information
https://s.click.aliexpress.com/e/mW45b6SG
AU $28.64  9%OFF | 2Pcs 6x25mm Down Cutter Left hand Spiral Bit CNC Router Tool AAA Series One Flute acrylic Aluminum carving frezer endmill
https://s.click.aliexpress.com/e/tuaU3ggC
		Thanks pippin88. - Just ordered from Saite_cutter store on AliExpress.  Just what I was looking for. Appreciate the heads up.
