Re: Manufacture metal pieces
		Before machining your bed, you should tram your spindle.
Spindle that is not tramed will make a stairway (not to heaven :nevreness:) on your bed during flattening.
ZASto
 Thanks for the advice!
Is there anything else that could go wrong with my plan?
ZASto
 Which would you prefer to have mounted on the table for best tramming results?.
A sheet of glass or thick perspex?.
Or just stick your needle on the table itself?.
		Nearly impossible to answer because it depends on the part and the accuracy you are aiming for and how good a job you make of the first attempt.
For a milling machine then you'll want fairly good accuracy and you may find it cheaper and less hassle to have the main important parts made for you and important surfaces machined flat and parallel etc.
This will save you time and money long term as you will only do it one time rather than spending weeks or months making failed attempts as you chase accuracy.
Often trying to save money in the wrong places costs money long-term and becomes a false economy.
		One thing that can help you sometimes is tooling plate. This has reasonable accuracy in both thickness, flatness and the two sides being parallel. But there will likely be some parts where you need surfaces accurately at 90 degrees etc., and there as Jazz said it may be better in the long run to get them machined for you.
		Thank you for your answers!
I guess I will look around for someone with a mill, as I would rather do it myself than spend an enormous amount of money to have the parts machined for me.
