CNC routing on a long board
Hello,
I want to rout a few sentences on the face of a 220mm wide, 2400mm board. Just a small section of text roughly 180 x 180mm will do. Can anyone recommend a good CNC router for daily use to do this. Happy to consider laser too if quicker. It needs to be quick and easy to setup and the wording may need changing for each board. any help much appreciated. I wondered if the 3018 pro would work if the board could be supported on rollers at either end so that the text could be in the middle of the board?
Thanks!
Joni
