Advice on setting cutter depth on a omicron 3000
		Hi , i have just started using a rye twin head cnc router , I’ve not much experience with it and was after advice on setting the depth of the cutter.  The control panel on the machine is a omicron 3000.
1. First of all I went into the ‘toolbox ‘on the panel ,
2. M/attr
3 .lenth dia
4.head select.
5 this will lower the head (3)
6 back to lenth dia
7 this now will show ‘ tool 3 L/ offst
8 I now use the left hand buttons to lower the head to required height , then press F1 to set the height.
It will set now to the Z depth .
9 I now press esc and the Z depth has went back to 1500,
So I can’t seem to change the depth from the control panel . I’m sure I’m just missing something out . Any advice on how to do this .
		Re: Advice on setting cutter depth on a omicron 3000
		Hi Sean,
I've also got a rye twin head CNC just started to try and get it running....
Maybe put your post in the Rye category?
Sent from my Mi A1 using Tapatalk
		What software/setup are you using?
		Thanks, having a look now
		Hi Sean,
Can you tell me which software you are using?
And is your pc connected to the controller via an rs232 serial lead.
Thanks Derek
		Did you get this sorted?
what was the fix?
thanks
