Audrino using cnc sheild and 8825 driver
		Hello all
Am using an audrino atmega 328 and cnc sheild with 8825 driver for a project.
Amusing it for the first time.
Facing a problem while using the same, stepper motor nema 17 with this circuit. The motor is shivering and and the 8825 drivers are reaching a high temperature in just sometime.Even the fuse on the cnc sheild had blown.
Can someone guide what could be the problem.
Have adjusted the potentiometer as per reference from you tube channel and some site of electronics kit development.
Thanks in advance.
Mustafa
		Re: Audrino using cnc sheild and 8825 driver
Musi
			Hello all
 Hello, Mustafa.
Musi
 You might be able to get a bit more assistance on some of the Arduino forums, as this feels to be very much focussed on Arduino based technology. But, whilst were here...
When/how did you blow the fuse?, before or after you adjusted the pot?, and have you replaced the fuse with the correctly sized replacement fuse?, or just bypassed with a bit of wire?
If replaced with a similar fuse - did you blow the second as well?
Musi
 The fuse blowing is a real indicator here. I'm not familiar with the 8825 driver, though it looks a bit on the light side; what's the specification of the motor? (current/coil). That you've blown the fuse concerns me - it looks like the random CNC shield that I googled (don't know if this is the one you have) protects the supply for up to 4 drivers - I'm inferring from this that, with one driver installed, you're pulling more current than the shield is designed to supply for 4 drivers... I'd be checking the wiring to the stepper, and also whether the stepper motor has a short on one coil (low-resistance measure across each coil and check for resistance commensurate with the motor specification).
Another thing... blowing a fuse is pretty dramatic - I'd check you have no shorts on the terminals to the motor, or even debris on the driver / shield that could be causing the short.
Musi
 With all due respect, you've told us nothing here - give us a link, or description as to what you've done.
Musi
			Thanks in advance.
Mustafa
 One issue here is, if you've drawn enough current through the driver to have blown the fuse, I wouldn't bet on the driver still working - you might be flogging the proverbial dead horse here. Have you got a replacement that you can test? (after checking coil resistance and visually checking for short circuits)
