MACH 3 Soft Limit effecting A Axis Rotary
		I have an issue where the Soft Limit setting in MACH3 is effecting the A Axis Rotary.
To get around this I set the limits to the most maximum settings it would accept but is there any way I can disable the soft limit only the A Axis? I could switch off soft limits once I have started the G-Code program I guess but would rather not.
I have no pysical limit switches currently.
		Re: MACH 3 Soft Limit effecting A Axis Rotary
		Go to General config and disable Rotational softlimits
